Thermostat Housing
Revision as of 11:35, 1 August 2018; view current revision
Category: Cooling System
Nissan calls the housing for the thermostat the "Water Outlet".
[hide]
B110
11062-18000 GASKET-WATER OUTLET
11060-G0300 OUTLET-WATER
11060-H7000 OUTLET-WATER USA MANUAL from 0373
G03 | H70
11060-G0300.jpg 21294.jpgAlbum 21294
A-engine Variations
There are a number of different types of water outlets for A-series engines.
19554.jpgAlbum 19554
Gasket Types (2-bolt, 3-bolt, 4-bolt)
45-degree outlet | 90-degree outlet
3-bolt and 4-bolt types have accessory bolt bosses
* 2-bolt Type -- as used by early engines, and some late engines
* 3-bolt Type -- newer engines, with extra mounting bosses
* 4-bolt Type -- newer engines, notably those with Air Passage
4-bolt Type | Air Passage (red arrow)
15172.jpgAlbum 15172 25820.jpgAlbum 25820
A most important difference is whether it fits over the Air Passage in some cylinders heads.
It further breaks down:
* 2-bolt Type -- as used by Datsun 1200
  * B10/B110 Type, outlet points 180 degrees
  * Late B110 USA -- with boss for thermo switch
  * B210/B310 Type-Outlet points 225 degrees
* 3-bolt Type
  * with accessory mounting bosses
* 4-bolt Type -- as used by some newer engines
  * with accessory mounting bosses and Air fitting
  * with accessory mounting bosses (forward) and Air fitting
15159.jpgAlbum 15159
Head Mating Surface
Starting with the 1973/974 A Engine Redesign, all A-series cylinder heads featured an alternator placed on the right side of engine. This in turn necessitated adding a bolt hole to the front face of the head next to the water outlet (the hole is for the alternator mounting tension bracket).
3265.jpgAlbum 3265
This means the water outlet was rotated up so as to not cover the bolt. This in turn means the radiator hose location is different, even though the first year B210 radiator is otherwise nearly identical to the B110.
1974-up engine w/bolt hole | 1966-1973 w/o alternator bolt hole
23099.jpgAlbum 23099 23096.jpgAlbum 23096
Head Mating Surface: 1974-up engine with Air passage | Adapter covers a hole, allowing old-style housing
15160.jpgAlbum 15160 23098.jpgAlbum 23098
Housing Part Numbers
NOTES:
  • CAL = California
  • CAN = Canada
  • FED = USA, except California
  • GFU = 5-speed Round-port A14 engine
  • JDM = Japan Domestic Market
  • Gasket is also called "WASHER-JOINT WATER OUTLET"
The 4-bolt gasket works on a 2-bolt housing.
2-bolt Type
The 2-bolt type is used by B10 and B110. It is also used by B210/B310 engines that do not have an Air Injection passage in the cylinder head.
2-bolt Type Thermostat housings attaches radiator hose at:
* B110: 9:00 o'clock (180 degrees)
  7766.jpgAlbum 7766
* B10/B210/B310: 10:30 o'clock (225 degrees) to clear belt
  of high-mounted alternator
  8091.jpgAlbum 8091
7:30 Outlet
It points straight to the side when installed.
11060-G0300 OUTLET-WATER B110
* also used on JDM C20 "Sunny Cab" with A10 engine
B110 housing and original fittings
15170.jpgAlbum 15170
Aftermarket
KILKENNY CASTINGS WO27
* suits 11060-G0300
WO27 (not WO27A)
KILKENNY CASTINGS WO27A (QWO27, MPO27 etc)
27111.jpgAlbum 27111 27110.jpgAlbum 27110 27109.jpgAlbum 27109
#11060-H7000 OUTLET-WATER B110 MANUAL from 0373 USA
9:00 Outlet
B10 & B210 - outlet points slightly up when installed
11060-18000 OUTLET-WATER B10
11062-H7201 GASKET-WATER OUTLET
* 11060-H5000 OUTLET-WATER B210 A13 USA 1974, A12 JDM early
* 11060-H5000 OUTLET-WATER B310 A12,A13,A14,A15 JDM 8011-
* 11060-H5000 OUTLET-WATER B120 A12 -8910
* 11060-H5000 OUTLET-WATER B310 A12A CAL from 0879
* 11060-H5000 B310 JDM
  -8109 VAN
  7901-8010 A12S.S,K+14.V
  8011- ALL
You can see how on newer engines, the alternator bracket bolts next to the outlet. This requires the outlet at 45 degrees up so the bolt is uncovered.
