B10 Badges
Revision as of 00:22, 29 January 2025; view current revision
Category: Datsun B10
Japan Market
Although marketed and sold as a "Datsun", the 1000 did not come with any "Datsun" badges or emblems (for more details, see Datsun B10#Name).
Japan model sedan badges with Coupe round badge
6595_4cdf672dd169d.jpgUpload click to view
Deluxe Sedan badges with Coupe grille badge
174_5e2766cd7a045.jpgPost 493571
Front & Front Side badges
174_6114fdc358572.pngPost 495731
radiator grille #'S' ornament 1967
radiator grille #'S' ornament 1968-1970
fender/wing #'Sunny' badge
fender/wing #'Deluxe' badge
  • Sedan, light Van (wagon) and Truck (ute) all use the same front badges
  • Coupe badges differ
  • The grille badge changed from 1967 (vertical badge) to 1968-1970 (horizontal shield-shaped badge)
C-pillar badge
174_5d12f1eef3c46.jpgbrochure
Rear Badges
28534.pngAlbum 28534
Transmission Badge
Model & Trim
Sedan & Van
  • #63843-18225 EMBLEM-"deLuxe", front fender Deluxe [also Coupe]
Truck Only
30009.pngAlbum 30009
  • 96906-15401 LABEL-car name "Sunny"
  • #84235-18225 MARK-"deLuxe" Truck Deluxe [also Sedan, Van]
Coupe Only
KB10 came out in mid-1968, there was no 1967 coupe.
REAR
30011.jpgAlbum 30011
6 #84812-25725 KIT-ORNAMENT, trunk lid
7 #84823-18200 MARK-"Deluxe", trunk lid
8 #83845-18000 CLIP-tubular 2 (deluxe/GL) 3 (automatic)
  #84862-H0300 WASHER-sealing (fixing deluze mark)
9 #84824-20300 MARK-"Nissan full automatic", rear panel
- #84823-H1025 SET-MARK GL
Catalog
84812 trunk lid ornament [medallion]
-25725 118-2 coupe
84823 rear trim badge
-H1025  78-4 sedan 'GL'
       118-2 coupe
-18200 118-2 coupe 'Deluxe'
-18825  78-4 sedan 'Deluxe'
        97-4 van
       108-3 truck
84824 rear transmission badge
-20300  78-4 sedan 'Nissan full automatic'
       118-2 coupe
-27725  78-4 sedan 'Sports'
Export Models
Export Datsun 1000s, being sold by Datsun dealers instead of Sunny Shops, were badged "Datsun" instead of Sunny. However they still used the "S" emblems.
  • The SunnyCoupe badge does not appear to have been used on many export coupes, if any.
  • Exports coupes used 'DATSUN' instead of 'Sunny' badges
Rear Badge - Export coupes used the 'S' emblem, like this Australia coupe
22698.jpgAlbum 22698 18317.jpgAlbum 18317
Rear 'Sports' badge -- was it stock?
4585a.jpgAlbum click to view 4585.jpgAlbum click to view
  • BADGE-"D", radiator grille
    9465.jpgAlbum click to view 12313.jpgAlbum click to view 1263.jpgAlbum click to view
  • Different color badges?
    3418.jpgAlbum click to view
  • MARK-"DATSUN 1000"
    3541.jpgAlbum click to view 5833.jpgAlbum click to view 12807.jpgAlbum click to view
  • MARK-"DATSUN", front fender
    5834.jpgAlbum click to view 12313.jpgAlbum click to view 13237.jpgAlbum click to view
  • 84823-18200 Coupe Rear 'deLuxe'
    9724.jpgAlbum 9724
  • #63843-18225 EMBLEM-"deLuxe", front fender Deluxe [Same as sedan, coat-of-arms style]
    9998_4c89f162273ac.jpgUpload click to view
  • #62311-25725 'S' flag badge, radiator grille
Sedan/Van 'DATSUN 1000'
174_56c8f50cda87b.jpgUpload click to view 5833.jpgAlbum 5833
12807.jpgAlbum 12807 174_56c8f51da068a.jpgUpload click to view
Grille Badges
'D' Early Grille Badge
62311-18025 SET-EMBLEM, radiator grille
A narrow, vertically-oriented 'D' badge was used on early models -- both JDM and Export models.
