Search results
For query "Ignition"
There is no page titled ":Ignition". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Ignition Timing (9164 bytes)
    1: ... [[tune-up]] and carburetor adjustments depend on ignition timing being correct.
    27: = Ignition Timing Specifications =
    35: == Late 1200 Electronic Ignition ==
    77: == With Electronic Ignition ==
    95: ... points (if you haven't converted to [[Electronic Ignition]]) you must set the dwell for perfect tune. To ac...
  2. Ignition Switch (12532 bytes)
    1: ... Datsun 1200 ignition switch is also known as an "Ignition Starter Switch". For STD models, it is integrated...
    17: Interruptor de ignićāo [Ignition switch]
    23: ...column-mounted ([[Steering Lock]]). The keylock & ignition switch are integrated with only three or four spa...
    25: The ignition switch is mounted via bracket on the dash.
    26: ...ignition-2.jpg|Datsun%201200/wiki}} {{Photo|S52-4_ignition-1.jpg|Datsun%201200/wiki}}
  3. Pertronix Electronic Ignition (3513 bytes)
    1: The Pertronix Electronic Ignition Retrofit Kit model 1741 fits a stock Datsun 1200 ...
    9: ...ent" type of unit very similar to the [[Hot-Spark Ignition]]). It is more reliable than points, which for to...
    19: [http://www.streetsideauto.com/p/pertronix-ignition-kit-ignitor-datsun-4-cyl-1741/ StreetSideAuto.com...
    41: ...o consider a high-energy system. See [[Electronic Ignition]].
    61: ... duty-cycle circuit to prevent overheating if the ignition switch is left on. Apparently the Ignitor doesn't...
  4. Ignition Modifications Overview (597 bytes)
    2: [[Category:Ignition Modifications]]
    4: ... fuel injection. See main article:[[EI|Electronic Ignition]].
  5. Electronic Ignition (11848 bytes)
    4: There are many type of Electronic Ignition (EI), but the most common choices seem to be:
    12: * $300+ fully [[#programmable]] ignition (spark curve and timing)
    15: Advantages of electronic ignition include:
    31: Why go to all the trouble upgrading to electronic ignition?
    38: * Use an EI coil (designed for electronic ignition) and wire it correctly. See [[EI Wiring]].
  6. VW Electronic Ignition Conversion (608 bytes)
    3: also see: [[Electronic Ignition]]
  7. Ignition Coil (5940 bytes)
    1: An ignition coil creates a powerful spark by stepping up 12V ...
    3: Also see: [[EI Coil]] for electronic ignition
    10: <br>2: Ignition Coil
    28: 22433-14806 COIL-ignition (Hitachi C6R-601)
    29: 22433-14816 COIL-ignition (Hanshin H5-15-2)
  8. Hot-Spark Ignition (2741 bytes)
    1: ...SD, and fits easily like a [[Pertronix Electronic Ignition]] unit, but is less expensive.
    15: ... a low-current 3.4 ohm unit. [[EI Coil|Electronic Ignition Coil]]s are usually 0.7 ohms for a more powerful ...
    24: ...les/newbb/viewtopic.php?topic_id=60788 Electronic Ignition for points Hitachi Dizzies]
    39: ...rk ignition wire. Too much voltage can damage the ignition module}}
    42: [[Category:Ignition Modifications]]{{End}}
  9. Crane Ignition (1809 bytes)
    1: ...te wear). Crane kits use an external [[Electronic Ignition]] module which may be mounted on the inner fender...
    4: The XR700 external ignition module can drive a standard low-energy coil, and ...
    8: 700-0001 XR700 ignition module w/o trigger
    19: The XR3000 external ignition module can drive a high-energy coil, and does not...
    29: * Works with stock Datsun [[Electronic Ignition Coil]], although the Crane coils are higher energ...
Page text matches
  1. Datsun 1200 encyclopedia (3415 bytes)
    45: * [[:Category:Ignition Modifications|Ignition Modifications]]
  2. QR25DE Engine (6399 bytes)
    46: * direct ignition (coil-on-plug)
    113: ...t System) or else you'll need the special key and ignition switch too.
