Datsun 1200s came with two brake systems: all drums (Standard models), or Girling-Tokico front disc with rear drums. They were excellent brakes for the period. All are manually adjusting except non-North America Left-hand drive 1200s, which were equipped with auto-adjusting rear drum brakes.
Also see: * Rear Brakes * Brake Swaps * Brake Upgrades * Brake Adjustment
Daily Care
- Leakage and amount of fluid in brake and clutch master cylinders
- Clutch and brake operation
Observe the level of fluid visible through the plastic reservoir of the master cylinder (no need to remove the cap).
- If it is at or below the fill line, top up with DOT 3 Brake/Clutch fluid.
Types
- Drum front/drum rear - Standard trim, Deluxe trim
- Disc front/drum rear - GL, GX and optional on Deluxe
The 1200 front-disc/rear-drum system was good for 1971. In fact, stopping power was better than most 'muscle cars' of the era. However, if you have a drum/drum system, you'll want to upgrade to disc/drum. The drum system stops well enough, but the disc system has less fading going down mountain roads.
1200 disc brakes, ready for new pads to be fitted
Adjustment/Maintenance
See: * Drum Brake Adjustment * Disc brakes need no adjustment
Replacing Rotors
The brake rotor bolts to the hub on disc brake models. It is retained by four bolts to the hub. A press is not required as the joint is not an interference fit.
After removing the hub from the strut, unbolt the four rotor-retaining bolts. If the rotor does not separate easily, get 2 house bricks and place them on concrete end up. Place the disc/hub between the bricks wheel face down with the rotor face on the bricks. Using a hammer strike the inner wheel bearing seal carrier area lightly moving around its full circumference. This should loosen the joint.
- Remove the front Wheel in question
- Using a screwdriver, carefully pry the brake pads away from the rotor a little bit
- Using a length of twine or wire, tie the caliper to the spring, so that it won't fall when the caliper is unbolted
- Unbolt the caliper, and lift up and away from the rotor
- Tap the grease cap off, and remove the large spindle retaining nut
- Pull the hub & rotor straight off
To replace the hub after bolting on the new rotor, see Wheel bearings.
Calipers
Calipers are used with disc brakes. Datsun B110, B210 and B310 used floating two-piston ANETTE types. These were designed by Lucas Girling whicg designed the Anette, Babette and Colette series.
1969 Annette: Fixed twin-piston with floating caliper (yoke type), as used by B110/B210/B310 1974 Colette: Single-sided (fist type) floating caliper as used by S13
Type B110: ANNET 12/14A (1.894" cylinder inner diameter) B310 small: AN-18 (1.894" cylinder inner diameter) B310 large: Disc-AN20 (2.012" cylinder inner diameter)
Caliper bolt spacing: 84 mm: B110 * and all 12" wheel B210 and B310 88.9 mm: B310 large struts for 13" wheels
Sliding surfaces
full
Anette caliper
full
Caliper breakdown
full
1 Clip (original type instead of cotter pins) 2 Springs 3 Clevis Pins, pad-retaining 4 Shim, anti-rattle 5 Hanger spring (anti-rattle Clip) 6 Brake pads 7 Air bleeder 8 Retaining ring 9 Boot, dust 10 Piston B 11 Cylinder block (caliper body) 12 Piston A 13 Bias spring (plastic block) 14 Yoke spring 15 Yoke (caliper plate)
Rotor Sizes
Dia. (mm) | Part Number | Source |
208 | 40207-G1501 | Sunny Truck 8910- |
212.5 | 40206-H1006 | B110, B210 A12 1974-1975 |
220 (AN18) | 40206-H7500 | B210 A12 1976-1978, B310 with 12" wheels |
245 (AN20) | 40206-U6700 | A10, B210 A14, 1976-1978 120Y, B310 w/13" wheels, GB211 |
219 (220) | 1976-1978 120Y Australia-assembled (same spec as JDM B210) | |
? (Girlock) | ? | A10, Australia-assembled |
Brake Lines
See main article: Brake Lines
Front Drum Brakes
1200 DX and STD trim received front drum brakes (GL and GX were fitted with Disc Brakes). It uses two cylinders, unlike the rear drums which have one cylinder.
