Thermostat
Revision as of 11:24, 17 February 2015; view current revision
Category: Cooling System
Datsun 1200 uses a traditional pellet-type engine cooling thermostat. It regulates temperature by closing when cold to keep hot water in the engine, and opening when hot allowing the coolant to flow to the Radiator.
Cooling Thermostat
Replacement
Replacement of the thermostat is called for when:
  1. Put a bucket under the radiator fan to catch spilled coolant
  2. Loosen the clamp on the hose at the water outlet
  3. Twist and pull the hose off the outlet
  4. Remove the two fastening bolts
  5. Scrape all traces of gasket off water outlet and cylinder head face
    • be careful not to nick the aluminum of the gasket faces
  6. Fit thermostat into engine, then gasket, then housing and tighten moderately
    The gasket goes against the housing (not the head).
  7. Top up coolant
  8. Rinse spilled coolant off engine and body with water
  9. After engine has been fully warmed up, and cooled down, top up coolant again.
Be sure to fit thermostat with spring facing into engine
WARNING: Due to air pockets, the coolant level usually drops down and the engine can easily overheat if not monitored for a few days after changing the thermostat.
Temperature
It is not unusual with any 10-year old stock radiator for the temperature to rise during summer. If this occurs with your Datsun, don't panic. The engine can run all day close to the "H" mark.
DO NOT let it go onto the H mark. Pull over immediately if it goes past the H mark. Don't wait 30 seconds, it could be too late.
Typical Temperature
If this worries you, fit a slightly larger radiator to provide more cooling than Datsun provided with the 1200s.
According to Owner's Manual: Water Temperature Gauge,
the engine will run "satisfactorily" in this range:
1972 USA Owners manual (Page 10 ... ):
For most types of driving, the pointer will hover about halfway. However, the engine will run satisfactorily when the pointer is at any position in the middle range.
TIP: Use the stock engine-drive fan. Electric fans are notorious for failing to cool the radiator in stop/go traffic. Of course an electric fan can work well, but many don't.
What is the correct temperature the engine should run at?
Primarily, this depends on the thermostat. The engine can run fine at a variety of temperatures. You can get different temp thermostats, and the coolant should stay steady at that temperature.
Datsun factory options were:
* THERMOSTAT 170 F (75.5c optional, for tropical use)
* THERMOSTAT 180 F (82 c, for standard use)
* THERMOSTAT 190 C (88 c, optional for winter)
These three thermostats were mainly because of the heater. 170 for hot climes so the room heater won't put out much heat, 190 for cold climes so the heater puts out more heat.
180 is recommended for all street cars, it will keep the oil at optimum temperature (oil runs about 20 degrees hotter than the coolant). A guy at the oil company told me 180 is ideal for the oil working the best. He went through training for Mobile I think it was and they were formulating oil for 200 degrees, which works out to be 20 degrees warmer than the coolant for most engines. Maybe it's changed now but it won't be colder as engines now run hotter than ever. If anyone has documentation for this please add it here.
160-degree is favored by some for drag racing as they tune the carbs for cold dense air, or for use with low octane fuel. But EFI computers don't run well at cold temps nor does the oil, and cold temps mean more engine wear. Cold temps are not recommended.
But won't I make more HP with a colder thermostat?
Not if your carburetor jetting is stock -- it expects warmer less dense air. And when you floor the accelerator pedal, the air cleaner hot air duct opens up letting only cooler air in, and the stock Hitachi compensates via the power valve. Those clever Datsun engineers had it covered.
Many cars use a 195 F degree thermostat along with a 14 lb. radiator cap to raise the boiling point. A radiator is more efficient at higher temperatures, because the temperature differential to the air will be greater, thus shedding heat faster. In turn airflow can be reduced which increases aerodynamics.
After the thermostat, the radiator is the next factor. If your temp. stays steady except on hot summer days (which is normal), you can use a bit larger replacement radiator and it will stay steady even during temperature peaks. Use either a new unit, rebuilt unit, or a good used unit from a B210 or B310, which are larger than the 1200 radiator.
See Radiator.
Thermostat Types
Newer Type -- advanced type with 'jiggle' valve. The jiggle valve is used to "shorten the warm up period" (Nissan Service Bulletin No. 188 Introduction of New Datsun B210, 1973).
