Compressor brackets
From Datsun 1200 Club
Category: Heating And Ventilation Systems
<-- back to Air conditioning
Various types of brackets were used over the years to fix the aircon compressor to the engine. Early A12 and late A12 brackets differ. You can make your own brackets, buy used from a 1200 or 210/B310 or A-engined Cherry/Pulsar/Vanette, or buy new.
Index
Factory brackets
17554_5806e018e2f44.jpg#H86 18710.jpg#H74 24729.jpg#H74 28742.jpg#custom 31234.jpg#Sanden 508 174_63c632f538f1a.jpg#Sanden 174_5c45a548354f8.jpg#York to Sanden 23103.jpg#York 25501.jpg#B210 17554_5806e01fac29e.jpg#120Y 174_5cbac66ecc7e8.jpg#210 20079.jpg#1979 cb1.jpg#1979 cb3.jpg#1979 593072-5300.jpg#vanette1C120_A15_ac2.jpg#vanette1
The engine parts needed for aircon are 1) Compressor 2) Compressor bracket 3) Crankshaft Pulley and 4) V-belt
B110 1970-1976 All custom, various types
B120 1978-1979 Factory high-idler mount
B120 1980-     Factory low-idler pulley mount
A bracket can be fabricated of two 8mm strips of metal (going across) and two vertical strips to connect to the compressor. An idler pulley can be added from a Nissan or other vehicle.
High-mount idler | Low-mount idler
20088.jpgAlbum 20088 20089.jpgAlbum 20089
Early Engine
Compressor on early A12 (1970-1973, front-mount distributor type)
Custom install on right-side, battery moved to trunk, compressor place just above oil pump. Mounted like an alternator with no idler pulley
This in an Australia 1200. It uses a humongous bracket to space the compressor out past the low-mounted alternator.
9377.jpgAlbum 9377 9378.jpgAlbum 9378
15371.jpgAlbum 15371
Here is a USA 1200 with a slightly different setup:
2185.jpgAlbum 2185 16244.jpgAlbum 16244
Uncommon Right-side compressor mount
14950.jpgAlbum 14950 14953.jpgAlbum 14953
Late Engine
For late model A12 (1974-up, mid-distributor type).
unknown bracket
13822_55619c6b37967.jpgPost 468324 13822_543ba7b1b39af.jpgPost 460546
Custom bracket for modern short compressor, made out of 6mm stock
close-ear H86 from B310 (1981-1982)
174_5806b82922ab6.jpgPost 481951 17554_5806e018e2f44.jpgPost 481953
wide-ear H74 from #B310
24729.jpgAlbum 24729 18710.jpgAlbum 18710
1978 Factory Bracket
Old compressor type (York-type)
21822.jpgAlbum 21822 23103.jpgAlbum 23103
1979
Starting august 1979 -- New Compressor-type
210
B310 Datsun 210 USA with York compressor
AC bracket 11910-H9900
174_5cbac66ecc7e8.jpgPost 491231
174_5cbac6634c1cc.jpgPost 491231
Unicla
1977 Unicla compressor mount
25585.jpgAlbum 25585 25586.jpgAlbum 25586
idler pulley
Piston Compressor
Found on a JDM E-HB310 (A14, 1979?), does not appear to be a factory bracket or compressor
28742.jpgAlbum 28742 28743.jpgAlbum 28743 28744.jpgAlbum 28744
Sanden
Sanden 508
For use with Sanden 508 compressor
31234.jpgAlbum 31234 31233.jpgAlbum 31233 31232.jpgAlbum 31232
Sanden W508
For Sunny Truck SANDEN W508 JCC02 Compressor Stay Set (コンプレッサー ステイ セット) for A12/A14/A15 engines
SANDEN W508 SD5S14 A2 (W-groove) compressor 14.1 mm thick front flange
31240.jpgAlbum 31240 31241.jpgAlbum 31241 31242.jpgAlbum 31242
Sanden Steel
Generic axial-type compressor bracket for late A-engine
174_63c632f538f1a.jpgPost 497427 31223.jpgAlbum 31223 31222.jpgAlbum 31222
Universal bracket to replace the square York compressor (USA and AUS original equipment) with a modern lightweight Sanden compressor is $60 at Summit Racing. May be adaptable to early/late A-engine?
