Mazda rotary engine swap
Revision as of 08:47, 18 December 2009; view current revision
Category: Engine Modifications
The Mazda rotary engine is a good match for Datsun 1200 -- it is light and compact. It makes more power than a piston engine of the same size and weight. The engine weight is down low so it doesn't interfere with good handling.
Performance
Typical engine power in stock form:
  • 12A: 100-130 HP, 100-115 lb. ft. torque
  • 13B EFI: 135 hp, 133 lb. ft. torque
  • 13B-Turbo (1987-1991 "Turbo II"): 185-200 HP
Quarter Mile acceleration performance ranges from quick to insanely quick. With a totally stock rotary engine you won't be wanting for power.
  • 19.8 secs at 65 mph: Stock Datsun 1200 piston engine (baseline)
  • 16.1 at 90mph: bone stock 12A rotary engine tuned by ear
  • Ange's 13.7 second 12A bridgeport
  • JVML's 8.1 second 13B twin turbo
Discussions
Engine
The Mazda rotary comes in two common sizes: 12A and 13B. In Australia, choose a 12A for street legal swaps. Everyone else, choose the 13B. There are less common versions, the old 10A and the ultra-rare and expensive 20B triple rotor.
8040.jpg 12A
158.jpg Mazda 13B carbureted
15021.jpg 13B Fuel Injected
93.jpg Mazda 13B Turbo rotary engine
2050.jpg Factory EFI 13B Turbo
3008.jpg 13B Turbo with factory intercooler
14572.jpg 20B triple rotor
Engine Mounts
Motor Plate
For racing a motor plate can be used. Not recommended for a street car as it transmit vibration directly to the body.
Transmission
Use the transmission that comes with the rotary engine (the Mazda transmission).
Driveshaft
A custom driveshaft to mate the Mazda transmission with your differential will have to be fabricated. Any driveshaft shop can make this for you.
Shifter
A new shifter mount hole may need to cut?
Transmission Mount
Tunnel
Some fabricate a large tunnel. Is it necessary, or just used with beefy racing transmissions?
Differential
The least 12A engine outputs 100 lb. ft. of torque. The stock Datsun 1200 H145 diff can handle that.
But many 12A put out 115 lb. ft. of torque, which calls for a stronger diff. The H150 from a B210 or B310 can handle this.
Stock 13B engine calls for an H165.
Any modified rotary (especially if the turbo boost is raised) will need a stronger differential, such as a Nissan H190. Drag racing versions need the ultra-strong Ford 9".
See: Rear Axle Swaps
93.jpg 158.jpg 383.jpg 581.jpg 912.jpg 959.jpg 965.jpg 1078.jpg 1384.jpg 1539.jpg 1540.jpg 1547.jpg 1549.jpg 1756.jpg 1757.jpg 1787.jpg 1788.jpg 1820.jpg 2049.jpg 2050.jpg 2065.jpg 2066.jpg 2067.jpg 2237.jpg 2558.jpg 2616.jpg 2681.jpg 2700.jpg 2701.jpg 2702.jpg 2703.jpg 2848.jpg 2914.jpg 2915.jpg 3008.jpg 3078.jpg 3427.jpg 3483.jpg 3548.jpg 3549.jpg 4484.jpg 4486.jpg 4655.jpg 4694.jpg 4949.jpg 5006.jpg 5448.jpg 5979.jpg 5980.jpg 6353.jpg 6757.jpg 7226.jpg 7374.jpg 7690.jpg 7697.jpg 7698.jpg 7699.jpg 7700.jpg 7703.jpg 7704.jpg 8040.jpg 8051.jpg 8320.jpg 8467.jpg 8469.jpg 8472.jpg 8555.jpg 8557.jpg 9422.jpg 9423.jpg 9501.jpg 9550.jpg 10801.jpg 11107.jpg 11246.jpg 11284.jpg 11285.jpg 12605.jpg 13279.jpg 13280.jpg 13837.jpg 13961.jpg 14572.jpg 14573.jpg 14574.jpg 15021.jpg 15028.jpg 15129.jpg 15141.jpg 15144.jpg 15356.jpg 15642.jpg 15696.jpg 16118.jpg 16120.jpg 16180.jpg 16373.jpg 17281.jpg 17292.jpg 17294.jpg 18150.jpg 18226.jpg 18344.jpg 18345.jpg 18692.jpg 18695.jpg 18818.jpg 18819.jpg 19867.jpg
