<-- back to Lighting System
Datsun 1200 side lamps are used either as running lamps (USA) or indicators/blinkers/flashers (Australia). Because USA purpose is for visibility (instead of turn signals) they are made larger, and are fitted front and rear. B210 worldwide markers adopted the size of the earlier USA B110 side lights (although the shape is slightly different).
Fitment
The side lamp bolts to the outer fender (wing/guard)
The wires from the lamp pass through the inner fender into the engine compartment via a grommet
Even late model 1200 (black rim version) use the grommet. Most aftermarket lack this part
Rear side marker lamps (used in North America) bolt to the rear fender, directly into the trunk room, hence use no grommet
Variations
1200 #global![]()
* long thin ORANGE lenses for turn signal (blinkers) * front only
1200 #North America * front lamp and rear reflector![]()
* Yellow front marker (non-flashing) * Red rear reflector * both are taller (more squarish)
Global
107 x 24 mm side lights are used as winker/blinker (indicator) lamp in worldwide markets, including Japan, Europe and Oceania. For #North America, side indicators were not used but only side lamps.
#H10 26160-H1001 LAMP ASS'Y-side flasher -7803 [chrome rim] #G10 26160-G1060 LAMP ASS'Y-side flasher 7804- [black rim]
Chrome Type
'IKI 5002 JAPAN' | 'B-110 45 TOKYO'
26160-H1001 LAMP ASS'Y-side flasher -7803 * integrated two-wire harness (bulb 12V + earth/ground) 26161-H1001 LENS -7803 [marked 'IKI 5002 JAPAN] 26162-H1001 RIM -780326164-H1001 PACKING -7803 01451-00071 SCREW 08964-10410 NUT-spring 26715-89900 BULB-6W
810
Datsun 810 Bluebird/200B/180B side markers use the Datsun B110 lens and rim
Type U74 looks exactly like the B110 markers right down to the bullet wire connectors, but the lamp body is somehow different
Type U74 is for 4-cylinder Datsun 810. The 6-cylinder models use the larger 510/B210/240Z pointed markers
810 SIDE FLASHER LAMP ASSEMBLY 26160-U7400 for SHORT BODY * 26161-H1001 LENS * 26162-H1001 RIM 26160-U7400 for LONG NOSE [6-cylinder models]
Black-rimmed type
Image Search: サニトラサイドマーカーランプᴵ
G10 type was used from 1978 April - with black rim
26160-G1060 LAMP ASS'Y-side flasher 7804- [black rim] * integrated two-wire harness (bulb 12V + earth/ground) 26161- LENS ? RIM ? 26164-G1060 PACKING 7804- 01451-00071 SCREW 08964-10410 NUT-spring 26715-89900 BULB-6W
Even late model 1200 (black rim version) use the grommet. Many aftermarket lamps lack the grommet
North America
North America side lamps are only parking lamps, and have no indicators/blinker functions. Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged. Australia moved to the same-sized large lights with the 1974 120Y.
BEWARE: Unlike the multitude of "1200" lamps on eBay, which are actually B210 lamps, 1200 lamps haveThe B210/240Z/510 lamps may fit but require wire splicing and/or conversion wiring
- two bullet-connector wiring
- rectangle shape, not pointed in the least
* 2-wire (12V + Ground) for side marker lamp (non-flashing) * individual wires (one female bullet, one male bullet) * right and left differ * front and back differ * front has longer wires with a grommet * lenses amber FRONT, red REAR * Both RH and LH lenses are marked IKI 5003 as well as IKI 7007 * Lenses marked SAE P169 and SAE A69
SAE PI69 and A69 are found on many cars and indicate meeting the 1969 standards.
Front: grommet. Rear: without grommet
COMMON [4 of each per vehicle] * 26182-H1900 RIM * 26715-89902 BULB 12V-8W (ICHIKHO) * 08964-10410 NUT-SPRING (ICHIKHO) [8 per vehicle]
NOTE: The lamp packing wraps around the housing and thus acts as a gasket between body panel and housing and between housing and rim/lens.
SAE lighting standards codes (SAE J759ᴳ)
SAEPI69
SAE = Society of Automotive Engineers (SAE Internationalᵂ)
P = Parking Lamps
I = Turn signal lamps
A = Reflex reflectors
69 = meets the 1969 standard
Although the housing is marked 'I' (Indicators/Turn Signals), these North America side lamps are only parking lights, and have no indicators/blinker functions.