Sanden York
York-to-Sanden adapter
174_5c45a548354f8.jpgPost 490405
174_5c45a5529a62a.jpgPost 490405
B210 Japan early (1973-1975)
25501.jpgAlbum 25501
1976 two-piece bracket
28741.pngAlbum 28741
1977 one-piece bracket Type H74 (also used by early #B310)
28739.pngAlbum 28739
B210 JAPAN LATE (1976-1977)
11910-H7401 BRACKET-COMPRESSOR A12,A14
11925-M3000 PULLEY ASSY-IDLER COMPRESSOR A12,A14 -7612
11925-M3001 PULLEY ASSY-IDLER COMPRESSOR A12,A14 7701-
27630-H7402 COMPRESSOR-COOLER A12,A14
120Y
'5 SPEED DATSUN 120YCCC'
17554_5806e01fac29e.jpgPost 481953
A different style: 'DATSUN 120Y' for A12 engine with Sanden 507 compressor
174_6912559081db3.jpgPost 499125 174_691255a852b3e.jpgPost 499125 174_6912559e6b9d6.jpgPost 499125 174_691255b22f1a1.jpgPost 499125 174_691255b9b692c.jpgPost 499125
B310
wide-ear H74 from JDM B310 cast marking '593016 1900'
H74 Type (late #B210/early B310)
B310 JAPAN LATE (1976-1977)
11910-H7401 BRACKET-COMPRESSOR -8010
11910-H8661 BRACKET-COMPRESSOR 8011-
27630-H8501 COMPRESSOR-COOLER [with clutch]
27631-U9602 COMPRESSOR UNIT DKKC
27633-H8500 CLUTCH ASSY-COMPRESSOR
28738.pngAlbum 28738
approximately 118mm between ears
30684.jpgAlbum 30684
mounts lower than oil pan
30683.jpgAlbum 30683
30679.jpgAlbum 30679 30680.jpgAlbum 30680 30681.jpgAlbum 30681 30682.jpgAlbum 30682
Vanette
C120 Vanette A15 mounts below oil pan rail
Late Block Bracket Pattern
This was patterned off an A15 block in Australia, it should be close enough to get you started. The bolts on my block are 3/8" x 16 TPI UNC with about 25mm of thread depth.
NOTE: A-series uses M10 bolts alloy steel (10.9 strength)
also see Block_Comparison#23474 for block photo & measurements
27774.jpgAlbum 27774
B310 JDM CATALOG C-403 page 479 1983.9
11910-H7401 -8010 bracket
11910-H8661 -8011 bracket
08131-03510 BOLT M10x35, alloy steel [9T hi-strength]
another measurement (in millimeters)
28304.jpgAlbum 28304
JDM B120
FOR YORK-TYPE COMPRESSOR (1978)
* 11910-G1661 BRACKET A
* 11911-G1661 BRACKET B
* 11925-A0100 IDLER PULLEY
* 11933-A0100 ADJUSTER NUT
* 11917-M0100 ADJUSTER BOLT
JDM B120
FOR RADIAL COMPRESSOR (1979-_)
* 11910-G1615 BRACKET 7908-8910
* 11910-95W00 BRACKET 8910-
* 11925-G1615 IDLER PULLEY
USA B310 used either York USA-source or similar Hitachi compressor
11910-H9100 BRACKET-COMPRESSOR -0678
11910-H9101 BRACKET-COMPRESSOR 0778-
11910-H9900 BRACKET-COMPRESSOR 0879-
JDM B310 used DKKC radial compressor
11910-H7401 -8010 BRACKET-COMPRESSOR
11910-H8661 8011- BRACKET-COMPRESSOR
11925-H8900 IDLER PULLEY
JDM A10 A14
11910-H7401 BRACKET-COMPRESSOR -8003
11910-G2500 BRACKET-COMPRESSOR 8004-
11925-H8900 IDLER PULLEY 7804-
11925-M3001 IDLER PULLEY -7803
11925-W0400 IDLER PULLEY 7906- A14,Z16/Z18
11926-W0400 BRACKET-IDLER PULLEY 7906-
JDM C120
11910-G2500 BRACKET-COMPRESSOR 8106-8210
11910-G3400 BRACKET-COMPRESSOR A 8210-
11911-G3400 BRACKET-COMPRESSOR B 8210-
11910-G3401 BRACKET-COMPRESSOR 8407-
JDM C22 - high-mount pulley bracket
11910-G5100 BRACKET-COMPRESSOR
11910-G5110 BRACKET-COMPRESSOR
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Compressor_brackets"
This page has been accessed 10,230 times. This page was last modified 23:31, 18 November 2025. Content is available under Datsun 1200 Club.
