Seats
(Redirected from Bench Seat)
Category: Interior
Datsun 1200s came with front bucket seats except in a few countries where a front bench seat was available. Front seat style include: fixed, tilting (folding) and reclining. The coupe rear seat folds down. Different trim levels got different materials, namely vinyl or vinyl with cloth inserts. Sedan and Coupe seats generally differ in the cut and level of support padding. Some market like Australia produced seats locally. Head restraints were optional in some markets, but standard in USA.
Operation
1972 USA Owners manual
29364.jpg04   29365.jpg05
You can adjust the seat back to any desired position, even horizontal, by simply pulling the lever up.
  • Folding: 2-door models
  • Reclining: some models
  • Coupe rear seat folds down
Sedan DX vs Coupe DX seats
15929.jpgAlbum 15929
sedan STD,DX - fixed, straight-cut pattern. recliner OPTION
sedan GL, GX - recliner with x-pattern cloth
sedan 2-door - folding, straight cloth
coupe 2-door - folding, x-pattern cloth
truck - fixed, no recliner possible
Coupe Seats - sporty trim, but light with very little padding
22869.jpgAlbum 22869
Sedan Seats - flatter, with a bit more padding
11972.jpgAlbum 11972 5083.jpgAlbum 5083
B110 GX-5 - hi-back seat, black
KPB110 GX - hi-back seat OPTION with ovoid recliner control
* laterally-padded seats
KPB110 GL - laterally-padded seats
B210 - low-back seats with small headrest
KB210/KPB210 - hi-back seats with round recliner control
KPB210 GLL/GXL - low-back seats with small headrest
B120 1978-1989 hiback seats, BROWN
B120 1989-1994 hiback seats, Black with GREY inserts
Coupe Style
Cushions are cut in an x-pattern to make slightly bolstered. GL and GX sedans uses this style. All coupes (including Coupe DX) use this style.
Inserts have 5-rib style
Coupe DX is all vinyl
GL/GX cloth inserts
Coupe DX vinyl
22869.jpgAlbum 22869 174_5b97a76d62487.jpgPost 489417
GL sedan used coupe-style cushions with cloth inserts
Vinyl
174_68bbe5f1cce06.jpgPost 499044 174_68bbe5e8871a1.jpgPost 499044 174_68bbe5f70206f.jpgPost 499044
folding mechanism
174_68bbe5fc90127.jpgPost 499044
Highback Seats
High-back seats have the headrest portion built-in.
#GX-5 Hiback seats have GL-type cloth
#Sunny Truck Late (from 1978 April) has rounded headrest (no seam)
Unknown High-back seats
Location
Front seat risers
A seat cross member
B inside seat bracket
C outside seat bracket
23056.jpgAlbum 23056
See also: Coin Tray
Sunny Truck
Many/most/all? B120 have a fixed (non-sliding) passengers side seat rail, but all 1200 rails interchange so you can replace it with an adjustable seat rail.
1971-1978 Black low-back seats
1978-1989 Brown hi-back seats
1989-1994 Gray  hi-back seats
-7803 Early Datsun 1200 utes
* sedan seat bottom
* Truck unfinished back
* fixed (non-reclining)
* thin headrest 87700-G1001 Head Restaint Assy OPTION ALL(assist)
174_57cf6c37da883.jpgPost 481058 174_57cf6c28a5325.jpgPost 481058 4180.jpgAlbum 4180
7803-8910 - Brown high-back seat (needs no external headrest)
25638.jpgAlbum 25638
8910- Gray
16670.jpgAlbum 16670 20522.jpgAlbum 20522 25640.jpgAlbum 25640
Phillipines truck
16045_4ed5f1286857a.jpgUpload click to view
Coupe, Sedan seats fit in ute, no problem, even though they are a little thicker than truck seats
19288.jpgAlbum 19288
Catalytic Converter Seats
later seats have passenger side lower mount — to clear the catalyst bulge in the floor.
1976-1978 #B210 pictured here (1989-up #Sunny Truck is similar)
16689.jpgAlbum 16689
Connectors
A connector is used to attach the seatback.
* H10 STD FIXED connector
* H12 STD 2-DR FOLDING device [non-reclining]
* H11 DX RECLINING [+folding] black cover
* H18 GL,GX RECLINING [+folding] chrome cover
GL/GX RECLINING device
174_5b97a76360d68.jpgPost 489417
FIXED Connector early | mid-model ute
Stock Seats
DX is all vinyl
174_67e768b426089.jpgPost 498833
GL seats have cloth inserts
13933.jpgAlbum click to view
Stock Seats
5083.jpgAlbum 5083
Standard, Deluxe and Reclining Seats
1555.jpgAlbum 1555
GX Seats
456.jpgAlbum 456
DX Seats
620.jpgAlbum 620
Recovered Seats
765.JPGAlbum 765
Aussie-Market
STD
11971.jpgAlbum 11971
2517.jpgAlbum 2517 2516.jpgAlbum 2516 1207.jpgAlbum 1207 1413.jpgAlbum 1413
1200 Coupe seats (custom fabric) in Datsun 1000
3537.jpgAlbum 3537
3512.jpgAlbum 35124487.jpgAlbum 4487
Ute
Australia-market B120 seats are not suitable for sedans as the back is not finished, but are extra thin compared to sedan seats with a slim-profile headrest. JDM seats are same/similar.
The rear of the seats (all years) have a rubber bumper for the rear panel.
