Instruments and Controls
Revision as of 08:34, 6 November 2012; view current revision
Category: Body
1972 USA Owners manual (starting page 8):
Selt Belt Warning Light/Buzzer
1972 USA Owners manual (page 9):
See main article: Seat belts
Clock
See main article: Clock
Speedometer
See main article: Speedometer
Tachometer
Tachometer was optional.
See main article: Tachometer
Water Temperature Gauge
th_10.jpg 1972 USA Owners manual
If the pointer stays on the "H" side for more than two minutes, stop the vehicle and let the engine cool down, keeping it at 1,000 to 1,500 rpm.
By "H" they mean out of the large middle range (way over to right-side -- the H area).
Also see: Thermostat or Temperature Gauge
Fuel Gauge
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill.
Stock Fuel level gauge, ss measured by club members:
  • Empty mark: 73-88 ohms input
  • Full mark: 12 ohms
ang94541 uses an aftermarket Autometer 3515, which does doesn't match the Nissan sender except at the empty mark. It is designed for the unusual Ford senders.
  • 3515 Empty mark: 73 ohms
  • 3515 Full mark: 10 ohms
Reference: Forum: Fuel sending unit specs
Also see: Fuel tank (includes Fuel Sender specs)
Indicator/Warning Lights
Also see: Wiring
Ignition Warning Light
Oil Pressure Warning Light
Headlight Beam Indicator Light
Brake System Warning Light
Turn Signal Indicator Lights
Switches
Also see: Wiring
Ignition Switch
1972 USA Owners manual (page 11):
Also see: Keys
Light Switches
See: Lighting Switch
Light Switch
Turn Signal Switch and High Beam Switch Lever
Hazard Warning Switch
th_12.jpg 1972 USA Owners manual
...first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
Light switch operation differs between Australia models and other markets. Turn Signal operation (T/S) is the same?
Wiper and Washer Switch
To operate the washer, turn clockwise and hold the knob for a moment, or until there is enough fluid on the glass to wash off the dirt. Do not operate the washer for more than thirty seconds continuously.
Horn
Just press the button to sound the Horn.
th_13.jpg 1972 USA Owners manual
Parking Brake Lever
If the ignition switch is on when the parking brake lever is applied, the brake warning light will glow.
Heat Glass Switch
Optional equipment.
