There is no page titled ":Bodywork". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 19 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Wheels (18326 bytes)
1: ...ameter. Wheels up to 18x7 can fit under the stock bodywork when used with low-profile tyres.
135: * Offset size that work with stock bodywork
160: ...ven 18" wheels are being used on 1200s with stock bodywork, if a skinny low-profile tire is used.
168: ...er than 165-wide tires. The tires will rub on the bodywork unless they are very low profile (small diameter,...
240: ...nd there is nothing you can do except cut out the bodywork, perhaps fitting large flares. - Tires (15252 bytes)
14: ...it this rubber into a 1200 and keep it within the bodywork. - Spoiler (3084 bytes)
6: ...ce attached to an automobile, contiguous with the bodywork, and where only one surface (ie the top) is expos... - Wing (1664 bytes)
1: Wing fits on the rear of the bodywork and supplies downforce to the chassis. So that th... - 280ZX Strut Swap (9179 bytes)
122: ...ut is too large diameter for the B110 strut tower bodywork. So you need do one of the following: - 140Z (7545 bytes)
119: BODYWORK - Offset (16590 bytes)
54: ... offset, the tire will be very close to the outer bodywork (fender/guard)
107: ...the well, allowing the maximum width within stock bodywork.
257: ...ard (away from the spring). But this may foul the bodywork.
259: ...idth work together to locate the wheel inside the bodywork.
277: ...e possible to get 215-width tires under the stock bodywork (with [[Rolling the Guard]]) and [[fender pulling... - Painting (3612 bytes)
8: ...e $1500 USD which includes small amounts of minor bodywork. - Tech Section (4644 bytes)
127: ''Anything to do with bodywork or interior - L26 (5354 bytes)
17: ...o put in an L series motor without cutting up the bodywork as we did, though, but at the time, this how we d... - Oil Pressure Sender (5015 bytes)
131: ... braided hose from the oil sender hole out to the bodywork, and then mounted the tee with senders in place.
133: ... track. Definitely mount the brass fitting on the bodywork, not the engine. - Sneak Preview of new Datsun 1200 (11506 bytes)
16: ... 1200, power is up from 62 to 69 bhp and restyled bodywork is available in 2-door sedan and fastback coupe v... - Road & Track Road Test (11534 bytes)
16: ... 1200, power is up from 62 to 69 bhp and restyled bodywork is available in 2-door sedan and fastback coupe v... - FIA (5004 bytes)
131: Extension 3/1E 02/07/1972 BODYWORK,INTERIOR (2 pages) - South Africa GX Brochure (14981 bytes)
44: wash and brush up. The undented red bodywork, still resplendent in rally stickers, was unmarke...
60: ... and eventually they just get punched through the bodywork." - Spit (182 bytes)
1: ...your car on a barbecue spit is the easy way to do bodywork. Spin the body upside down. - Scorpion (1724 bytes)
11: ... Lambda (1981-1984) featured similar but restyled bodywork, and a larger, better-riding chassis. - Tubbed (1375 bytes)
8: ... result of the drag racing classes requiring that bodywork remained standard looking ... no flares allowed. ... - DATSUN CARS in the UNITED KINGDOM (12851 bytes)
229: ... 25 amp alternator. Magnetic shift starter motor. Bodywork incorporates latest safety features, including cr...
248: ... 25 amp alternator. Magnetic shift starter motor. Bodywork incorporates latest safety features, including cr...
