1972 USA Owners manual (starting page 8):
Selt Belt Warning Light/Buzzer
1972 USA Owners manual (page 9):
See main article: Seat belts
Clock
See main article: Clock
Speedometer
See main article: Speedometer
Tachometer
Tachometer was optional.
See main article: Tachometer
Water Temperature Gauge
Also see: Thermostat or Temperature Gauge
Fuel Gauge
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill.
From the 1973 Datsun 1200 Factory Service Manual.
Ohms Mark 35 Half
Stock Fuel level gauge, ss measured by club members:
- Empty mark: 73-88 ohms input
- Full mark: 12 ohms
ang94541 uses an aftermarket Autometer 3515, which does doesn't match the Nissan sender except at the empty mark. It is designed for the unusual Ford senders.
- 3515 Empty mark: 73 ohms
- 3515 Full mark: 10 ohms
Reference: Forum: Fuel sending unit specs
Also see: Fuel tank (includes Fuel Sender specs)
Indicator/Warning Lights
Also see: Wiring
Ignition Warning Light
Oil Pressure Warning Light
Headlight Beam Indicator Light
Brake System Warning Light
Turn Signal Indicator Lights
Switches
Also see: Wiring
Ignition Switch
1972 USA Owners manual (page 11):
Also see: Keys
Light Switches
See: Lighting Switch
Light Switch
When you pull the switch knob to the first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
At the second position, the parking lights are still on and the headlight beams are lit, then if you push the turn signal lever switch forward, the headlight high beams will be turned on ... Pull the lever toward you, and it will be changed over to low beam.
B120 1974 Export owner's manual LIGHT SWITCH
The light switch clearance lights, parking lights, headlights, taillights, license plate light and instrument panel lights.![]()
With the light switch knob pulled on, the following lights will be on.1st position:
Clearance, parking, tail, license, instrument panel lights and then headlight low beams.
With the turn signal switch lever pulled up, the headlight low beams can be turned on.2nd position:
Turning the knob clockwise will darken the instrument panel lights.
Headlights and other lights
If you push the turn signal switch lever forward, the headlight high beams will be turned on.
INSTRUMENT PANEL LIGHT CONTROL (For Australia only)
The instrument panel light control is integral with light switch. The brightness of instrument panel lights can be adjusted by turn the light switch knob.(Australia only)
Turn Signal Switch and High Beam Switch Lever
Hazard Warning Switch
...first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
Light switch operation differs between Australia models and other markets. Turn Signal operation (T/S) is the same?
Wiper and Washer Switch
Horn
Just press the button to sound the Horn.
Parking Brake Lever
If the ignition switch is on when the parking brake lever is applied, the brake warning light will glow.
Heat Glass Switch
Optional equipment.
(Australia only)
