B10 Badges
Revision as of 08:16, 16 August 2025; view current revision
Category: Datsun B10
  • Sedan, light Van (wagon) and Truck (ute) all use the same front badges
  • Coupe badges differ
  • The grille badge changed from 1967 (vertical badge) to 1968-1970 (horizontal shield-shaped badge)
Japan Market
Although marketed and sold as a "Datsun", the first generation Sunny did not come with any "Datsun" badges or emblems, instead stressing the 'Sunny' name (for more details, see B10 Name).
Japan model sedan badges with Coupe round badge
6595_4cdf672dd169d.jpgUpload click to view
Deluxe Sedan badges with Coupe grille badge
174_5e2766cd7a045.jpgPost 493571
Sedan & Van
Front & Front Side badges
174_6114fdc358572.pngPost 495731
  • C-pillar badge
    174_5d12f1eef3c46.jpgbrochure
  • #62311-18025 SET-EMBLEM, radiator grille ["D"] 1967
  • #62311-27725 KIT-ORNAMENT, radiator grille (from C/# VB10-066701) ["S"] 1968-1970
Rear Badges
28534.pngAlbum 28534
28555.jpgAlbum 28555
Truck
FRONT
REAR
30009.pngAlbum 30009
Coupe
KB10 came out in mid-1968, there was no 1967 coupe.
FRONT & SIDE
30012.pngAlbum 30012
 4 #62311-25725 KIT-ORNAMENT, radiator grille
 5   62312-25700 BRACKET
 6   89-15134-1  WASHER-lock
 7   89-11104-1  NUT
42 #63841-25700 BADGE-"Sunny coupe", front fender 2
43   #63845-18000 CLIP-tubular 4
44 #63843-18200 BADGE "Deluxe", front fender 2 [similar to sedan, coat-of-arms style]
45   #63845-18000 CLIP-tubular 4
 - #Option Badges
REAR
30011.jpgAlbum 30011
6 #84812-25725 KIT-ORNAMENT, trunk lid [Round with reeded edges]
7 #84823-18200 MARK-"Deluxe", trunk lid [boot, right side]
8 #83845-18000 CLIP-tubular 2 (deluxe/GL) 3 (automatic)
  #84862-H0300 WASHER-sealing (fixing deluze mark)
9 #84824-20300 MARK-"Nissan full automatic", [rear panel, center] [same badge as sedan]
- #84823-H1025 SET-MARK GL
Catalog
62311 grille badge
-18025  70-3 sedan "D" vertical
        88-3 van
       100-2 truck
-25725 110-2 coupe "S"
        70-3 sedan [missing]
        88-3 van   [missing]
       100-2 truck [missing]
63841 fender model badge
-18025  70-7 sedan "Sunny"
        88-6 van
       100-4 truck
-25700 110-4 coupe "Sunny coupe"
84812 trunk lid ornament [medallion]
-25725 118-2 coupe
84821 rear model
-18025  78-4 sedan "Sunny 1000"
        97-4 van
84823 rear trim badge
-H1025  78-4 sedan 'GL'
       118-2 coupe
-18200 118-2 coupe 'Deluxe'
-18825  78-4 sedan 'Deluxe'
        97-4 van
       108-3 truck
84824 rear transmission badge
-20300  78-4 sedan 'Nissan full automatic'
       118-2 coupe
-27725  78-4 sedan 'Sports'
96905 LABEL-loading capacity
-15200 108-3 truck
-18100  97-4 van "400 kg"
-27800  97-4 van "400 kg" option
Export Models
Export Datsun 1000s, being sold by Datsun dealers instead of Sunny Shops, were badged "Datsun" instead of Sunny. However, they still used "S" emblems.
  • #63841-25700 The 'Sunny coupe' badge does not appear to have been used on many export coupes, if any
  • Exports coupes used 'DATSUN' instead of 'Sunny' badges
#84812-25725 Export coupes used the 'S' emblem, like this Australia coupe
18317.jpgAlbum 18317
#84824-27725 Rear 'Sports' badge — was it stock?
