Bulbs
Revision as of 08:06, 29 May 2025; view current revision
<-- back to Lighting_System#Lamp_Specifications
See also: Headlights
Electric light bulbs (globes)
5021.jpgAlbum 5021
1. Exterior single element, one bottom contact
Rear T/S (turn signal) -- See Tail Lights
Front T/S -- See Front Combination Lamp & PB110
* #26717-89900 BULB 12V-23W
  * B110 North America
  * B110 Japan and PB110
* 21 watt (other countries)
5021.jpgAlbum 5021
REAR INDICATORS
<-- single bottom contact
2. Exterior dual element, two bottom contacts
Dual-filament bulb
* Front park & T/S -- See Front Combination Lamp
* Rear Tail & Stop -- See Tail Lights
#26717-89920 BULB 1V-23/8W Type 1034
  * Japan
  * North America (can also use Type #1157)
12/5 watt
  * other countries
5021.jpgAlbum 5021
DUAL FILAMENT BULB
double bottom contacts -->
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
5021.jpgAlbum 5021
3. FUSE
<-- 10A
23313.jpgFuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
5021.jpgAlbum 5021
4. FUSE
15A -->
23313.jpgFuse Box
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
26945-H4600 (not sure if this lamp only, or whole unit)
* Type 3175 e.g. Wagner 12100
5021.jpgAlbum 5021
5. SEAT BELT LAMP
5023.jpgWarning
6. Dome Lamp
#26736-89902 (room lamp) Sedan, Coupe
#26715-89900 for truck version
5021.jpgAlbum 5021
6. ROOM LAMP
20758.jpgDome Lamp
7. Instrument Panel Lamp
The instrument panel illumination lamps use T10 bulbs. T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
* Cluster Gauge illumination bulbs, warning bulbs
* SQUARE METER ONLY: + two dash T/S bulbs
5021.jpgAlbum 5021
7. WEDGE HOLDER & BULB
26261-89902 1.7W/2.7W bulb (ROUND GAUGE)
26261-89900 3.4W bulb (SQUARE GAUGE)
24884.jpgWedge Lamps
26260-89900 Wedge Socket
Twist-lock holder (7 used in round dash). These sockets fit bulbs with a W2.1x9.5d base (aka W2, miniature wedge, or T5 base.
Nissan 26260-89900 Wedge Socket $3.28 USD each [twist-in type]
* Type V-2 Instrument Panel socket T10 cluster plug lamp for 1/2" or 13m hole
* 7 or 8 for bar meter dash
* 7 for B110 round gauge dash
* 8 for B120 round gauge dash
174_5d9747dfdd04b.jpgPost click for topic
  * #26261-89902 2.7 watt bulb (ROUND GAUGE)
    Some Nissan catalogs say 1.7 watts
  * 2.7 watt Type 161 is often specified by aftermarket
  * 3.4 watt Type 158 is sometimes listed by aftermarket
JPN B110
  * #26261-89900 BULB-12V, 3.4W SQUARE METER 7
    also used for B110 Tail Lights small bulb
  * #26261-89902 BULB-12V, 1.7W ROUND METER 7
JPN B120
  B120 -8608 Tail Lights
   * #26261-89900 -8608 12V-3.4W 8
  SQUARE METER
   * #26261-89900 -7803 12V-3.4W 8
  ROUND METER
   * #26261-89902 BULB 12V-2.7W 6
   * #26261-01G00 BULB 12V-1.4W 8910- F/EXH TEMP
   * #26711-89900 BULB 12V-1.7W 8910- F/BRAKE WARNING
T10 glass with T5/W5W base
* 26261-89900 1.5 watt Ichikawa/Ichikoh Datsun B10
* 26261-30100 1.5 watt Ichikawa/Ichikoh Datsun B10
* Type 194 1.0 watt
* Type 161 2.7 watt Type 161 specs
* Type 158 3.4 watt
* Type 159 6 volt
CAUTION: Type 159 is identical looking, but only 1.0 watt 6.3V. In addition there are several others including lower and higher wattage versions.