  • sedan 1966-1967
  • light van (wagon) 1966-1967
  • 1968 Sunny Truck (B20) with aluminum 2-section grille
  • 1968 Australia Ute (which used the 1967 sedan grille)
Sedan/Van with the early aluminum-type 4-section grille
174_61150e80cb561.jpgPost click for topic 27295.jpgAlbum 27295
400px-1966_Datsun_Sunny_01.jpgWIKI go to Wikipedia
There are M4 nuts & washers fixing the emblem to the grille
quantity: 2 each
89-15434-1 WASHER-plain standard, M4
89-15134-1 WASHER-lock, M4
89-11104-1 NUT, low carbon steel (low grade strength/JIS 4T) M4 thread
174_611504c3008f9.jpgPost 495713 7266.jpgAlbum 7266
'S' Late Grille Badge
62311-27725 KIT-ORNAMENT, radiator grille 'S'
Sedan/Van 1968-1969
Truck 1968-1970
7076.jpgAlbum 7076 174_5c0a39be48c17.jpgPost 495722
about 11cm wide
174_611c313971457.jpgPost 495731 174_611c31b815883.jpgPost 495731 174_611c31c576bfb.jpgPost 495731 174_611c31d966b55.jpgPost 495731 174_611c3266586bb.jpgPost 495731 174_611c3266586bb.jpgPost 495731 174_611c3369070c0.jpgPost 495731 174_611c33757d5b9.jpgPost 495731
Fitted to B110 sedan
1231.jpgAlbum 1231
Flag Grille Badge
Radiator grille emblem ('S' flag badge in Datsun colors) — left side
62311-25725 KIT-ORNAMENT, radiator grille COUPE, SEDAN GL
174_5d37d9a0da06c.jpgPost 491962 174_5d37d9bc070f6.jpgPost 491962
174_5d00319f231f8.jpgbrochure 174_5d37d993ef2fe.jpgPost 491962
Export Coupe
s-COUPE.jpg 6644.jpgAlbum 6644
Grille badge
Option Badges
KB10 Sports Options
Car Badges (Sunny motorsport mark)
Safari Badge
Sunny * The 17th East African Safari Rally [1969]
174_611c206e9e17c.jpgPost 495729
Studs: M5 x 40mm
Bolt pattern: 2 on 36mm PCD
174_611c207dcdf8a.jpgPost click for topic 174_611c208915846.jpgPost click for topic
63843-18225
9998_4c89f162273ac.jpgUpload click to view 174_5e276923d0144.jpgPost click for topic
Sedan | Coupe
6635.jpgAlbum 6635 7781.jpgAlbum 7781
9986.jpgAlbum 9986 6643.jpgAlbum 6643 7073.jpgAlbum 7073
COUPE: 'deLuxe' and 'Sunny Coupe' front fender badges
2013ityou0461.jpg 28554.jpgAlbum 28554
63841-18025
63841-18025 EMBLEM-"Sunny", front fender
21314.jpgAlbum 21314 21313.jpgAlbum 21313 174_5e276954c3f1d.jpgPost 70243
4248.jpgAlbum 4248 8739.jpgAlbum 8739
63841-25700
63841-25700 BADGE-"Sunny coupe", front fender (red, white & blue Datsun Colors)
6985.jpgAlbum 6985 7781.jpgAlbum 7781 9116.jpgAlbum 9116
Coupe deLuxe
76831-H0225
76831-H0225 KIT-ORNAMENT, rear quarter pillar (from C/# B10-350001) (2) 4-door Deluxe
76831-H0225 'S' ornament [round]
* with smooth edge
* with fluted interior ring
compare to #84812-25725
* with reeded edge
* with 3-section interior ring
2090.jpgAlbum 2090
1969 4-door sedan Deluxe rear quarter pillar ornament
174_6137d99e01b7e.jpgPost 495819
174_613bdc3ad84e0.jpgPost 495830 174_613bdc1bb288e.jpgPost 495830 174_613bdc4632821.jpgPost 495830 174_613bdc5736f07.jpgPost 495830
174_613bdc67010a3.jpgPost 495830 174_613bdc7741980.jpgPost 495830
84812-25725
84812-25725 KIT-ORNAMENT, trunk lid Coupe [Round]
* with reeded edge
2090.jpgAlbum 2090
Compare to #76831-H0225 Sedan Pillar 'S' ornament [round]
* with smooth edge
2090.jpgAlbum 2090 6575.jpgAlbum 6575
4993.jpegAlbum 4993 174_667a3ce2d4a40.jpgPost 498529
84821-18025
84821-18025 EMBLEM-"Sunny 1000" [boot, right side]
Sedan
9987.jpgAlbum 9987
Van
15080.jpgAlbum 15080 16503.jpgAlbum 16503
84823-18200
84823-18200 MARK-"deLuxe" [coupe boot, right side]
25906.jpgAlbum 25906 4322.jpgAlbum 4322 9724.jpgAlbum 9724 174_667a3ce2d4a40.jpgPost 498529
84823-18225
84823-18225 MARK-"deLuxe" [sedan boot, right side]
9998_4c89f1748c25f.jpgUpload click to view
30010.jpgAlbum 30010 4238.jpgAlbum 4238
coupe or sedan?
174_5e27693fcf1f5.jpgPost 70243
search: サニー1000デラックスエンブレム Sunny 1000 Deluxe emblem
84823-H0125
84823-H0125 SET-MARK "GL"
* Coupe GL
* Sedan GL
27968.jpgAlbum 27968 B1016ppcover.jpgKB10 brochure
or
27886.jpgKB10 brochure
174_677edfa6a79c2.jpgPost 498705 174_677edfae6c9bd.jpgPost 498705 174_677edfb72ab55.jpgPost 498705
84824-27725
84824-27725 KIT-MARK-"SPORTS" Sedan 4-speed
* Sedan boot lid, left side
* 3-speed models carried no badge
COMPARE to Datsun 1200 'Sports' badge
20865.jpgAlbum 20865
21315.jpgAlbum 21315 174_5d0c810c54f69.jpgPost 491752 4237.jpgAlbum 4237
84824-20300
MARK 'NISSAN Full Automatic'
27850.jpgAlbum 27850
Sedan | Coupe
21974.jpgAlbum 21974 27851.jpgAlbum 27851