3265.jpgAlbum 3265
Late B120
11060-G2500 OUTLET-WATER B120 A12 8910-
* 11062-H7201 GASKET-WATER OUTLET -9202
* 11062-18000 GASKET-WATER OUTLET 9202-
11060-H7000
Late 1973 USA has a threaded boss for a water temperature switch.
11060-H7000 OUTLET-WATER B110 USA MANUAL from 0373
* Has boss for temp switch
* 22120-U2001 ASSY-SWITCH WATER TEMP from 0373
  same switch used by:
  * L16-powered 620 USA for EGR
  * 1973 510
Everco part number W2499 similar but is heavy cast iron (all factory housing are light alloy, so this is incorrect material)
The purpose of the late 1973 water temp switch is unknown, but it might replace the ambient air temp switch of the TCVAS system. In other Datsun models it was used to disable EGR, including PB110 L14 engine (in thermostat housing) and EGI A14E engine (in EGR adapter on intake manifold). On the 1974 L18-powered 620, it was activated at 120 degrees, so it is the wrong temp to be used to control a radiator fan.
15164.jpgAlbum 15164
FWD
11060-M0100 E10 Cherry 2-bolt with accessories boss A10,A12
3-bolt Type
11062-M3001 GASKET-WATER OUTLET
* can use 4-bolt gasket
11062-M3001.jpg 27112.jpgAlbum 27112
The 3-bolt water outlet was used in newer engines that do not have an air port in the front of the cylinder head -- and that do not have the alternator bracket bolted to the front of the head. In this case, the outlet can exit more to the side, even covering the high bolt hole.
5-bolt Head Face, adds right-side low Alternator Mounting
23095.jpgAlbum 23095
15171.jpgAlbum 15171
11060-M3001 OUTLET-WATER
* B310 JDM -7812 A12 S,K; A14 V
* B310 FED A14,A15
* B310 AUS A14 Wagon
11060-M3010
* N10 JDM A12,A14
Aftermarket:
KILKENNY CASTINGS WO92 (THO-60, QTH etc)
3-bolt type fastening housing to head. With two accessories bosses pointing up
25735.jpgAlbum 25735
6509.jpgAlbum 6509 6510.jpgAlbum 6510 6511.jpgAlbum 6511 3464.jpgAlbum 3464 80.JPGAlbum 80
4-bolt Type
All engines with Air passage in the cylinder head require a 4-bolt housing and gasket. Some newer engines without Air system also use the 4-bolt kit.
4-bolt
15161.jpgAlbum 15161
Smog Pump Type - bosses up
6226.jpgAlbum 6226
11060-H7201 OUTLET-WATER B210 A14 USA
11060-H7400 OUTLET-WATER
* B210 A14 FED GFU from 1276
* B210 A12 JDM late, A14
* F10 A14 USA
* A10 JDM A14S.S,K -7803
H74 1977 B210 Coupe A14 5-speed GFU
Air Induction Type - 1 Boss Forward, 1 boss up
6357.jpgAlbum 6357 25953.jpgAlbum 25953
11060-H9100 OUTLET-WATER B310 A14,A15 CAL,CAN
* 11062-H7201 GASKET-WATER OUTLET  B310 A14,A15 CAL,CAN
11060-H9100 OUTLET-WATER B310 A12A from 1278
* 11062-H7201 GASKET-WATER OUTLET A12A CAN from 1278
* 11062-M3001 GASKET-WATER OUTLET A12A FED from 0879
509.jpgAlbum 509 3149.jpgAlbum 3149 1874.jpgAlbum 1874 606.jpgAlbum 606
A14/A15 high angle
776.jpgAlbum 776 6191.jpgAlbum 6191
Thermo Switch Housing
1048.jpgAlbum 1048
Late, Accessory bracket type
2495.jpgAlbum 2495 3702.jpgAlbum 3702