The 1969 L16 service bulletin says: "fitted with a jiggle valve to improve defrosting performance"
Thermostat Testing
Test it in a pot of water, heated on the stove, with a cooking thermometer. Notice when the thermostat opens.
Thermostat Part Numbers
Cooling Thermostat. $7-$16
Nissan Part Numbers for B10/B110/B210/B310
180F (82C) 21200-P7901 $19 USD
190F (88C) 21200-P7906 $19 USD (optional, winter)
Buy at http://www.rockauto.com
Gaskets
There are various gaskets.
NOTE: 4-bolt gaskets work on a 2-bolt housings.
2-bolt: 11062-18000 GASKET-WATER OUTLET
3-bolt: 11062-M3001 GASKET-WATER OUTLET
4-bolt: 11062-H7201 GASKET-WATER OUTLET
CORTECO 111451
Fel-Pro 352981
Victor Reinz C20116
Gates 33644
Stant 25168
Stant 25113 universal gasket
Gates 33646 universal gasket
Fel-Pro 25608
Victor Reinz C26075
For standard B110 180-degree thermostat:
Rockauto.com
* STANT 13858 with jiggle pin 180 degree (82C)
* STANT 32118 with jiggle pin 180 degree (82C)
* STANT SuperStat 45858 with jiggle pin
* GATES 33478 with jiggle pin
* GATES 33478S Premium with jiggle pin
* BECK/ARNLEY 1430685
* BECK/ARNLEY 1435685 Fail-Safe
* MOTORAD 2041180
* MOTORAD 7241180 Fail-Safe
* Prestone 391-180
* Prestone 752-180
* ACDELCO 12T25D (19114482)
* ACDELCO 12TP10D {#19114402}
* GATES 33478
* GATES 33478S Superstat
* STANT 45858 Superstat
Dimensions:
* 2 1/8" diameter
* 29/32" high hot side x 13/16" high cold side
Stant 13858
192 degree (use in cold climates)
* STANT 13859 with Jiggle Pin
* STANT 45859 Superstat
* GATES 33479 with Jiggle Pin
* GATES 33479S Superstat
* BECK/ARNLEY 1430686
* ACDELCO 12T25E
160 degre (use in hot climates)
* BECK/ARNLEY 1430684
* MOTORAD 241160
Honda 1994-1996 PASSPORT
ISUZU 1989-1994 AMIGO, 1992 IMPULSE, 1981 I-MARK, 1981-1995 PICKUP,
 1985-1989 I-MARK, 1991-1997 RODEO, 1988-1990 IMPULSE, 1984-1991 TROOPER
Datsun/Nissan
1971-1973 1200
1974-1978 B210
1979-1982 210
1974 260Z
1975-1978 280Z
1979-1982 280ZX
1971-1972 521 Pickup
1972-1979 620 Pickup
1980-1986 720 PICKUP
1986-1989 D21 Pickup
1987 Pathfinder
1976-1978 F10
1979-1982 310
1983 Pulsar
1983-1989 Pulsar NX
1971-1973 Datsun 510
1973-1976 610
1974-1977 710
1978-1981 510
1977-1988 200SX
1977-1981 810
1982-1984 Maxima
1982-1988 Sentra
1982-1989 Stanza
1987-1988 Van
Thermostat Housing
Nissan calls the thermostat housing the "Water Outlet".
* 11060-G0300 OUTLET-WATER B110 JDM, USA
* 11060-H7000 OUTLET-WATER B110 USA MANUAL from 0373
** Has boss for temp switch
   22120-U2001 ASSY-SWITCH WATER TEMP from 0373
   same switch used by L16-powered 620 USA for EGR
   also 1973 510
The purpose of the late 1973 water temp switch is unknown, but it might replace the ambient air temp switch of the TCVAS system. In other Datsun models it was used to disable EGR, including PB110 L14 engine (in thermostat housing) and EGI A14E engine (in EGR adapter on intake manifold). On the 1974 L18-powered 620, it was activated at 120 degrees, so it is the wrong temp to be used to control a radiator fan.
A-engine Variations
There are a number of different type for A-series engines.