T3-1/4 glass with T5/W5W base (max. O.D.: 10.3 mm)
* 194 2cp
* 168 3cp
* 2827 4cp
* 2825 4cp (eu)
* 25837 6cp
Bar Cluster Gauge uses 7 or 8 lamps including the T/S bulbs
27148.jpgAlbum 27148
VENDOR: RockAuto.com Product: Instrument panel bulbs
Type 158 less than $1 each
* more watts than standard/ runs hotter
* 25 lumens
Hella 158
GE 158
Wagner 158LL (long life)
LED
HELLA 921LED5K LED 5000K $5.32
PHILIPS 158WLED Ultinon LED $9.17
HELLA 921LED65K LED 6500K $5.37
194-xHP5-CAR 85-95 lumens $4.5 SuperBrightLeds.com
Since the LED version can be so much brighter, consider a dimmer.
LEDs get darker than incandescents, so remember to replace them long before they burn out.
Incandescent 2000 hours  7% loss
CFL         10000 hours 22% loss
LED         20000 hours 30% loss
8. Exterior Lamp
5021.jpgAlbum 5021
CAUTION: various watts
8. bulb for:
* Side Marker
* License Lamp
* Reverse Lamp
Side-marker lamp
6 watt (flashing, non-North America)
8 watt (North America, non-flashing)
  * Wagner 97
  * Sylvania 97 (9.32 watt  nominal)
License Lamp
7.5 watt Coupe, Van 26715-89901 Ichikho
10  watt Sedan, except North America
7.5 watt Sedan USA
  * B29.012.625 (7.5w) or [Toshiba A12V8W 6 7]
Reverse Light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
5021.jpgAlbum 5021
9. Dash T/S bulb
<-- 1.7W round dash
<-- 26260-H1800 SOCKET-WITH LEAD WIRE
BULBS FOR DASH T/S INDICATORS
* #26261-89900 BULB 3.4 watt (SQUARE GAUGE)
  wedge socket use
* #26711-89900 BULB 1.7 watt (ROUND GAUGE)
  can use 1.9 watt Type 1445 e.g.Wagner 1445
  1.9W G3-1/2 (7/16" globe) BA9S, 22.7 mm long 1445 specs
14515.jpgAlbum 14515 IMG_1398.jpg 21615.jpgAlbum 21615
Lamp Specifications
Australia
1974 B120 Owner's Manual (Page 30 ... 30)
Bulb Chart
Headlight unit 12V-50/40W
Directional    12V-21/5W
Parking        12V-21/5W
Side Flasher   12V-6W
License Plate
  Sedan        12V-10W
  Wagon, Van   12V-7.5W
Rear Combo
  Tail         12V-21/5W
  Stop (brake) 12V-21/5W
  Turn Signal  12V-21W
  Back-up      12V-21W
Meter (bar type)
  illumination 12V-3.4W
  IGN warning  12V-3.4W
  T/S          12V-3.4W
  BEAM         12V-3.4W
  OIL          12V-3.4W
  Clock        12V-3.4W
Room light     12V-10W
Rectangle Meter specs (1974 B120)
Head Lamp
#26705-04101 Sealed beam unit (Koito)
#26705-08700 Sealed beam unit (Koito)
Front Combination Lamp early
#26717-89920 BULB (12V-23/7W)
#26261-89900 BULB (12V-3W)
Front Combination Lamp from 1973 September
#26717-89900 BULB (12V-23) [P21W]
#26261-89920 BULB (12V-8/3.4W) [P21/5W???]
#26261-89925 BULB (12V-8/3.4W) 7804-
B310
新型サニー電球セット New Type Sunny bulb set
B6717-H8500 BULB
29817.jpgAlbum 29817
Items included in the set
    5W SIDE FLASHER
  #10W ROOM
 #3.4W PARKING, METER [LIFE 158]
   15A FUSE (quantity 2)
   10A FUSE (quantity 2)
#23/8W TAIL,STOP
  #23W TURN SIGNAL
8/3.4W FRONT PARKING
   10W LICENSE
29816.jpgAlbum 29816
North America
1972 USA Owners manual (Page 36 ... ):
Bulb Chart
  Spec. SAE No. Nissan/Ichiko
Headlight unit 50/40W 6012 #26705-04201
Front Combo Light
  Direction and Parking
23/8W
1034*
#26717-89920
Side marker 8W 67 #26715-89902
License plate 7.5W 89 #26715-89901
Rear Combo Light
  Tail
  Stop (brake)
  Turn signal
  Back-up light
23/8W
23/8W
23W
23W
1034*
1034*
1073^
1073
#26717-89920
#26717-89900
Wiper Knob (1973) 3.4W 158  ?
Heater control (1973) 3.4W 57  ?
