Japan Market
Although marketed and sold as a "Datsun", the 1000 did not come with any "Datsun" badges or emblems, instead stressing the 'Sunny' name (for more details, see B10 Name).
Japan model sedan badges with Coupe round badge
Deluxe Sedan badges with Coupe grille badge
Transmission Badge
- #84824-27725 EMBLEM-"Sports" (4-speed)
- #84824-20300 MARK-"NISSAN Full Automatic" Sedan/Coupe
Model & Trim
- #84821-18025 EMBLEM-"Sunny 1000" [boot, right side sedan/van]
- #84823-18225 MARK-"deLuxe" [boot, right side]
Sedan & Van
Front & Front Side badges
radiator grille #'S' ornament 1967 radiator grille #'S' ornament 1968-1970 fender/wing #'Sunny' badge fender/wing #'Deluxe' badge
- Sedan, light Van (wagon) and Truck (ute) all use the same front badges
- Coupe badges differ
- The grille badge changed from 1967 (vertical badge) to 1968-1970 (horizontal shield-shaped badge)
- #62311-18025 SET-EMBLEM, radiator grille ["D"]
- #62311-27725 KIT-ORNAMENT, radiator grille (from C/# VB10-066701) ["S"]
- #63841-18025 EMBLEM-"Sunny", front fender
- #63843-18225 EMBLEM-"deLuxe", front fender Deluxe
Rear Badges
- 22 #84821-18025 EMBLEM-"Sunny 1000" [boot, right side sedan/van]
- 24 #84823-18225 MARK-"deLuxe" [boot, right side]
- 25 #84824-27725 KIT-MARK-"SPORTS" Sedan 4-speed [boot lid, left side]
- 26 #84824-20300 MARK-"NISSAN Full Automatic" Sedan A-all [boot lid, left side]
- -- #84823-H1025 SET-MARK, "GL" (listed as H0125 in catalog, and H1025 in #catalog index)
Truck
- 96906-15401 LABEL-car name "Sunny"
- #84235-18225 MARK-"deLuxe" Truck Deluxe [also Sedan, Van]
Coupe
KB10 came out in mid-1968, there was no 1967 coupe.
FRONT & SIDE
4 #62311-25725 KIT-ORNAMENT, radiator grille
5 62312-25700 BRACKET 6 89-15134-1 WASHER-lock 7 89-11104-1 NUT 42 #63841-25700 BADGE-"Sunny coupe", front fender 2
43 #63845-18000 CLIP-tubular 4 44 #63843-18200 BADGE "Deluxe", front fender 2 [similar to sedan, coat-of-arms style]
45 #63845-18000 CLIP-tubular 4 - #Option Badges
REAR
6 #84812-25725 KIT-ORNAMENT, trunk lid [Round with reeded edges]
7 #84823-18200 MARK-"Deluxe", trunk lid [boot, right side]
8 #83845-18000 CLIP-tubular 2 (deluxe/GL) 3 (automatic) #84862-H0300 WASHER-sealing (fixing deluze mark) 9 #84824-20300 MARK-"Nissan full automatic", [rear panel, center] [same badge as sedan]
- #84823-H1025 SET-MARK GL
Catalog
84812 trunk lid ornament [medallion] -25725 118-2 coupe
84823 rear trim badge
-H1025 78-4 sedan 'GL'
118-2 coupe
-18200 118-2 coupe 'Deluxe'
-18825 78-4 sedan 'Deluxe'
97-4 van
108-3 truck
84824 rear transmission badge
-20300 78-4 sedan 'Nissan full automatic'
118-2 coupe
-27725 78-4 sedan 'Sports'
Export Models
Export Datsun 1000s, being sold by Datsun dealers instead of Sunny Shops, were badged "Datsun" instead of Sunny. However they still used the "S" emblems.
- The SunnyCoupe badge does not appear to have been used on many export coupes, if any.