* Wheel cylinders: 13/16 inch bore diameter
Rear Drum Brakes
See Rear Brakes
brake cylinders | B110 (disc) | 1977 US B210 | 1980 US B310 (Disc-AN20) | 1980 Canada A12A (Disc-AN18) |
Proportioning valve | not used | yes | 1,961 kPa x 0.4 psi | 1,961 kPa x 0.4 psi |
Booster (Master-Vac) | not used | ? | M60 6-in diameter 135mm rod length (flange-to-pedal) | M60 6-in diameter |
Master diameter | 11/16 inch | 3/4 inch | 13/16 | 13/16 |
Front cylinder diameter | 1.894 inch (drum brakes: 11/16) | 2.012 inch | 2.012 inch | 1.894 inch |
Rotor diameter | 212.5 mm | 245mm | 245mm | 220mm |
Pad (width x length) | 42.5 x 53.1 mm | 41.2 x 63.4 mm | 41.2 x 61.4 mm | 42.0 x 56.8 mm |
Pad thickness | 10.3 | 10.0 | 10.0 | 10.3 |
Total front braking area (discs) | 14.0 sq in | 16.2 sq in | ~14.6 | ~13.8 |
Total front braking area (drums) | 42.3 sq in | n/a | n/a | n/a |
Rear cylinder diameter | disc brake models: 11/16 inch (all-drum models: 13/16) | 13/16 inch | 13/16 | 13/16 |
Drum diameter | 8.0 inch | 8.0 inch | 8.0 | 8.0 |
Drum width | 1.378 inch | 1.378 inch | 1.378 | 1.378 |
Total rear braking area | 42.3 sq in | 42.3 sq in | 42.3 | 42.3 |
ブレーキ
Brake Pedal Switch
25320-H1000 -8109 * Beck/Arnley 201-0288 ** 1987-1988 Dodge Colt ** 1990 Mitsubishi Sigma ** 1985 Mitsubishi Starion ** 1967 Toyota Corona ** Datsun B110/B210/F10/N10/S10, 1974-1978 S30, A10, 620, 810, 910 25320-H8500 8110-
25320-75A00 8910-![]()
Front Brake Cylinder
41100-18000 ASS'Y-CYLINDER, front wheel, fore (R.H.) B10, B110 STD,DX 41102-18000 ASS'Y-CYLINDER, front wheel, fore (L.H.) B10, B110 STD,DX 41101-H1000 CYLINDER ASS'Y, front wheel, after (R.H.) B110 STD,DX
41103-H1000 CYLINDER ASS'Y, front wheel, after (L.H.) B110 STD,DX![]()
Seiken 41101-27700 ASS'Y-CYLINDER, front wheel, after (R.H.) B10 superceded 41101-18000 ASS'Y-CYLINDER, front wheel, after (R.H.) B10 41103-27700 ASS'Y-CYLINDER, front wheel, after (L.H.) B10 superceded 41103-18000 ASS'Y-CYLINDER, front wheel, after (L.H.) B10
Meisan (n & n)
B10 front & rear brake cylinders
フロント ホイール シリンダー
Brake Hoses
See main article: Brake Hoses
Pads
See Brake Pads
Rotor
B110 212 mm Nissan 40206-H1006 BENDIX 561060B Brembo 08.2459.10Centric 120.42000 * Type: behind the hub * Outer diameter: 212 mm * Height: 35.6 mm * Nominal thickness: 9.5 mm * Minumum thickness: 8.6 mm * Hub Reg: 70 mm * Bolt size: 10 x 1.5 mm * Bolt circle: 4 x 87 mm * center hole: 70 mm * Weight 5.9 - 6.1 pounds
B210 220 mm 12" wheel (including 120Y, 140Y, 150Y and CANADA B310.A12A) Nissan 40206-H7500 DBA 310 * Outer diameter: 219/220 mm * Height: 35.6 mm * Nominal thickness: 9.6 mm * Minumum thickness: * Hub Reg: 70 mm * Bolt size: * Bolt circle: 87 mm * center hole: 70 mm * weight: 2.7 kg
B310/A10/HB210/S10/160J/120A 245 mm for 13" wheel vehicles Nissan 40206-U6700 also fits 910.L18/L16 DBA 307 BREMBO 08.3955.10 Height: 35.5 mm Thickness: 10 mm Thinness: 8.4 mm Hub reg: 73 mm Bolt pattern: 4 x 95 PCD (bolts to hub) weight: 8.56 lb * Centric 121.42002![]()
Wheel Bearings
See Wheel bearings
Rear Wheel Bearings
See Axle Shaft. These are not easily replaced.
Caliper
Bore Size 1.89" Inlet Thread M10 x 1.0 Bleeder Thread M10 x 1.0
Right: RAYBESTOS FRC3021 $30.79, RC3021 A-1 CARDONE 19124, 17124
Left: RAYBESTOS FRC3022 $30.79, RC3022 A-1 CARDONE 19125, 17125
41214-H1007 RING-BIAS Girling 29-1007 or 67932343full
Caliper piston centering bias ring for indirect piston. Fit inside the front Disk Brake Pistons (inner side). Tang of Yoke fits into ring.