Meter (round gauge)
  illumination
1.7W
161
#26711-89900
  IGN warning 1.7W 161 #26711-89900
  Turn Signal #26713-89900
  BEAM 1.7W 161 #26711-89900
  OIL warning 1.7W 161 #26711-89900
  BRAKE warning 1.7W 161 #26711-89900
Room light 10W n/a #26736-89902
* #1157 can replace type #1034 but uses more current
^ #1156 can replace type #1073
Portugal
Opticas 12V-50/40W
12V-21/5W Luz de mudança de direcção o de presença
12V-6W Luzes laterais de mudança de direcção
12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras
 12V-5W luz de presença
 12V-21W luz de stop (travões)
 12V-21W luz de mudança de direcção
 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos
12V-3W Luz avisadora da ignicão
12V-3W Luz indicadora dos máximos
12V-3W Luz avisadora da pressao do óleo
12V-10W Luz interior
12V-3W Luz de iluminação do relogió
E= Nissan Part Numbers =
26151-89910
26151-89910 UNIT-sealed beam (12V-35W) KOITO
Fog Lamps OPTION
* JPN B110 Fog Lamp Part Numbers
26261-01G00
Nissan 26261-01G00 BULB 8910- 12V-1.4W F/EXH TEMP
Nissan 26260-95W00 SOCKET ASSY-BULB 8910- F/EXH TEMP
26261-89900
Nissan 26261-89900 BULB 3.4 watt [exterior lights + rectangle dash]
type 158 3.4W
27147.jpgAlbum 27147
14V-3.36W Miniature Wedge T3-1/4 Glass (25.8mm MOL 10mm diameter) W2.1x9.5d Base
#9. Instrument Panel Turn Signal
#7. Instrument Panel Lamp
Meter Part Numbers SQUARE GAUGE DASH
* JPN B110 bar meter
* JPN B110 Tail Lights
* JPN B110 KPB110 Tail Lights
* JPN B120 -8608 Tail Lights
* JPN B120 -7803 TURN SIGNAL (2)
* JPN B120 8910- BRAKE WARNING (1)
* Many 2000s era Nissan Cargo Lamp, Marker Lamp, Tail Lamp, etc
B110 tail light small bulb
26261-89902
Nissan 26261-89902 BULB 12V-2.7W WEDGE TYPE $2.89
Nissan-Toshiba 161
27149.jpgAlbum click to view
Official Nissan parts catalogs list it as 2.7W (B120) or 1.7W (B110,PB110 -- which also show an incorrect illustration). Even Nissan USA shows two different wattage for the same bulb.
Meter Part Numbers ROUND GAUGE DASH
* B110, B120
* R35 Nissan GT-R 2015-2018 Premium [door courtesy lamp bulb, step lamp]
26705-04101
Headlight Part Numbers
* JPN B120 -8910 (except Okinawa -8503)
26705-08700
26705-04201
26705-04201 UNIT-SEALED BEAM (ICHIKHO) <> #26705-89925 (ICHIKHO)
* 12V-50/40W
* USA B110
26705-89905
26705-89905 UNIT-SEALED BEAM (KOITO)
* 12V-50/40W
* USA B110
26705-89920
26705-89920 HEAD LAMP UNIT IKI
26705-89925
26705-89925 UNIT-SEALED BEAM (ICHIKHO) <> #26705-04201 (ICHIKHO)
* 12V-50/40W
* USA B110
* JPN HEAD LAMP UNIT IKI F/OKINAWA -8503
26705-C9920
26705-C9920 HEAD LAMP UNIT [square type]
* JPN B120 8910-
26711-89900
Nissan 26711-89900 BULB 12V-1.7W
* G10 glass with BA9S base (10MM Globe with 9mm Bayonet mount)
27145.jpgAlbum 27145 24410.jpgAlbum 24410 27146.jpgAlbum 27146
#9. Instrument Panel Turn Signal qty 2
Meter Part Numbers round guage
* USA B110
* JPN B110
* JPN B120 7804-
* JPN B10 Coupe 8
26717-89900
23 watt Type 1073 but can also use 27 watt Type #1156
Nissan 26717-89900 BULB 12V-23W
Turn Signal bulb (front and rear)
#. single bottom contact
USA/JPN B110, B120 Rear Combo Lamp T/S (turn signal) bulbs
USA/JPN B110, B120, B210 Front Combo Lamp T/S (turn signal) bulbs
JPN PB110 Front Turn Signal Lamp
JPN KPB110 Rear Combination Lamp
* S-8 size and shape, single contact bayonet base
27466.jpgAlbum 27466
26715-89900
26715-89900 BULB-6W
* G14 globe style
* superceded 26073-30001
Side Lamps Japan market
B10 Lights#Side Lights JDM
Room Lamp Japan truck
510 Side Marker (Canada to September 1969)
26715-89901
26715-89901 BULB 12V-7.5W (ICHIKO)
* 12V-7.5W
License Lamp Part Numbers