- Exports coupes used 'DATSUN' instead of 'Sunny' badges
Rear Badge - Export coupes used the 'S' emblem, like this Australia coupe
Rear 'Sports' badge -- was it stock?
- BADGE-"D", radiator grille
- Different color badges?
- MARK-"DATSUN 1000"
- MARK-"DATSUN", front fender
- 84823-18200 Coupe Rear 'deLuxe'
- #63843-18225 EMBLEM-"deLuxe", front fender Deluxe [Same as sedan, coat-of-arms style]
- #62311-25725 'S' flag badge, radiator grille
Grille Badges
'D' Early Grille Badge
A narrow, vertically-oriented 'D' badge was used on early models -- both JDM and Export models.
- sedan 1966-1967
- light van (wagon) 1966-1967
- 1968 Sunny Truck (B20) with aluminum 2-section grille
- 1968 Australia Ute (which used the 1967 sedan grille)
Sedan/Van with the early aluminum-type 4-section grille
There are M4 nuts & washers fixing the emblem to the grille
quantity: 2 each 89-15434-1 WASHER-plain standard, M4 89-15134-1 WASHER-lock, M4 89-11104-1 NUT, low carbon steel (low grade strength/JIS 4T) M4 thread
'S' Late Grille Badge
62311-27725 KIT-ORNAMENT, radiator grille 'S' Sedan/Van 1968-1969 Truck 1968-1970
Flag Grille Badge
Radiator grille emblem ('S' flag badge in Datsun colors) — left side
62311-25725 KIT-ORNAMENT, radiator grille COUPE 62312-25700 BRACKET 89-15134-1 WASHER-lock 89-11104-1 NUT
Option Badges
Car Badges (Sunny motorsport mark)
Safari Badge
Sunny * The 17th East African Safari Rally [1969]
Studs: M5 x 40mm Bolt pattern: 2 on 36mm PCD
63843-18225
COUPE: 'deLuxe' and 'Sunny Coupe' front fender badges
63841-18025
- Sedan
- Van
- Truck
- but not Coupe which used #'Sunny coupe' badges
63841-25700
63841-25700 BADGE-"Sunny coupe", front fender (red, white & blue Datsun Colors)
76831-H0225
76831-H0225 KIT-ORNAMENT ['S' round medallion], rear quarter pillar (from C/# B10-350001) (2) 4-door Deluxe
76831-H0225 'S' ornament [round, originally purple]
* with smooth edge
* with fluted interior ring
compare to #84812-25725 coupe rear badge * with reeded edge * with 3-section interior ring![]()
1969 4-door sedan Deluxe rear quarter pillar ornament
Color has faded away over time
Purple (紫 murasaki) is seen as a sign of wealth and prestige in Japan, associated with royalty and luxury (deluxe) things
83845-18000
83845-18000ᴳ CLIP-tubular 2 (fitting badges ) 2 or 3 per badge
84812-25725
84812-25725 KIT-ORNAMENT, trunk lid Coupe [Round]
* with reeded edge
Compare to #76831-H0225 Sedan Pillar 'S' ornament [round] * with smooth edge * with fluted interior ring![]()
84821-18025
84821-18025 EMBLEM-"Sunny 1000" [boot, right side]
84823-18200
84823-18200 MARK-"deLuxe" [coupe boot, right side]
- differs from sedan #84823-18225
84823-18225
84823-18225 MARK-"deLuxe" [sedan boot, right side]
- differs from coupe #84823-18200
search: サニー1000デラックスエンブレムᴵ Sunny 1000 Deluxe emblem
84823-H1025
84823-H1025 SET-MARK "GL" * Coupe GL * Sedan GL
or
84824-27725
* Sedan boot lid, left side
* 3-speed models carried no badge
COMPARE to Datsun 1200 'Sports' badge![]()
84824-20300
MARK 'NISSAN Full Automatic'
84862-H0300
84862-H0300ᴳ WASHER-sealing (fixing badges, 2 or 3 per badge)
.jpg)
