Seat belts
From Datsun 1200 Club
Category: Body
B110 was fitted with seat belts. Belts differ by country. Two-point or three-point (with shoulder strap) belts were fitted.
1972 USA Owners manual
29361.jpg01   29362.jpg02
The two front seat belts are of a three point type consisting of lap and shoulder belts. The two rear seat belts are of a two-point type.
Aussie
1207.jpgAlbum 1207
racing
1897.jpgAlbum 1897 4889.jpgAlbum 4889
JDM
5083.jpgAlbum 5083
fix-it
8198.jpgAlbum 8198
Belts come in 2-point and 3-point versions, with 3-point ELR an option for late Sunny Truck
Seat Accessories Part Numbers
OPTIONS
* Rear belts had retractable OPTION
* Rear belts had a rare 3-point OPTION
* Rear headrests
Australia
STD
11972.jpgAlbum 11972
Australia has ADRs to cover the installation of safety belts. This means starting with 1969 models, you cannot replace bad used belts with good used belts.
Get new belts from:
  • Rare Spares
  • Generic seat belts, Repco, etc.
  • Klippan AU$85 and AU$120
    • 1512 (retractable to suit 1200)
    • K7099 (150mm drop links to suit 1200)
    • K4264 - designed for 73 Holden, but fit 1200 well enough
The Klippan retractable units are compact and won't foul on most seats.
http://www.autolivaftermarket.com/
The 120Y recommendations are the same for 1200 Sedan.
Results for Nissan 120Y 1974-78
Make Nissan Model 120Y
Config 4/DR SEDAN Year 1974-78
Details B210 1.2L
Front Left Front Centre Front Right
K1517 N/A K1517
Rear Left Rear Centre Rear Right
K1635S K1637 K1635S
They can be bought through Repco. Get your old ones out and measure the length.
Variations
Early USA models came with either 2-point (lap-belt only) or 3-point (lap + shoulder) belts. Both front and rear belts are standard equipment.
* All 1972 models use 3-point belts
* From 0172, retractor system was used front and rear
* Rear set had 2-point belts
* Rear Optional was 3-point belts (not available with retractor type)
* 86810: shoulder belt
* 86820: 2 point
* 86830: 3 point (set? Or RH?)
* 86880: 3 point LH
* 88820: rear
B110
Front
Front USA (sedan & coupe use the same belts)
86830-H1000 3 POINT TYPE (2)
86830-H1001 3 POINT TYPE (2) 0871- $62.28
86830-H4600 3 POINT TYPE (AUTO LOCK R (2) 0172- $141.47
NOTE: 86830 comprises 2-point lap belt + shoulder belt
USA retractor belt (with detachable shoulder belt not shown)
20031.jpgAlbum 20031
Front JAPAN
* 86820-H1001 BELT SET-safety (2 point) -0871, PB110
* 86820-H1001 BELT SET-safety (2 point) 0871-
3 point set (includes detachable shoulder belt)
* 86830-H1000 BELT SET-safety GX 1972 (also PB110 option)
* 86830-H1001 BELT SET-safety GX 1972
Shoulder belt
86810-H1000 BELT ASS'Y-shoulder, front seat (for 3 point) OPTION -0871
86810-H1001 BELT ASS'Y-shoulder, front seat (for 3 point) OPTION 0871-
Unknown retractor shoulder belts installed in B110
Rear
Rear Seat Sedan, Van
* 88830-H1000 SET-SAFTY BELT REAR SEAT 3 POINT TYPE USA OPTION
* 88830-H1001 SET-SAFTY BELT REAR SEAT 3 POINT TYPE USA OPTION 0871- $71.11
* 88820-H1000 BELT SET-reat seat OPTION -0871
* 88820-H1001 BELT SET-reat seat OPTION 0871- JDM
* 88820-H4600 SET-SAFETY BELT REAR SEAT 2 POINT TYPE 0171- USA
  (retractor type) Sedan, Coupe NLA
* 88810-H1000 ASS'Y SHOULDER, safety belt OPTION USA
* 88810-H1001 ASS'Y SHOULDER, safety belt OPTION JDM, USA 7108-
Rear Seat Coupe
* 88820-H1800 BELT SET-reat seat OPTION [3 point], PB110 OPTION
* 88830-H1801 SET-SAFTY BELT REAR SEAT 3 POINT TYPE JUSA Coupe 0871-
* 88820-H1800 SET-SAFETY BELT REAR SEAT 2 POINT TYPE USA,JAP.OP Coupe
* 88820-H1801 SET-SAFETY BELT REAR SEAT 2 POINT TYPE USA,JAP.OP Coupe 0871-
 20033.jpgAlbum 20033
* 88810-H1001 ASS'Y SHOULDER, safety belt OPTION JDM, USA 0871-
Bolts
Seat belts bolts must be super strong Grade 8.8. Hex head was used by Datsun seat belts into the 1980s.