ORANGE, FRONT
Orange/Amber front lamps are same coupe and sedan
* 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO) * 26185-H1900 ASSY-LAMP SIDE MARKER FRONT LH (ICHIKHO) * 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH OKINAWA 0772- * 26185-H7000 ASSY-LAMP SIDE MARKER FRONT LH OKINAWA 0772- * 26184-H1900 PACKING RH * 26189-H1900 PACKING LH * 26181-H1900 LENS, FRONT [amber] * 01451-00041 SCREW (2 per lens)
R and L lens is the same. They are marked 'TOP' on both edges so they can be turned over for correct bevel for the intended side (Lens is thicker at front edge matching the curvature of the fender).
IKI 5003 JAPAN SAE PI69 SAE A69 IKI 7007
RED, REAR
rear lamps sedan and coupe differ. Lenses are the same but the housing differs.
rear COMMON COUPE+SEDAN * 26191-H1900 LENS, REAR [red] (2) PLUS the common parts (bulb, chrome rim, and spring nuts)
Lenses are marked same as fronts IKI 5003/IKI 7007 but of course the color differs. ICHIKO (IKI) was the company that sourced these parts for Nissan.
rear COUPE * 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE * 26195-H1910 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) COUPE * 26194-H1910 PACKING RH(ICHIKHO) COUPE * 26199-H1910 PACKING LH(ICHIKHO) COUPE * 01451-00061 SCREW(ICHIKHO) COUPE (2 per lens)
rear SEDAN * 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN * 26195-H1900 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) SEDAN * 26194-H1900 PACKING RH(ICHIKHO) SEDAN * 26199-H1900 PACKING LH(ICHIKHO) SEDAN * 01451-00041 SCREW SEDAN (2 per lens)
What's the difference between Coupe and Sedan rear side light? They look the same, but since the coupe uses longer screws, perhaps the lamp housing is thicker?
Bullet connectors (see Lamp Wiring)
Gasket tapers (this may be coupe? or sedan?)
Bulb Replacement
Remove both screws from the lens, and remove lens
Push bulb in slightly and twist anti-clockwise Pull bulb straight out
Wiring connectors differ between early, late 1200s and differ for various countries. Early 1200 lamps use bullet connectors.
Only the 1200 lights interchange. However, USA 620 lenses interchange with USA 1200.
620
In USA, the 620 side marker lenses look identical. The front lamp assembly looks nearly the same as the 1200, except the packing (gasket) may be beveled (?) The rear uses a highly-angled lamp housing.
USA 620 vs 1200 * lens & rim interchange * front housing may interchange * rear housing does not interchange
SAME AS B110 USA * 26181-H1900 LENS-SIDE MARKER LAMP, FRONT (2) * 26191-H1900 LENS-SIDE MARKER LAMP, REAR (2) * 26182-H1900 RIM-SIDE MARKER LAMP (4) * 01451-00041 SCREW, FRONT LAMP (4) * 08964-10410 NUT-SPRING, FRONT LAMP (4)
The rear lamp technically takes:
01451-00051 SCREW (4) 08966-30410 NUT-SPRING (4)
Pointed Lens
Pointed lens is used by B210 and 240Z and (late USA) 510. B110 is rectangular, compared to the slightly pointed rectangle type.
1200 North America
Pointed type
B210 side lamp is different from B110 lamp, and uses a different connector style
S30 240Z bullet wire connectors S30 260Z/280Z rectangular connector B210 (120Y) rectangular connector 510 late
The USA late 510 units 1970-1972 uses the 240Z pointed lens, though the assembly differs somehow
S30
240Z has individual wires 260Z has the rectangular connector
Lamp assembly differs from B210 somehow
North America (Canada and USA) used amber front side lamp and red rear side reflector
PB110
See Main Article: PB110#Side_Lights![]()
Datsun 1000
See main article: Datsun 1000
B140
South Africa B140 bakkie from 1982-2004 used the global indicator. From 2005 used a unique small lamp.
From 2005-2008 used this small indicator:
Clear aftermarket from Autostyle
Clear Lense
clear side lenses with front & rear combo lenses
26121-27700 Datsun B10 clear lens - will it fit the 1200?
Semi-clear lenses for 2005-2008 B140
Custom
Commodore
Holden Commodore VTᵂ indicators 1997-2000
you'll need to weld up the standard indicator hole as the commodore blinkers aren't as big on the back where they mount. The hole needs to be about half the standard size
Falcon
Ford Falcon BAᵂ 2002-2005
C130 Laurel Winkers
Side lamps from the 1972-1977 Nissan C130 Laurel fit the 1200 according to blog
drill out the front hole | bolt C130 lamp on
Search terms: lens, blinker, marker, side light, side lamp, running light ウインカ ランプ レンズ ウィンカー サイドマーカー
