Alternator mounting
From Datsun 1200 Club
Categories: Charging System | Engine Electrical System
Datsun 1200 mounted the alternator on the left or right side depending on the year.
アルタネータ マウンテング
Early A-series engines (1966-1973) mount the alternator down low on the left side of the engine, under the intake manifold as shown in this photo:
7891.jpgAlbum 7891
1974-up engines mount it high on the right side of the engine:
10489.jpgAlbum 10489
For the A Engine Redesign, the alternator was moved to this right-side position to make more room for accessories such as Air conditioning pump or Smog pump.
Yahoo search: サニーダイナモ (closed: サニーダイナモ)
Left-side Mount
Early A-series engines (1966-1973) mount the alternator down low on the left side of the engine, under the intake manifold as shown in these photos:
174_59eda1efec985.jpgPost click for topic 7891.jpgAlbum 7891
29815.jpgAlbum 29815
23324.jpgAlbum 23324 23555.jpgAlbum 23555
V-Belt
* 11720-18002 BELT-fan (L=838) B10
* 11720-27720 BELT-fan B10 (op.) Rally
* 11720-18002 BELT-fan (L=838) B110
* 11720-25604 BELT-fan (L=856) E10
* 11720-18002 BELT-fan (L=838) E10 (from '72)
BRACKET
B10, B110, B120, E10
* 11710-H0100 BRACKET-alternator
BOLTS FIXING BRACKET
B110/B120 - using studs in engine block
** 08911-20810 NUT M8, medium carbon steel (2)
** 08915-43810 WASHER M8, plain (2)
E10 - using bolts into engine block
** 08313-02210 BOLT, fixing bracket (2)
** 08915-14010 WASHER-lock, fixing bracket (2)
14950.jpgAlbum 14950
B10 EARLY & OPTION
* 11710-18000 BRACKET-alternator B10 (replaced by 11710-H0100)
* 11710-27720 BRACKET-alternator (506W alternator) (op.) B10 Rally
B10 used these to fix bracket to engine block:
** 89-11210-1 NUT, fixing alternator bracket (2)
** 89-15140-1 WASHER-lock, fixing alternator bracket (2)
or
** 81-31022-1 NUT (2)
** 89-14140-1 WASHER-lock (2)
Fixing alternator to bracket
B10 early
** 11711-18000 BOLT, fixing alternator to bracket
** 89-15140-1 WASHER-lock, fixing alternator to bracket
B10 late
** 81-30830-1 BOLT (2)
** 89-11208-1 NUT (1)
** 89-15138-1 WASHER-spring lock (2)
** 89-15438-1 WASHER-plain (1)
B110
** 08131-02210 BOLT (1)  [fixing alternator rear]
** 08915-14010 WASHER-lock (2)
** 08130-83010 BOLT (fixing alternator front) (1)
** 08911-20810 NUT (1)
** 08915-13810 WASHER-spring lock (2)
** 08915-43810 WASHER-plain (1)
E10
** 08130-83510 BOLT (fixing alternator rear) (1)
** 08915-13810 WASHER-lock (2)
** 11713-M0100 NUT-stopper, alternator bracket
9595.jpgAlbum 9595 7304.jpgAlbum 7304 6417.jpgAlbum 6417
Adjusting Bar
Attaches to front face of cylinder head
15170.jpgAlbum 15170 20402.jpgAlbum 20402
Thicker version
174_5c9759df71a1e.jpgPost 490991 174_5c9759f9ac8d7.jpgPost 490991 174_5c975a08090c5.jpgPost 490991
174_5c9759e751a11.jpgPost 490991 174_5c9759eecd396.jpgPost 490991
Adjusting Bar buy at Bprojects
B10, E10, B110, B120 early (A10 & A12)
* 11715-18001 BAR-adjusting, alternator B10
* 11715-H2300 BAR-adjusting, alternator B110 (to '70-Aug.) [thin ~3.2mm]
* 11715-M0100 BAR-adjusting, alternator (from '70-Sept.) [thick ~4.5mm]
* 11715-M0110 BAR-adjusting, alternator (op.) E10 1974
Bolts Fixing Adjusting Bar
** 08110-81610 BOLT, fixing adjusting barp
** 08915-13810 WASHER-lock, fixing adjusting bar
Right-side Mount
1974 and up 1200s mount the alternator on the right side of the engine.