Possible match?
* 7/16-20 NF thread (standard fine pitch)
* 1-1/4 inch long
* Grade 8.8
* Hexagonal head
NOTE: Bolt length does not include the head
174_5c9af300f08c4.pngPost 491017
Seat Belt Warning System
USA models have a warning system. If the seat is occupied, the weight switch sounds a buzzer unless the belt is fastened.
Swaps
The key to a great seat belt swap for B110 is finding a low profile rectractor that fits below the seat.
Late B210
1978 B210 (USA) dual-retractor design 3-point belt. It bolts to stock B110 bolt holes.
  • Lower retractor blocks seat from fully moving back
  • B210 Belt buckle is modern semi-rigid design that works stock B110 belts. But it is on the short side for B110.
20030.jpgAlbum 20030
620
1977 Datsun 620 pickup is a one-piece shoulder & seat belt, that bolts to stock B110 mount holes.
  • Works like a modern belt, very nice
  • Belt buckle is bit long. But works.
  • Rectractor blocks seat from moving fully back. But has unique swing design so fits better than Late B210 belts.
1977 Datsun 620 Pickup belts (USA) in Datsun 1200
20029.jpgAlbum 20029
26416.jpgAlbum 26416
B210 belts bolt into B110. PB210 uses same belts.
Front
* 86820-H5000 2-point -7503
* 86830-H5000 3-point -7503 GX
* 86830-H7400 ELR 3-pt 7504- Sedan, Coupe 76- Van (Takata)
* 86830-N6610 NLR w/shoulder 7504- Van
* 86830-H7800 ELR 76- Van (Fuji)
Shoulder Belt
* 86810-H5000
Rear Sedan, Coupe
* 88820-H5000 -7503
* 88820-H7400 7504- (Takata)
* 88820-H6600 OPTION van
* 88820-H6601 OPTION van 0475- (Fuji)
* 88820-H6602 Van (Takata)
Australia
Coupe Rear shoulder belt
7284.jpgAlbum 7284
Sedan Rear shoulder belt
10875.jpgAlbum 10875 11178.jpgAlbum 11178
2858.jpgAlbum 2858
3145.jpgAlbum 3145
North America
Aside from fabric type and regional requirements, the basic difference is:
  • 2-dr vs 4-dr
All are retractor type. All are 3-point, early uses separate shoulder belt, later uses integrated shoulder belt.
