There is no page titled ":Link". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Transverse link (673 bytes)
1: The '''tranverse link''', commonly called the '''lower control arm''' (... - Fusible Link (5066 bytes)
1: [[Category:Body Electrical System]]The [[Fusible Link]] is a special wire that feeds the main wiring ha...
4: ...al about six inches from the battery. The fusible link is a special length of wiring that will melt if i...
6: ...re wiring system when a short occurs. The Fusible Link protects against short circuits ... see [[Wiring#...
14: Datsun Fusible Links are color coding (e.g. W, G, R or B). When a rep...
18: <blockquote><hr>Fusible links often show no visible signs of having blown, but... - Transverse Link (9468 bytes)
1: ...alled a "lower control arm" (LCA), the transverse link is the lower suspension member. The [[Tension Rod...
11: [[Swaybar]] link bolts to the LCA
78: ... over standard pressed steel parts. Duel sway bar link pin mount holes. Chrome molly TIG welded adjustab...
83: * 54110-H1060 Transverse link ass'y R.H (formerly H1000)
84: * 54111-H1060 Transverse link ass'y L.H (formerly H1000) - 3-link (2270 bytes)
1: ...es on the front axle because it's easier to fit 3-link compared to 4.
4: 4-link -- as used by many cars such as Datsun B310 Sunny...
5: <br>{{Photo2|4-link.jpg}}
7: 3-link racing suspension
8: <br>{{Photo!|3-link.jpg|wiki}}
Page text matches
- FAQ (6725 bytes)
18: =Links=
19: TIP: Practice typing links into articles using Edit. But don't "Save" the a...
21: == How Do I Link To Another Encyclopedia Page? ==
24: It will work like this link: [[Datsun 1200]]
27: You can also give the link a custom label, like this: - Rear Axle Swaps (24555 bytes)
137: ... a good choice (needs modifications). It's also 4-link, so you have to do some significant mods to mount...
317: ...ring-fitted rear axle assembly: Cut & grind the 4-link brackets off, then weld leaf-spring perches on. G...
478: 4-link - Parts Sources (15979 bytes)
175: * [http://WWW.quicklink.net/bham/paeco/home.html PAECO INDUSTRIES]. These...
261: * [http://www.ozdat.com OzDat Online's Trade Link] has a long list of Australian Datsun specialist ... - Yahoo Auctions Japan (4625 bytes)
14: TIP: Use the "camera" link (画像) to switch... - Wiring (8463 bytes)
25: ... bout six inches from the terminal to the Fusible Link. See below.
32: ...ry<blockquote><hr>WARNING: Do not replace fusible link with a solid wire, or you risk burning up the ent...
42: == Fusible Link ==
45: ...e starter. All other power comes from the Fusible Link.</blockquote>
47: ...See main article: [[Fuse Box#Fusible Link|Fusible Link]] - Alternator Wiring (4842 bytes)
23: ...<td>* To Battery + terminal through the [[Fusible Link]]<br>* To Regulator "A" terminal (W wire)</td></t...
47: W Positive (12V from Fusible Link) - Ignition Switch (12669 bytes)
45: W POWER (12V in from [[Fusible Link]])
254: * From fusible link connected to Battery</td></tr> - Weber DCOE carburetor (9502 bytes)
29: Tomei engine, good view of the linkage
59: Kit includes manifold, carburetor, gaskets and linkage
78: = Linkage =
82: ...on_guide/DCOE_cross_bar_linkage.htm Redline Weber linkage] - Center Pull
88: {{Twin Carb Linkage}} - Engine Disassembly (239 bytes)
1: ... disassemble as A12 motor check out the following link. (Check the A12 Strip sections) - Repair Manual (20287 bytes)
42: <br>{{AlbumLinkH|1973_USA_Service_Manual|14103|Manual}}
78: ...e for download and saving. Please visit the below link are obsolete and out of print manuals and parts b...
85: Quick link to the 1200 workshop manuals:
117: <br>{{AlbumLinkH|A14E_Service_Manual|20014|A14E Service}}
156: {{AlbumLinkH|1972|29357|Online 1972 USA}} {{AlbumLinkH|Owners_manual#Export|8318|Online 1974 Ute}} - A-series Engine Swaps (14769 bytes)
193: ...quite significantly detailed at the following web link: [http://mildman.datsunprojects.org/Blue_index.ht... - 1/4 mile time log (25722 bytes)
931: [http://www.youtube.com/watch?v=I-AJMA6KzT0 Video link]
1020: [http://www.youtube.com/watch?v=vbGWU1P6wrk Video link]
1086: [http://www.youtube.com/watch?v=S8jEVbYTdHI Video Link] - B310 (13778 bytes)
365: ...ont suspension, including the struts and steering linkage. This includes the large 245mm [[Brakes#Rotor_...
375: * B310 sedans and coupes got coil-spring 3-link rear axle assembly. - Steering Gearbox Adjustment (3679 bytes)
12: ...inch of play. If you have more, it's probably the linkage or the gearbox (or often both). The tires won'...
20: You can check the steering linkage as follows:
50: ...is. The tie-rod (side rod) ends, ends of the drag link (cross rod), and particularly the idler arm shoul... - Steering Linkage (12026 bytes)
1: ...ering Gearbox]] with rear steer (behind-the-axle) linkage.
4: ...ength, and in the same plane, as the [[Transverse_Link|lower control arms]]. This is important for prope...
8: Main Linkage parts
17: * 12. Cross Rod, a.k.a. "drag link" or "center link"
23: ...is. The tie-rod (side rod) ends, ends of the drag link (cross rod), and particularly the idler arm shoul... - Front Suspension (3274 bytes)
11: * [[Steering Linkage]]
16: = Transverse Link =
17: ...alled a "lower control arm" (LCA), the transverse link is the lower suspension member.
19: See main article: [[Transverse Link]]
33: * 54110-H1060* Transverse link ass'y R.H (formerly H1000) - Suspension upgrades (19397 bytes)
29: ...ctory suspension. Just make sure all the steering linkage is in good condition:
34: * Drag link
62: ...leaf out and don't make the shocks too hard.2 top links mounted forward help to locate the diff and prev...
109: == Steering Gearbox and linkage ==
110: The complete steering linkage is adequate for competition purposes. This inc... - Three Speed Transmission (1744 bytes)
15: side-shift linkage
18: steering column shift linkage
35: * Link to the transmission swap article - EGI (26751 bytes)
34: <br>{{AlbumLinkH|B310_Brochures#EGI|26589|brochure|height=336}}
261: throttle linkage<br>{{Album|21835}}
282: <br>{{PhotoLinkH|Introduction_of_Datsun_Sunny_1400_GX-E#Blowby_Ho...
306: .... Others have successfully run Haltech, Wolftech, Link, or AEM ECUs with the EGI manifold. Adding a MAP ... - CG engine (3791 bytes)
31: Link to commerical CG13 specs: [http://www.enginepower...