23759.jpgAlbum 23759
H62 low mount (adjuster bolts to bottom bolt of cylinder head)
H72 high mount (adjuster bolts to top bolt of cylinder head)
3265.jpgAlbum 3265
Right-side High Mount
The adjuster bar bolts to the top bolt hole of cylinder head face
Lucas AS123 on A14 in B140
31348.jpgAlbum 31348 31347.jpgAlbum 31347
Right side low-mount
The adjuster bar bolts to the bottom bolt hole of cylinder head face
B310 engine
8091.jpgAlbum 8091 195.jpgAlbum 195 6851.jpgAlbum 6851 8856.jpgAlbum 8856
Right-side Cross Mount
Long adjuster mounts across the cylinder head face. Unknown source
POST racertech
Adjusting Bar
11715-H6200 BAR-ADJUSTING, ALTERNATOR [more curved, most vans]
11715-H7201 BAR-ADJUSTING, ALTERNATOR [less curved, sedan+coupe+(van.f/cold)]
08120-82062 BOLT [engine end]
23164-H0100 BOLT [alternator end]
H62 curved adjuster | H72 adjuster
19344.jpgAlbum 19344
Bracket
ダイナモブラケット
28540.jpgAlbum 28540 28541.jpgAlbum 28541 28542.jpgAlbum 28542
Bracket
* 11170-H6200 BRACKET-ALTERNATOR -7801
* 11170-H7401 BRACKET-ALTERNATOR 7802- > 11170-H7400
Bolts Fixing bracket to engine block
* 08131-03510 BOLT [rear]
* 08131-04210 BOLT [front]
* 08915-14010 WASHER (2)
Bolts Fixing alternator to bracket
* 08915-43810 WASHER [plain] (2)
* 08915-13810 WASHER [lock] (2)
23100B
* 11915-U0105 BOLT (2)
23100F
* 11713-21000 SHIM T=0.3 (As Required)
* 11713-21001 SHIM T=0.2 (As Required)
altbrack.jpgPost click for topic 28543.jpgAlbum 28543 28542.jpgAlbum 28542
V-Belt
Main: Fan Belt
Moving Bracket
Got a late-model A-series engine? Bolt the alternator to the left side down low for a cleaner look. No factory bracket bolt bosses here, but a simple adapter plate can be fabricated from a flat plate. Bolt to the block with the three outside holes, then bolt the alt. bracket to the two close holes. Size up a new fan belt and you are done.
kit datsun1200.com
27211.jpgAlbum 27211
A15 with left-mounted alternator
1409.jpgAlbum 1409
Adapter Plate bolts to engine left side, cast-iron bracket bolts to the plate
23465.jpgAlbum 23465
19281.jpgAlbum 19281
Upside down
6265.jpgAlbum 6265
Another method
12532.jpgAlbum 12532
Pillow Ball Adjusting Bar
A rod end bearing, also known as a heim joint (N. America) or rose joint (U.K.), or pillow ball (Japan) is a mechanical articulating joint.
Yahoo search:サニーピロボールダイナモ (closed: サニーピロボールダイナモ)
  • The turnbuckle type makes it easy to fine-tune the tension of the belt.
  • Rose-jointed tension rod allows you to custom-tune the length and angle of the alternator adjusting rod. The angle makes it easier to fit non-stock alternators
  • There is no need to worry about damaging the harness or engine with a lever at the time of adjustment.
approximately 146mm eye-to-eye length
28538.jpgAlbum 28538
28537.jpgAlbum 28537 Hole diameter 8mm Pillow ball right left and right screw M8 bolts 159mm ± 13mm S45C steel/Ni plated
ピロボールダイナモステー Pillow Ball Dynamo Stay
16063_53e965f45ca8a.jpgPost 458875
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Alternator_mounting"
This page has been accessed 4,711 times. This page was last modified 20:21, 27 November 2025. Content is available under Datsun 1200 Club.