* USA B110 Sedan, Coupe
* JPN B120 Truck
* JPN B110 Coupe
* JPN B110 Van 1970-1971
26715-89902
26715-89902
* 12V-8W
* USA B110 front & rear Side Lighting Marker lamp
Traditional replacement: Type 97 10W $0.30 Rockauto or part 97
Miniature Lamp G-6, single contact bayonet
length: 1.438 inch (36.5mm)
diameter: 0.74 inch
base: BA15s
wattage: 9.3W
174_67df6fde3d1f5.jpgPost click for topic
APPLICATION
* Many, many up to 2000 Bering MD23M
1971-1973 Datsun B110
1968-1973 Datsun 510
1970-1978 Datsun 240Z,260Z,280Z
1973-1978 Datsun B210
1973-1976 Datsun 610
1976-1978 Datsun F10
1979      Datsun 210
1980-1982 Datsun 720
1979-1983 Nissan 200SX
1979-1980 Nissan Datsun 310
1985-1988 Nissan Maxima
1983-1986 Nissan Pulsar NX
1982-1985 Nissan Sentra
1982-1986 Nissan Stanza
1987-1990 Nissan Van
1970-1979 Chevrolet
2001-2002 Chevrolet Silverado
1971-1977 Chrysler
and many more
26717-89920
12V-23/8W Type 1034
26717-89920 BULB 12V-23/8W (ICHIKHO)
* 12V-23/8W
Front Combination Lamp Part Numbers Direction and Parking
* USA/JPN B110 Sedan Rear Combination Lamp Part Numbers
* USA/JPN KB110 Coupe Rear Combination Lamp Part Numbers
* JPN PKB110 coupe rear combination lamp
* JPN VB110 Van Rear Combination Lamp Part Numbers
* JPN B120 -7308 Truck Rear Combination Lamp Part Numbers
27464.jpgAlbum 27464 27465.jpgAlbum 27465
Incandescent Miniature type 1034
  • 23/8.3 watt (1.8/.59 amp) 12.8/14 volt
  • 200 hours marker lamp (primary filament)
  • 5000 hours indicator lamp (secondary filament)
  • Base: S8 Double Contact Index Bayonet (BAY15d) Base
  • Sylvania 36111 161 lumens (402 lumens initial)
Can also use 27/8W type #1157. Higher wattage. Same brightness.
26718-26500
26718-26500 BULB (12V-30W) ICHIKOH
* 30W
* 白熱 [incandescent]
* S25Y yellow globe (25mm diameter glass)
* BA15s socket (15mm diameter base)
Fog Lamps OPTION
* JPN PB110 PB110_lights#Fog_Lights
* JPN 510 Fog Lamps
* JPN B210/PB210 (to 1973.12) B210 Fog Lamps
possible replacements (35W)
 bulb S25Y BA15s 35W
* KOITO 4519Y
* Stanley 26585819 35W
* Stanley A4580Y
* Stanley 501
* Toyota 90981-13026/90981-13026-76
26718-89906
26718-89906 BULB 12V-35W incandescent globe ICHIKOH $12 CAD
* supercedes 26713-34200/26713-34210
* 12V-35W
* Yellow globe
Fog Lamps OPTION
* 1965-1970 SP311 Datsun Fairlady 1600, SPL311 Sports 1600 (Datsun Roadster)
* 1967-1970 SR311 Datsun Fairlady 2000, SRL311 Sports 2000
* 1965-1968 Datsun 520
* 1969-1972 Datsun 521
27935.jpgAlbum 27935
26719-26500
26719-26500 BULB (12V-55W) ICHIKOH
  • 沃素 [iodine, a mini halogen bulb]
Fog Lamps OPTION
* 510 265 Grille /w Fog Lamps
* 510 Fender mount fog lamps
Koito 0454 halogen H3 bulb 55W
30295.jpgAlbum 30295
小糸(KOITO) 0454 バルブ ハロゲンフォグランプ用 [12V55W] クリアー [1個入り] H3平端子
28397.pngAlbum 28397
26750-25710
26750-25710 BULB (12V-55W) 2 KOITO
Fog Lamps OPTION
1156
VENDOR: RockAuto.com Product: 1156 Light Bulb
27 watt Type 1156
* can replace type 1073
1157
VENDOR: RockAuto.com Product: 1157 Light Bulb
27/8W Type 1157
* can replace Type #1034
* Same brightness as #26717-89920 (Type 1034)
* More heat generated
* More current used. Renew Fuse Box contacts
* 1200 hours marker lamp (primary filament)
* 3000 hours indicator lamp (secondary filament)
* 161 lumens (402/38 lumens initial)
16 cents to $3.11
Wagner 1157 $0.16
Philips 1157LL $0.88 long life 2-pack
Hella 1157
GE 1157
GE 1157NH Nighthawk 50% More Light (shorter life) $0.44
PHILIPS 1157CV CrystalVision 30% more light $3.27
LED version 100/330 lumens -- much brighter. A brand-new incandescent is brighter (402 lm), but quickly burns-in to the design lumens (161 lm).