  • 2-bolt Type -- as used by early engines, and some late engines
  • 3-bolt Type -- newer engines
  • 4-bolt Type -- newer engines
It further breaks down:
  • 2-bolt Type -- as used by Datsun 1200
    • B10/B110 Type, outlet points 180 degrees
    • Late B110 USA -- with boss for thermo switch
    • B210/B310 Type-Outlet points 225 degrees
  • 3-bolt Type
    • with accessory mounting bosses
  • 4-bolt Type -- as used by some newer engines
    • with accessory mounting bosses and Air fitting
    • with accessory mounting bosses (forward) and Air fitting
2-bolt Type Thermostat housings attaches radiator hose at:
  • B10/B110: 9:00 o'clock (180 degrees)
  • B210/B310: 10:30 o'clock (225 degrees) to clear alternator belt
of high-mounted alternator
Head Mating Surface
Starting with the 1974 redesign, all A-series cylinder heads feature alternator on right side of engine. This necessatated adding a bolt hole to the front of the head next to the water outlet. This means the water outlet was raised up so as to not cover the bolt. This in turn means the radiator hose location is different, even though the first yeat B210 radiator is otherwise nearly identical to the B110.
Head Mating Surface: 1974-up engine w/o Air passage
Head Mating Surface: 1974-up engine with Air passage
23098.jpg Adapter
Housing Part Numbers
NOTES:
  • CAL = California
  • CAN = Canada
  • FED = USA, except California
  • GFU = 5-speed Round-port A14 engine
  • JDM = Japan Domestic Market
  • Gasket is also called "WASHER-JOINT WATER OUTLET"
The 4-bolt gasket works on a 2-bolt housing.
2-bolt Type
The 2-bolt type is used by B10 and B110. It is also used by some B210/B310 engines that do not have an Air passage in the cylinder head.
9:00 Outlet
B10 & B110 - Engines without alternator bolted to cylinder head.
* 11060-18000 OUTLET-WATER B10
* 120Y 1974-1977
Aftermarket
KILKENNY CASTINGS WO27
* suites 11060-G0300
11060-H7000 OUTLET-WATER B110 MANUAL from 0373 USA
* Has boss for temp switch:
B110 housing and original fittings
10:30 Outlet
For right side mounted alternator.
* 11060-H5000 OUTLET-WATER B210 A13 USA 1974, A12 JDM early
* 11060-H5000 OUTLET-WATER B310 A12,A13,A14,A15 JDM 8011-
* 11060-H5000 OUTLET-WATER B120 A12 -8910
* 11060-H5000 OUTLET-WATER B310 A12A CAL from 0879
Aftermarket
KILKENNY CASTINGS WO27A
You can see how on newer engines, the alternator bracket bolts next to the outlet. This requires the outlet at 45 degrees up so the bolt is uncovered.
Late B120
11060-G2500 OUTLET-WATER B120 A12 8910-
* 11062-H7201 GASKET-WATER OUTLET -9202
* 11062-18000 GASKET-WATER OUTLET 9202-
3-bolt Type
The 3-bolt water outlet was used in newer engines that do not have an air port in the front of the cylinder head -- and that do not have the alternator bracket bolted to the front of the head. In this case, the outlet can exit more to the side, even covering the 4th bolt hole.
11060-M3001 OUTLET-WATER
* B310 JDM -7812 A12 S,K; A14 V
* B310 FED A14,A15
Aftermarket:
KILKENNY CASTINGS WO92
3-bolt type fastening housing to head. With two accessories bosses pointing up
4-bolt Type
All engines with Air passage in the cylinder head require a 4-bolt housing and gasket. Some newer engines without Air system also use the 4-bolt kit.
4-bolt
Smog Pump Type
bosses up
* 11060-H7201 OUTLET-WATER B210 A14 USA
* 11060-H7400 OUTLET-WATER B210 A14 FED GFU from 1276
* 11060-H7400 OUTLET-WATER B210 A12 late, A14
* 11060-H7400 OUTLET-WATER F10 A14 USA
Air Induction Type - 1 Boss Forward, 1 boss up
11060-H9100 OUTLET-WATER B310 A14,A15 CAL,CAN
* 11062-H7201 GASKET-WATER OUTLET  B310 A14,A15 CAL,CAN
11060-H9100 OUTLET-WATER B310 A12A from 1278
* 11062-H7201 GASKET-WATER OUTLET A12A CAN from 1278
* 11062-M3001 GASKET-WATER OUTLET A12A FED from 0879
A14/A15 high angle
Thermo Switch Housing
Late, Accessory bracket type
