Search results
For query "Front"
There is no page titled ":Front". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Front Suspension (3274 bytes)
    1: ...s that most B210 front suspension, front axle and front brake parts do not interchange with B110.
    5: In the Nissan parts catalog, the [[Brakes]] and [[Front Axle]] (strut, hub) are in different section. The...
    8: * [[Front Suspension Specification]]
    31: * 54401-H3900 (formerly 54401-H1000) Front Suspension Member assembly (engine crossmember)
    37: * 54611-H1002 front stabilizer torsion bar (except GX)
  2. Front Axle (620 bytes)
    1: ...nd '''knuckle arm''' (steering arm) complete the "Front axle".
    6: See main article: [[Front Suspension]]
    17: [[Category:Front Axle And Front Suspension]]
  3. Front Suspension Adjustment (261 bytes)
    1: [[Category:Front Axle And Front Suspension]]
  4. Front Fender and Front End (2183 bytes)
    1: ...pport]], completing the box-like structure of the front sheet metal (the [[Engine Bay]]). And as you migh...
    14: Ledge with Tower | 12 - Hood Ledge [[Front Body Panels Part Numbers]]
    19: * {{pn|Front_Body_Panels_Part_Numbers|64100-H1000}} HOOD LEDGE...
    23: * {{pn|Front_Body_Panels_Part_Numbers|64100-H3100}} HOOD LEDGE...
  5. Front Suspension Specification (2614 bytes)
    8: = Factory Front Suspsension Specifications =
    58: [[Category:Front Axle And Front Suspension]]
  6. Front Combination Lamp (9117 bytes)
    1: {{BackTo|Lighting_System|Front_Lights}}
    3: All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck...
    6: ...un 1200 was fitted with four or five different '''Front Combination Lamps''', depending on the year and c...
    19: All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck...
    64: Front running light lenses are either all-orange or whi...
  7. Front Combination Lamp Part Numbers (3043 bytes)
    2: [[Front Combination Lamp]]
    8: FRONT COMBINATION LAMP to 1973-8
    9: 26120-H1000 LAMP ASS'Y-front combination (R.H.) (ICHIKO)
    10: 26125-H1000 LAMP ASS'Y-front combination (L.H.) (ICHIKO)
    11: 26120-H1010 LAMP ASS'Y-front combination (R.H.) (KOITO)
  8. Front Drum Brake Part Numbers (1235 bytes)
    3: [[Front Drum Brake]]
    6: FRONT DRUM BRAKE (exc. GL, GX)
    7: 41020-18032 ASS'Y-BRAKE, front (R.H.)
    8: 41030-18032 ASS'Y-BRAKE, front (L.H.)
    12: 41100-18001 ASS'Y-CYLINDER, front wheel, fore (R.H.)
  9. Front Axle Part Numbers (3467 bytes)
    3: [[Front Axle]]
    7: [[Brakes|Front Brake Drum]] & [[Brakes|Brake Rotor]]
    13: 1 40018-18000 COLLAR-SPINDLE FRONT (2)
    14: 2 <s><strike>08114-06510 NUT-LOCK FRONT WHEEL BEARING (2)</strike></s>
  10. Front Suspension Part Numbers (3971 bytes)
    3: [[Front Suspension]]
    7: 1 54401-H3900 ASSY-MEMBER FRONT SUSPENSION 1171- 2 54401-H1000
    8: 54401-H1000 ASSY-MEMBER FRONT SUSPENSION
    24: 13 54470-H1000 ROD-TENSION FRONT SUSPENSION RH
  11. Front Body Panels Part Numbers (7252 bytes)
    27: 4 62610 APRON-FRONT PANEL
    41: 9 63100 FENDER-FRONT,RH
    48: 10 63101 FENDER-FRONT,LH
    108: From 1985 April FRONT BODY FITTING
    121: 4 62612-H1000 PANEL-APRON,FRONT SEDAN
  12. Front Door Part Numbers (9892 bytes)
    10: FRONT DOOR (4 DOOR SEDAN)
    11: 1 80102-H1000 ASS'Y-PANEL, front door (R.H.)
    12: 80103-H1000 ASS'Y-PANEL, front door (L.H.)
    13: 2 80210-H1001 ASS'Y-SASH, front door (R.H.)