#62311-25725 radiator grille ornament
4585a.jpgAlbum click to view 4585.jpgAlbum click to view
  • 'DATSUN 1000' rear model badge Sedan/Van
    174_56c8f50cda87b.jpgUpload click to view 5833.jpgAlbum 5833
12807.jpgAlbum 12807 174_56c8f51da068a.jpgUpload click to view
Grille Badges
'D' Early Grille Badge
A narrow, vertically-oriented 'D' badge was used on early models -- both JDM and Export models.
  • sedan 1966-1967
  • light van (wagon) 1966-1967
  • 1968 Sunny Truck (B20) with aluminum 2-section grille
  • 1968 Australia Ute (which used the 1967 sedan grille)
Sedan/Van with the early aluminum-type 4-section grille
174_61150e80cb561.jpgPost click for topic 27295.jpgAlbum 27295
400px-1966_Datsun_Sunny_01.jpgWIKI go to Wikipedia
There are M4 nuts & washers fixing the emblem to the grille
quantity: 2 each
89-15434-1 WASHER-plain standard, M4
89-15134-1 WASHER-lock, M4
89-11104-1 NUT, low carbon steel (low grade strength/JIS 4T) M4 thread
174_611504c3008f9.jpgPost 495713 7266.jpgAlbum 7266
'D' Late Grille Badge
Export Datsun 1000s used the 'D' badge after the first year
BADGE-"D", radiator grille
9465.jpgAlbum 9465 3418.jpgAlbum 3418
'S' Late Grille Badge
Japan-market B10 and B20
62311-27725 KIT-ORNAMENT, radiator grille 'S'
Sedan/Van 1968-1969
Truck 1968-1970
7076.jpgAlbum 7076 174_5c0a39be48c17.jpgPost 495722
about 11cm wide
174_611c313971457.jpgPost 495731 174_611c31b815883.jpgPost 495731 174_611c31c576bfb.jpgPost 495731 174_611c31d966b55.jpgPost 495731 174_611c3266586bb.jpgPost 495731 174_611c3266586bb.jpgPost 495731 174_611c3369070c0.jpgPost 495731 174_611c33757d5b9.jpgPost 495731
Fitted to B110 sedan
1231.jpgAlbum 1231
Flag Grille Badge
Radiator grille emblem ('S' flag badge in Datsun colors) — left side
62311-25725 KIT-ORNAMENT, radiator grille COUPE
62312-25700 BRACKET
89-11104-1  NUT
174_5d37d9a0da06c.jpgPost 491962 174_5d37d9bc070f6.jpgPost 491962
174_5d00319f231f8.jpgbrochure 174_5d37d993ef2fe.jpgPost 491962
Export Coupe
s-COUPE.jpg 6644.jpgAlbum 6644
Grille badge
Option Badges
KB10 Sports Options
Car Badges (Sunny motorsport mark)
Safari Badge
Sunny * The 17th East African Safari Rally [1969]
174_611c206e9e17c.jpgPost 495729
Diameter: 880mm
Studs: M5 x 40mm
Bolt pattern: 2 on 36mm PCD
174_611c207dcdf8a.jpgPost click for topic 174_611c208915846.jpgPost click for topic
B10_safari_badge_a.thumb.jpg.b5540d4d0c27ba995f1f9973b0fb07a1.jpg B10_safari_badge_b.thumb.jpg.e96c3f0c7f1c55cd113cf161bffcac02.jpg B10_safari_badge_c.thumb.jpg.e9d9e7bf170cb681bf3d16f4bd3dbe04.jpg B10_safari_badge_d.thumb.jpg.e97deeb86d39dd662894a674d4f4b42f.jpg
63843-18225
63843-18225 EMBLEM-"deLuxe", front fender Deluxe [Same as sedan, coat-of-arms style]
9998_4c89f162273ac.jpgUpload click to view 174_5e276923d0144.jpgPost click for topic
Sedan | Coupe
6635.jpgAlbum 6635 7781.jpgAlbum 7781
9986.jpgAlbum 9986 6643.jpgAlbum 6643 7073.jpgAlbum 7073
COUPE: 'deLuxe' and 'Sunny Coupe' front fender badges
2013ityou0461.jpg 28554.jpgAlbum 28554
