Japan Market
Although marketed and sold as a "Datsun", the 1000 did not come with any "Datsun" badges or emblems (for more details, see Datsun B10#Name).
radiator grille #'S' ornament 1967 radiator grille #'S' ornament 1968-1970 fender/wing #'Sunny' badge fender/wing #'Deluxe' badge
- Sedan, light Van (wagon) and Truck (ute) all use the same front badges
- Coupe badges differ
- The grille badge changed from 1967 (vertical badge) to 1968-1970 (horizontal shield-shaped badge)
Japan model sedan badges with Coupe round badge
Deluxe Sedan badges with Coupe grille badge
Sedan & Van
- #63841-18025 EMBLEM-"Sunny", front fender [Also Truck]
- #63843-18225 EMBLEM-"deLuxe", front fender Deluxe [also Coupe]
- #84821-18025 EMBLEM-"Sunny 1000" [boot, right side sedan/van]
- #84823-18225 MARK-"deLuxe" [boot, right side]
- #84824-27725 KIT-MARK-"SPORTS" Sedan 4-speed [boot lid, left side]
- #84824-20300 MARK-"NISSAN Full Automatic" Sedan A-all [boot lid, left side] [Same as Coupe badge]
- #84823-H0125 SET-MARK, "GL" Sedan GL
- #62311-18025 SET-EMBLEM, radiator grille ["D"]
- #62311-27725 KIT-ORNAMENT, radiator grille (from C/# VB10-066701) ["S"]
Truck Only
- 96906-15401 LABEL-car name "Sunny"
- #84235-18225 MARK-"deLuxe" Truck Deluxe [also Sedan, Van]
Coupe Only
KB10 came out in mid-1968, there was no 1967 coupe.
- #62311-25725 KIT-ORNAMENT, radiator grille Coupe
- #63841-25700 BADGE-"Sunny coupe", front fender
- #63843-18225 EMBLEM-"deLuxe", front fender Deluxe [Same as sedan, coat-of-arms style]
- #84812-25725 KIT-ORNAMENT, trunk lid Coupe [Round with reeded edges]
- #84823-18200 MARK-"deLuxe" [boot, right side]
- #84824-20300 MARK-"NISSAN Full Automatic" Sedan A-all [rear panel, center] [same badge as sedan]
- #84823-H0125 SET-MARK "GL"? "Deluxe"? Coupe GL
- #76831-H0225 'S' ornament
- #Option Badges
Export Models
Export Datsun 1000s, being sold by Datsun dealers instead of Sunny Shops, were badged "Datsun" instead of Sunny. However they still used the "S" emblems.
- The SunnyCoupe badge does not appear to have been used on many export coupes, if any.
- Exports coupes used 'DATSUN' instead of 'Sunny' badges
Rear Badge - Export coupes used the 'S' emblem, like this Australia coupe
Rear 'Sports' badge -- was it stock?
- BADGE-"D", radiator grille
- Different color badges?
- MARK-"DATSUN 1000"
- MARK-"DATSUN", front fender
- 84823-18200 Coupe Rear 'deLuxe'
- #62311-25725 'S' flag badge, radiator grille
'D' Early Grille Badge
A narrow, vertically-oriented 'D' badge was used on early models -- both JDM and Export models.
- sedan 1966-1967
- light van (wagon) 1966-1967
- 1968 Sunny Truck (B20) with aluminum 2-section grille
- 1968 Australia Ute (which used the 1967 sedan grille)
Sedan/Van with the early aluminum-type 4-section grille
There are M4 nuts & washers fixing the emblem to the grille
quantity: 2 each 89-15434-1 WASHER-plain standard, M4 89-15134-1 WASHER-lock, M4 89-11104-1 NUT, low carbon steel (low grade strength/JIS 4T) M4 thread
'S' Late Grille Badge
62311-27725 KIT-ORNAMENT, radiator grille 'S' Sedan/Van 1968-1969 Truck 1968-1970
Flag Grille Badge
Radiator grille emblem ('S' flag badge in Datsun colors) — left side
62311-25725 KIT-ORNAMENT, radiator grille COUPE, SEDAN GL
63843-18225
COUPE: 'deLuxe' and 'Sunny Coupe' front fender badges
63841-18025
- Sedan
- Van
- Truck
- but not Coupe which used #'Sunny coupe' badges
63841-25700
63841-25700 BADGE-"Sunny coupe", front fender (red, white & blue Datsun Colors)
76831-H0225
76831-H0225 KIT-ORNAMENT, rear quarter pillar (from C/# B10-350001) (2) 4-door Deluxe
76831-H0225 'S' ornament [round]
* with smooth edge
* with fluted interior ring
compare to #84812-25725 * with reeded edge * with 3-section interior ring![]()
1969 4-door sedan Deluxe rear quarter pillar ornament
84812-25725
84812-25725 KIT-ORNAMENT, trunk lid Coupe [Round]
* with reeded edge
Compare to #76831-H0225 Sedan Pillar 'S' ornament [round] * with smooth edge * with fluted interior ring![]()
84821-18025
84821-18025 EMBLEM-"Sunny 1000" [boot, right side]
84823-18225
84823-18225 MARK-"deLuxe" [sedan boot, right side]
- differs from coupe #84823-18200
84823-18200
84823-18200 MARK-"deLuxe" [coupe boot, right side]
- differs from sedan #84823-18225
84823-H0125
84823-H0125 SET-MARK "GL" * Coupe GL * Sedan GL
84824-27725
* Sedan boot lid, left side
* 3-speed models carried no badge
COMPARE to Datsun 1200 'Sports' badge![]()
84824-20300
MARK 'NISSAN Full Automatic'
Option Badges
Car Badges (Sunny motorsport mark)
Safari Badge
Sunny * The 17th East African Safari Rally [1969]
Studs: M5 x 40mm Bolt pattern: 2 on 36mm PCD
.jpg)