4-dr
* 86830-H6200 POLYESTER(NSK) -0274
* 86830-H6210 NYLON (TAKAT)(USA) 1073-0275
* 86830-H6205 NYLON (NSK) (USA) 0374-0275
* 86830-H6206 NYLON (NSK) (USA) 0375-
* 86830-H6211 NYLON (TAKAT)(USA) 0375-
* 86830-H6205 NYLON (NSK) (CAN) 0374-0775
* 86830-H6206 NYLON (NSK) (CAN) 0875-
* 86830-H6210 NYLON (TAKAT) (CAN) 1073-0775
* 86830-H6211 NYLON (TAKAT) (CAN) 0875-
2-dr California
* 86830-H6900 POLYESTER (NSK) -0274
* 86830-H6905 NYLON (NSK) (USA)	0374-0275
* 86830-H6906 NYLON (NSK) (USA) 0375-
* 86830-H7301 NYLON (NSK) (CAL)	0974-0275
* 86830-H7302 NYLON (NSK) (CAL)	0375-0775
* 86830-H6905 NYLON (NSK) (CAN) 0374-0775
* 86830-H6906 NYLON (NSK) (CAL,CAN) 0875-
* 86830-H6910 NYLON (TAKAT) (USA) 1073-0275
* 86830-H6911 NYLON (TAKAT) (USA) 0375-0776
* 86830-H7311 NYLON (TAKAT) (CAL) 0974-0275
* 86830-H7312 NYLON (TAKAT) (CAL) 0375-0775
* 86830-H6910 NYLON (TAKAT) (CAN) 1073-0775
* 86830-H6911 NYLON (TAKAT) (CAL,CAN) 0875-0776
* 86830-H6920 NYLON (TAKAT) 0876-
Rear
* 88820-H6200 SET-SAFETY BELT REAR SEAT (rectractor type, 2 point) USA -1177 $67.89
* 88820-H6205 SET-SAFETY BELT REAR SEAT (rectractor type, 2 point) USA 1277-
B120
BELT-SHOULDER, FRONT
* 86810-H7400 7510-7803 BLACK
* 86810-G1060 7804-8910 DARK BROWN
2 POINT
BELT SET-FRONT SEAT, 2 POINT
* 86820-H7401 7510-7803 BLACK
* 86820-G1260 7804-8910 DARK BROWN
3 POINT Non retracting
BELT SET-FRONT SEAT, 3 POINT  (separate shoulder belt)
* 83830-H7401 7510-7803 BLACK
* 83830-G1061 7804-8109 DARK BROWN
  20032.jpgAlbum 20032
* 83830-G1062 8110-8109
3 POINT Retracting
These retractors bolt to the B-pillar and should fit B110 sedan, coupe and van -- although it may limit seat travel. With 2-door models it may interfere slightly with rear-seat access.
1978-1994 specs
* Meets JDIS D4604 IIIB ELR-VW
* Model: TK-521-G422
* TAKATA CORPORATION
* 4525, K2133
* H2701, 108TI, 81R
BELT SET-FRONT SEAT, 3 POINT (integrated shoulder belt)
DARK BROWN
* 83830-G1070 ELR DARK BROWN 7804-8109 (option)
BROWN
* 83830-G1071 ELR 8110-8611 (option)
* 83830-G1900 ELR 8611-8910 (standard equipment)
GRAY
* 83830-95W00 ELR 8910-
* 83830-95W03 ELR タカタ 8910-
G1070
17190.jpgAlbum 17190 20035.jpgAlbum 20035
95W
20034.jpgAlbum 20034
B310
Rear
* 88820-H8500 Black $46.27
B310 front seat belts have a retractor mechanism that fits inside the B-pillar. So they do not fit B110.
B310 rear belts look very similar to B110
11003.jpgAlbum 11003
B110 Vs B310
Rear B110
Rear B310
24514.jpgAlbum 24514
PB110
Sunny Excellent seat belts look the same as regular B110.
11438.jpgAlbum 11438 23411.jpgAlbum 23411
Mounting
Change May 1972
24393.jpgAlbum 24393
Front seat belt anchorages
Reinforcing plates on underside of car
Coupe
Aussie front top mount point
16236_55ac9b557f454.jpgPost 470745
174_55b092fe9c5f1.jpgPost 470858
Japan mount point is above the glass — much higher.
Modified top mount location - matches late USA point
Sedan
Japan - above the glass
Revised (late) USA Front mount point - 2 door
Aussie
1207.jpgAlbum 1207 15424.jpgAlbum 15424
Australia Sedan
17735_55ab5b87d7a8a.jpgPost 470716 17735_55ab5b6850c6a.jpgPost 470716
Rear retractable belts
Truck
19287.jpgAlbum 19287
1207.jpg 1897.jpg 5023.jpg 5083.jpg 8198.jpg 11003.jpg 14972.jpg 15424.jpg 17190.jpg 17538.jpg 17976.jpg 19287.jpg 20029.jpg 20030.jpg 20031.jpg 20032.jpg 20033.jpg 20034.jpg 20035.jpg 20522.jpg 21755.jpg 23410.jpg 24393.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Seat_belts"
This page has been accessed 83,903 times. This page was last modified 23:09, 10 July 2025. Content is available under Datsun 1200 Club.
