General specifications
Revision as of 10:50, 20 May 2021; view current revision
Category: Owner's Manual
General specifications for Datsun 1200 are listed here.
For other parts and systems use the search box at end of this page (below).
Template:OwnersManual2
Measurements
  • Wheelbase: 90.6 inch (2,300 mm) ALL, including truck
  • Overall length: 150.8 inch (3,830 mm) Sedan & Coupe
  • Overall width:
  • Overall height:
  • Track, front:
  • Track, rear:
  • Turning radius:
  • Ground clearance: 6.7 inch (170 mm) Sedan & Coupe
For more details, see: Measurements
Components
Capacities
Engine Specifications
  • Displacment:
  • Bore & Stroke:
  • Compression Ratio
    • 9.0:1 Japan, Australia
    • 9.0:1: 1971 Export
    • 10.0:1 A12GX Hi-gas
    • 9.5:1 ??? A12GX Lo-gas
    • 8.5:1: 1972 Export (e.g. North America)
    • 8.5:1: 1973 North America
      • Source: Service Bulletin 1974 Introduction of New Datsun B210 Series
  • Spark plugs firing order: 1-3-4-2 (same as most four-cylinder engines)
  • Dwell angle at idle:
  • Ignition Timing:
  • Idling speed:
  • Spark plug gap:
  • Distributor point gap:
  • Valve Clearance (hot):
  • Belt tension