08513-41612 SCREW, pan head tapping M4x16 + 86805-15400 RUBBER PACKING
Bench Seat
120Y bakkie and 1400 bakkie (B140) came with a 3-passenger bench seat
16135.jpgAlbum 16135
7-passenger bench seating
19822.jpgAlbum 19822
Retrofit
ud_4771-img600x450-13084554571odvv046865.jpgPost click for topic ud_4771-img600x450-13084554565vjtmb46865.jpgPost click for topic ud_4771-img600x450-1308455540lyfjld47224.jpgPost click for topic
Mazda 1000 Bench seat which has been retrimmed
IMG_3211.jpgPost click for topic
Split-bench seat idea
ud_4771-img600x450-13084554571odvv046865.jpg ud_4771-img600x450-1308455540lyfjld47224.jpg ud_4771-img600x450-13084554565vjtmb46865.jpg
North America
Canada & USA models
* 1973 models had blue or beige seats.
  Black was available (again) on from 0173
* 1971-1972 models:
  * Coupe: Black, Beige or (optional) Yellow
  * Sedan: Black, Yellow, Gray
* Reclining seats standard  on coupe
* Sedan had reclining seats OR folding non-reclining seats with (optional)
* Sedan had some sort of optional front seats
1973 black?
174_5b9ce2d03ac88.jpgPost 489451 174_5b9ce2df27346.jpgPost 489451 174_5b9ce2f204a49.jpgPost 489451 174_5b9ce366a4ad9.jpgPost 489451 174_5b9ce37c0955f.jpgPost 489451 174_5b9ce38390f10.jpgPost 489451174_5b9ce36fd280c.jpgPost 489451
Occupant Sensor for Seat Belt Warning System
Parts
  • 86982-A0600 Eyelet 'A' Seat Back $1.12
  • 86983-A0600 Eyelet 'B' Seat Back $0.85
  • 87550-H1603 Slide-seat LH $44.33
  • 87500-H1603 Slide-seat RH
  • 87400-M3000 Hinge-recline RH $179.58
  • 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
  • 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FIX TO SLIDE
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors sometimes called coin trays. These fit above the floor just to the outside of each seat.
GX-5
#Highback seats have the headrest portion built-in, and were factory fitted to Datsun 1200 GX-5 sedans and coupes.
GX-5 front bucket seat
* high-back style with integrated headrest
* same five-rib pattern as all Coupe/GL type seats
* basically is GL seat with a different back
174_68bbdde0758c8.jpgPost 499043
Sedan & Coupe are same seat per Catalog C-231, but contrary to this are listed as having different cushions:
* Coupe: H41 coupe GL cushion
* Sedan: H33 sedan GL cushion
174_5b989c4398be0.jpgPost click for topic 174_5b989c57e3ac9.jpgPost 489428 174_5b989cd0bea8c.jpgPost 489428 174_5b989caca9ae1.jpgPost 489428 174_5b989ca31ea13.jpgPost 489428 174_5b989c671fb82.jpgPost 489428 174_5b989c87e0811.jpgPost 489428 174_5b989cded8493.jpgPost 489428 174_5b989ce6670e0.jpgPost 489428
Facelift
H33 SEAT COMPLETE GL SEDAN
H34 SEAT COMPLETE GX SEDAN
H41 SEAT COMPLETE GL COUPE
H42 SEAT COMPLETE GX COUPE
H72 SEAT COMPLETE GX-5 COUPE/SEDAN
H42 CUSHION ASS'Y GX COUPE
H41 CUSHION ASS'Y GL/GX-5 COUPE
H33 CUSHION ASS'Y GL/GX-5 SEDAN
H34 CUSHION ASS'Y GX SEDAN
PB110
Sunny Excellent PB110 seats are exactly like regular 1200 seats except for the colors and fabric style are upscale designs. They even use the same seat #Connectors, #Rails and Headrests.
1970-1971 1400 Coupe
H25 DX inserts have a center double-stripe
H26 GL inserts have four horizontal sections
H27 GX inserts have three vertical sections
1970-1971 1400 Sedan
H28 DX inserts have three stripes
H29 GL is like Coupe GL, includes H26 cushions
H30 GX is like Coupe GX, includes H27 cushions
1971 seats
174_5b98c31f8b1f3.pngPost 489432
Sedan DX
852.jpgAlbum 852
Sedan
174_65af5aaae95c5.jpgPost 498207
Coupe GL
174_65ae3c804d3cc.jpgPost 498206
Sedan GL?
Sedan GX Striped fabric brown & black
11438.jpgAlbum 11438 456.jpgAlbum 456 23413.jpgAlbum 23413
Sedan GX — with non-standard fabric?
174_5b98b1f667555.jpgPost 489431 174_5b98b22d317b0.jpgPost 489431 174_5b98b2750bab2.jpgPost 489431 174_5b98b25573103.jpgPost 489431 174_5b98b29320f08.jpgPost 489431
OPTION high-back seats (like #GX-5 but with GX-type plaid fabric) | OPTION Coupe GX
11444.jpgAlbum 11444 174_5b98c6b9ec130.pngPost click for topic
174_65af58cd70f68.jpgPost 498207
B310
B310 seats are very similar to B110 seats, but the front seats are slightly bigger with different frame rails. The rear seat fits but not perfectly.
30872.jpgbrochure
Upholstery
STD/DX  Vinyl Leather (black or yellow)
GL      fabric insert (black or blue Tricot)
GX      plaid insert  (brown or black)
Headrests
Main: Headrests
Alternative Seats
Factory non-1200 Bucket Seats
Sport Seats
Recaro Seats
Vintage
Racing Seats
Aftermarket seats
Seat Rails
Adapting Seats
Many, many seats will fit into your Datsun 1200.
Rear Seats
Main: Rear Seat
Datsun 1000 Seats
See Also
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Seats"
This page has been accessed 162,649 times. This page was last modified 14:03, 7 October 2025. Content is available under Datsun 1200 Club.