    14: 80211-H1001 ASS'Y-SASH, front door (L.H.)
  13. Front Door Fitting Part Numbers (4999 bytes)
    15: 3 80502-H1201 ASSY-DOOR LOCK FRONT RH SEDAN 2 DOOR
    16: 3 80502-H3600 ASSY-DOOR LOCK FRONT RH SEDAN 2 DOOR
    17: 4 80503-H1201 ASSY-DOOR LOCK FRONT LH SEDAN 2 DOOR
    18: 4 80503-H3600 ASSY-DOOR LOCK FRONT LH SEDAN 2 DOOR
    38: 22 80605-H1900 ASSY-HANDLE DOOR OUT SIDE FRONT RH SEDAN 2 DOOR
  14. Front Door Trim Part Numbers (8144 bytes)
    11: FRONT DOOR TRIMMING (4 DOOR SEDAN)
    13: 39 80900-H1000 ASS'Y-FINISHER, front door (R.H.) 4S, 4ST
    14: 40 80900-H1100 ASS'Y-FINISHER, front door (R.H.) (&#40658; black) 4D, 4DT, 4GT, 4DA, 4...
    15: 80900-H1101 ASS'Y-FINISHER, front door (R.H.) (&#40644; yellow) 4D, 4DT, 4DA
    16: 80901-H1000 ASS'Y-FINISHER, front door (L.H.) 4S, 4ST
  15. Front Seat Part Numbers (17974 bytes)
    9: [[Front Seat]]
    85: 87556 BRACKET ASSY-FRONT SEAT, LH
    91: 1 87000-H1303 COMP-SEAT,FRONT FOLDING R.H (YELLOW) SEDAN 1270-1171
    92: 1 87000-H1302 COMP-SEAT,FRONT FOLDING R.H (BLACK) SEDAN 0170-1171
    93: 1 87000-H7001 COMP-SEAT,FRONT RECLINING RH(BEIGE)WITH SEDAN 0772-
  16. Front bar (88 bytes)
    3: [[Front Bumper]]
  17. 120Y Front Suspension (7983 bytes)
    4: Early 120Y used the exact same front strut assembly as the B110 -- except for the stru...
    35: 54302-H5025 STRUT KIT-front suspension (Atsugi) 2
    37: 54302-H5125 STRUT KIT-front suspension (R.H.) (Atsugi)
    38: 54303-H5125 STRUT KIT-front suspension (L.H.) (Atsugi)
    49: STRUT KIT-front suspension
Page text matches
  1. Datsun 1200 encyclopedia (3415 bytes)
    28: ...ry:Front Axle And Front Suspension|Front Axle And Front Suspension]]
  2. History of Datsun 1200 (16941 bytes)
    33: * 1983-present front-wheel drive {{wiki|Nissan Sunny}} (B11-B15)
    81: .... The new Sunny sported {{wiki|MacPherson strut}} front suspension and the A series engine had grown to 1...
    84: The biggest change was to front-wheel-drive starting in 1983 with the B12 model. ...
    86: ...yclopedia in on Datsun 1200, we won't discuss its front-wheel-drive descendents in very much detail.</blo...
    94: ...the presence of side marker lights mounted in the front edge of the fenders. Three main specifications we...
  3. Movies (20445 bytes)
    134: ...ife, there's a brown 1200 Coupe that pulls out in front of his neighbor, then slams the brakes on. Being ...
    178: ...e parked in supermarket lot. It has a dent in the front fender. Dealer pinstripe?
    298: ... while a purse snatcher is brutalizing himself in front of Sledge.
  4. Nissan Parts (563 bytes)
    8: 80834-H1000 Spacer - Weatherstrip. Front door RH
    9: 80835-H1000 Spacer - Weatherstrip. Front door LH
  5. 5-Speeds (19568 bytes)
    272: ...and lubrication system is improved. Countershaft, front main bearing and main shaft bearings are stronger...
  6. Racing History (26063 bytes)
    176: ...Torque 14.0 kg at 7000rpm. Starlet is fitted with front and rear spoilers, tubular a-arm suspension and a...
  7. Engine Swaps (25981 bytes)
    238: ...ndle curvy roads too well with all that weight up front, but that's not the point of this, eh?