Parking Brake
See Hand Brake
Master Cylinder
See Brake Master Cylinder
Hardware Kit
When changing the brake pads, the old hardware can usually be re-used. But if the anti-squeal shims are missing or the springs damage, new ones can be purchased.
A disc brake "hardware kit" includes all the small parts (although individual parts are also available at parts stores).
* BENDIX H5564 * EIS H155242 * RAYBESTOS H155242 (dual kit) * RAYBESTOS H15524 (single kit) * LEE MANUFACTURING 15524 * KELSEY-HAYES HK956 * WAGNER F96607 * CARLSON 13114 * CENTRIC 11742027 * DORMAN HW13114
Some kits are dual (does both front brakes) other kits you need two of them.
The Wagner kit additionally includes new yoke springs, so you don't have to clean the old ones to make sure the Yoke (caliper plate) slides smoothly.
Nissan small hardware parts * fits B110 and 120Y with Japan caliper 41040-H1005 SPRING-yoke (2) 41041-H1005 SPRING-yoke (2) 41084-H1005 SHIM [anti-squeal] (4) <> 41084-M6800 41080-H1005 SPRING-hanger [anti-rattle clip] (4) 41217-28500 PIN [retaining pads] (4) 41206-H1005 SPRING-coil [for pins] (4) 41049-H1005 CLIP [retaining wire for pins] (2)
B210 Japan front brake caliper(rh) strut rotor pad 41000-H1007 H50 212mm 41060-H1006 EARLY B210.(GL+GX) 41020-H7450 H74 220mm 41060-M3226 7608- B210.A12S.DX+V > 41020-10832 41000-H7501 " " " B210.A14+A12S.GL 41000-H7800 " " 41060-H7825 7607- B210.VH=PT [van 1400 super-deluxe] 41000-S0100 H59 A1100 41060-H7926 B210.L14 H75 245mm " 7510- B210.L14.some? 41000-H8000 H59 245mm " B210.L16S [D864P pad]
120Y
A12-powered B210 uses small suspension similar to 1200.
1974-1975: used the same brakes as Datsun 1200 (212 mm disc) 1976-1978: AUS changed to larger 220 mm rotors EUR continued with 212 mm rotors
NOTE: 120Y for Germany, Switzerland and Austria uses large suspension like USA B210. Possibly all LHD B210?
Australian-assembled late 120Y used a locally sourced PBR caliper, using a adapter plate:
PBR disc brake pad ADB1025 (Bendix DB1025) CHRYSLER Sigma GE (EXC SCORPION) PBR CALIPER 1978-1980 MITSUBISHI Sigma GE PBR Front Disc & Girlock Rear Drum 1978-1980 NISSAN 120Y Sedan P.B.R Front Disc 1977-1979![]()
PBR
B120
Front Disk Brakes from 8910. These are unique as they fit the same strut as the former drum brake setup.
Rear Drum Brake
See Rear Brakes
Master Cylinder
Master cylinder has two bolts in horizontal plane; previous drum brake system used two bolts in vertical plane (like B110).
Front Discs
Sunny Truck staring in October 1989 has a disc brake system similar to B11/N12.
See main article: Sunny Truck Disc Brakes
Nissan Competition
Nismo Catalogfor race, rally 41060-H1020 Ass'y pad Front Brake DS11 41060-H1021 Ass'y pad Front Brake M59 44060-27720 Ass'y-Shoe Rear Fore (B10 op.) 44070-27720 Ass'y-Shoe Rear After AM4 (B10 op.) 44100-H2320 CYL ASSY RR Wheel 5/8"
44060-A1260 SHOE ASSY-Brake Fore for LT20 Drum, Ferode AM4 44060-A1270 SHOE ASSY-Brake After for LT20 Drum, Ferode AM4 44100-M7000 CYL ASSY-Wheel 5/8" LT20 Selective Use, N10 standard 44100-M4901 CYL ASSY-Wheel 11/16" LT20 Selective Use 44100-G2800 CYL ASSY-Wheel 1/4" LT20 Selective Use 44100-U9200 CYL ASSY-Wheel 13/16" LT20 Selective Use
1984 Nissan Competition99996-H7010 1200, F10 & 310/N10 DP11 BRAKE PAD SET 44060-27720 BRAKE SHOE/FORE for 1200 and early B210 44070-27720 BRAKE SHOE AFT for 1200 and early B210 44100-H3320 5/8" WHEEL CYLINDER for 1200 and early B210 44100-H3300 11/16" WHEEL CYLINDER for 1200 and early B210 44100-H3100 13/16" WHEEL CYLINDER for 1200 and early B210