63841-18025
63841-18025 EMBLEM-"Sunny", front fender
21314.jpgAlbum 21314 21313.jpgAlbum 21313 174_5e276954c3f1d.jpgPost 70243
4248.jpgAlbum 4248 8739.jpgAlbum 8739
63841-25700
63841-25700 BADGE-"Sunny coupe", front fender (red, white & blue Datsun Colors)
6985.jpgAlbum 6985 7781.jpgAlbum 7781 9116.jpgAlbum 9116
Coupe deLuxe
76831-H0225
76831-H0225 KIT-ORNAMENT ['S' round medallion], rear quarter pillar (from C/# B10-350001) (2) 4-door Deluxe
76831-H0225 'S' ornament [round, originally purple]
174_613bdc4632821.jpgPost click for topic
* with smooth edge
* with fluted interior ring
compare to #84812-25725 coupe rear badge
* with reeded edge
* with 3-section interior ring
2090.jpgAlbum 2090
1969 4-door sedan Deluxe rear quarter pillar ornament
30014.jpgAlbum 30014 30013.jpgAlbum 30013 174_6137d99e01b7e.jpgPost 495819
Color has faded away over time
174_613bdc67010a3.jpgPost 495830 174_613bdc7741980.jpgPost 495830
Purple (紫 murasaki) is seen as a sign of wealth and prestige in Japan, associated with royalty and luxury (deluxe) things
174_613bdc4632821.jpgPost 495830 174_613bdc5736f07.jpgPost 495830 174_613bdc3ad84e0.jpgPost 495830 174_613bdc1bb288e.jpgPost 495830
83845-18000
83845-18000 CLIP-tubular 2 (fitting badges ) 2 or 3 per badge
84812-25725
84812-25725 KIT-ORNAMENT, trunk lid Coupe [Round]
* with reeded edge
2090.jpgAlbum 2090
Compare to #76831-H0225 Sedan Pillar 'S' ornament [round]
* with smooth edge
2090.jpgAlbum 2090 22698.jpgAlbum 22698 6575.jpgAlbum 6575
4993.jpegAlbum 4993 174_667a3ce2d4a40.jpgPost 498529
84821-18025
84821-18025 EMBLEM-"Sunny 1000" [boot, right side]
Sedan
9987.jpgAlbum 9987
Van
15080.jpgAlbum 15080 16503.jpgAlbum 16503
84823-18200
84823-18200 MARK-"deLuxe" [coupe boot, right side]
25906.jpgAlbum 25906 4322.jpgAlbum 4322 9724.jpgAlbum 9724 174_667a3ce2d4a40.jpgPost 498529
84823-18225
84823-18225 MARK-"deLuxe" [sedan boot, right side]
9998_4c89f1748c25f.jpgUpload click to view
30010.jpgAlbum 30010 4238.jpgAlbum 4238
coupe or sedan?
174_5e27693fcf1f5.jpgPost 70243
84823-18225_a.thumb.jpg.fa913f00fcca1b35ee8a48533e3891dc.jpg 84823-18225_b.thumb.jpg.cec4c9ff99894fb3390300299e336d16.jpg 84823-18225_c.thumb.jpg.ec981b574e357594b62e5cfd02e1a128.jpg
search: サニー1000デラックスエンブレム Sunny 1000 Deluxe emblem
84823-H1025
84823-H1025 SET-MARK "GL"
* Coupe GL
* Sedan GL
27968.jpgAlbum 27968 B1016ppcover.jpgKB10 brochure
or
174_5d12f058cf160.jpgKB10 brochure
174_677edfa6a79c2.jpgPost 498705 174_677edfae6c9bd.jpgPost 498705 174_677edfb72ab55.jpgPost 498705
84824-27725
84824-27725 KIT-MARK-"SPORTS" Sedan 4-speed
* Sedan boot lid, left side
* 3-speed models carried no badge
COMPARE to Datsun 1200 'Sports' badge
20865.jpgAlbum 20865
21315.jpgAlbum 21315 174_5d0c810c54f69.jpgPost 491752 4237.jpgAlbum 4237
84824-20300
MARK 'NISSAN Full Automatic'
27850.jpgAlbum 27850
Sedan | Coupe
21974.jpgAlbum 21974 27851.jpgAlbum 27851
84862-H0300
84862-H0300 WASHER-sealing (fixing badges, 2 or 3 per badge)