PHILIPS 1157ALED Ultinon LED Amber $15.40
26730-S0115
26730-S0115
26730-S0115 BULB 12V-30W
* B210 Fog Lamps
* used into the 90s by some Nissan fog lamps
26736-89902
26736-89902 < 99990-S3175
Room Lamp Part Numbers
* USA B110
* JPN B110 except Truck, Van. Truck uses #26715-89900
* 510
10 watt (room lamp)
* Type SV8/5168 10 watt but is too long
  needs lamp contacts to be bent out
* Type SV7, ~29 mm long seems to fit best, but are usually 3w or 5w
  DE3022 5W 31mm
  6428 3W 29mm
* SV7-8 Festoon base (pointy ends)/ LES / SV7
Some parts stores specify the longer unit (Type #3175) which is readily available, but the Room Lamp socket must be bent slightly to fit.
20758.jpgRoom Lamp
3175
Dome lamp type 3175 is Longer version of Nissan #26736-89902 for Datsun 1200 Sedan & Coupe. It will fit if the Room Lamp sockets are bent slightly. Or in some cases the lamp ends can be ground down to fit. 31mm long.
VENDOR: RockAuto.com Product: Dome Light Bulb
DE3175 bulb
Less than $1 each
Wagner 12100
Philips/GE/Hella DE3175
LED $4 to $7
GE DE3175NH Nighthawk 50% More Light
  (higher color temperature)
PHILIPS 30MMLED VisionLED
PHILIPS DE3175WLED Ultinon LED
  6000K Bright White
Wagner 12100 (type DE3175)
174_5d9d18ca43bf4.jpgPost click for topic
Base: T3.25 10mm diameter
Base Type: SV8.5
Watt: 10
Length: 25mm
Overall length: 31mm
SuperBrightLeds DE3175 LED
174_5d9d188229539.jpgPost click for topic 174_5d9d188e59315.jpgPost click for topic 174_5d9d189b59acf.jpgPost click for topic 174_5d9d18bec8538.jpgPost click for topic
Color Temperature
The old-school incandescent light bulb is 2700K, a "soft white" color with a slightly yellowish glow. The color temperature over 5000 K are called "cool colors" (bluish), while lower color temperatures (2700–3000 K) are called "warm colors" (yellowish).
2700K–3000K Soft White (yellowish-white)
3500K–4100K Cool White (aka Bright White)
5000K–6500K Daylight (bluish-white)
Bright White is a whiter color that appears brighter even at the same lumens.
For interior room lamp (dome lamp), many prefer a warm color, so as to not overpower the eyes at night. By contrast, a map light needs to be brighter/bluer so that the map is clearly seen.
Brightness
We typically think of the brightness of a light bulb in wattage. However, wattage simply represents the amount of energy needed to use the bulb. The lumens scale indicates the brightness of a bulb — energyearth.com
This means a 35W incandescent bulb and a 35W LED bulb will have very different brightness. In fact the LED version of a 35W indicator bulb only uses about 4W.
The lumen (lm) is the SI derived unit of luminous flux, a measure of the total quantity of visible light emitted by a source. Luminous flux differs from power (radiant flux) in that radiant flux includes all electromagnetic waves emitted, while luminous flux is weighted according to a model of the human eye's sensitivity to various wavelengths.