    115: ...with twin carburetors. MegaSquirt can control the ignition coils and timing.
  3. Engine Swaps (25633 bytes)
    336: ...nvert it to use a carburetor or two, and using an ignition-only ECU, program it to power a relay to switch t...
  4. Carburettor Diagnosis (3654 bytes)
    1: ... the problems you have experienced are related to ignition or other causes.
    10: <li>engine keeps running when ignition turned off (dieseling)</li>
    28: * Engine Ignition (spark) problems. Click [[Engine Troubleshooting ...
    34: ...mptom: Engine runs on (diesels) after cutting the ignition.
  5. Ignition Timing (9164 bytes)
  6. Fuel pump pressure test (3334 bytes)
    8: ...where for cause of poor running, such as tune-up, ignition or carburetion problems.
  7. Choke Operation and Adjustment (5922 bytes)
    9: ...-quarter of its travel to the floor, and thrn the ignition key in the switch to "START", when the engine sta...
    89: ...r, you can simply connect the choke to 12V switch ignition (e.g. the ballast resistor). Using a relay that c...
  8. Emission Controls (28391 bytes)
    107: * Revised Spark timing (engine ignition timing)
    223: ...unit. Also it should be supplied with engine OFF, Ignition Switch ON.
    286: ...e engine "diesels" (won't stop running) after the ignition is turned off. 1973 models compensate for this by...
  9. Weber 32/36 Carburetor (22579 bytes)
    251: ...re. This means the choke only gets power when the ignition is ON and the alternator is putting out power (en...
  10. Parts Sources (15979 bytes)
    46: * Ignition Condenser
    47: * Ignition Points
    57: * Ignition Switch (electrical switch which bolts to key lock...
  11. Radio (16887 bytes)
    130: ACC on the [[Ignition Switch]] feeds the [[Radio]]:
  12. Part Numbers Index (8259 bytes)
    82: [[Spark Part Numbers|Spark]] HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG includes Alternator Mounting
  13. Fuel Injection (19606 bytes)
    196: ...ustomize the EFI for the small engine. Electronic Ignition is not required, it can use the points as a tach ...
    259: ...or use a distributorless crank-trigger multi-coil ignition system. The latter is called a "spark" system and...
    262: * [[Electronic Ignition]] for electronic distributors
  14. Wiring (8463 bytes)
    63: ...wer cars, especially with EFI and distributorless ignitions ...<br>[http://datsun1200.com/modules/newbb/view...
    65: = Ignition Switch =
    66: The ignition switch bolts to the back of the key cylinder. The...
    68: See [[Ignition Switch#Wiring|Ignition Switch Wiring]]
    90: = Ignition Coil & Distributor =
  15. Alternator Wiring (4842 bytes)
    39: <tr bgcolor=f0f0f0><td>IG (ignition)</td><td>WL</td><td>* To fuse box "M" terminal (d...
    51: WL Ignition ([[Fuse Box|'M' fuse]])
  16. Ignition Switch (12532 bytes)
    17: Interruptor de igni&#263;&#257;o [Ignition switch]
  17. 200SX EFI (11723 bytes)
    130: == Ignition Coil & Distributor ==
    139: The 200SX uses a typical Electronic Ignition distributor, with the same control box as the [[D...
    155: * Turn the ignition switch off and reconnect the wiring connector to ...
    177: ...ne stops running. Apparently there is a relay for Ignition, fuel pressure and oil pressure. Loss of any of t...
  18. Using Newer Distributor (1313 bytes)
    24: ...See how to install Distributor & set timing] at [[Ignition Timing]].
  19. Using Older Distributor (1072 bytes)
    19: ...ee "how to install Distributor & set timing" at [[Ignition Timing]].
    22: [[Category:Ignition Modifications]]
  20. B310 Electronic Distributor Swap (3084 bytes)
    33: ...ourse, set initial timing. For details, see the [[Ignition Timing]] article.
Search in namespaces :
List redirects   Search for