    257: Ford Essex V6? (front-distributor engine)
    282: ...emoved from the engine and a pusher fan placed in front of the radiator.
    284: ...B engine in Bakkie. Plenty of room for radiator & front mounted intercooler
  8. Heater (11725 bytes)
    24: ...embled]] B110 used a Nissan heater by Smiths. The front cover is fastened with screws instead of clips li...
    93: * 27017-B8520 COCK- ASSY-FRONT HEATER 7510- B120
    122: 27013-H1001 CORE ASSY-FRONT HEATER
    132: In this photo the front (long) heater hose is the original braided type, ...
    158: ...{{searchPart|27021-H1000}} HOSE-WATER [to outlet, front of engine] $7.50
  9. Strut Insert Part Numbers (10856 bytes)
    1: [[Strut]] Inserts (shock absorbers) for the front suspension: Datsun 1200 (B110) uses 45 mm diamete...
    4: The 1200 front shock absorbers [[Strut#Rebuilding_Strut|can be r...
    18: ...'cartridge' insert) is the way to retain a smooth front-end ride. However, these kits are no longer manuf...
    22: * 56105-H5025 CARTRIDGE-ABSORBER,SHOCK, FRONT
    31: * 56110-H1025 KIT-ABSORBER SHOCK FRONT (ATSUGI)
  10. A12GX Engine (12809 bytes)
    87: * [[Water pump]] inlet pipe at front of block (PIPE-suction, water pump) has an additi...
    169: * accelerator clip is on front pad, not rear
    170: * fuel line clip boss is on rear left side, not front left side
    178: * A12: front and rear bosses
  11. Rear Axle (11788 bytes)
    270: ...nd brake cable from the adjustment block near the front of the diff
    272: # Disengage the brake line which is in front of the diff
  12. Rear Axle Swaps (24650 bytes)
    68: ...ited-slip) and the diff assembly unbolts from the front of the axle assembly (like Ford 9", but much smal...
    204: ...ount. So you can use the same offset (fwd) wheels front and rear without looking kinda silly and undertyr...
    246: * [{{Post|6346}} Datsun 620 (pickup)] front axle assembly with LSD
    354: ...cated in the engine compartment (Hilux) or by the front seat (Hiace).
    422: ...ell as most Subarus. The [[R180]] was used in the front axle of Datsun 4x4 trucks (720, etc).
  13. Emission Controls (28459 bytes)
    166: * 8504-8910 second delay valve added inline near front of rocker cover
    202: ...unted on the front of the intake manifold just in front of the carburetor.
    345: ...nto a passage drilled lengthwise in the head from front to back, and which has cross-passages drilled to ...
  14. Parts Sources (15979 bytes)
    89: ...al "flasher" unit]], [[Wiring|fuses]], [[Oil]], [[Front Axle|Wheel bearing grease]], [[Automatic Transmis...
  15. Part Numbers Index (8259 bytes)
    6: ... & Pan Part Numbers|Block & Pan]] CYLINDER BLOCK, FRONT COVER & OIL PAN
    55: [[Front Axle Part Numbers|Front Axle]] & ROAD WHEEL & TIRE
    56: [[Front Suspension Part Numbers|Front Suspension]] STRUT, SHOCK ABSORBER
    62: [[Front Drum Brake Part Numbers|Front Drum Brake]]
    96: ...art Numbers|Battery]] (for Battery Mounting see [[Front Body Panels Part Numbers]])
  16. GX-5 (8005 bytes)
    28: {{wikiFile|3/31|1972_Datsun_Sunny_B110_GX-5%2C_front_left.jpg}}
    80: The GX-5 package includes unique seats. Fronts are black '''highback''' seats with black cloth ...
    87: FRONT SEAT (4 GX 5speed)
  17. Strut photo index (3157 bytes)
    3: </div>[[Category:Front Axle And Front Suspension]]
  18. Clutch (17014 bytes)
    174: ...er to cover the lower portion of the transmission front cover.
  19. Fuel Injection (19606 bytes)
    239: Wolf crank sensor on the front pulley
    364: ... or 2) fit a "swirl pot" (anti-[[Surge Tank]]) up front with low pressure fuel pump supplying that.
    366: ...g to the tank and run a new return line up to the front. Or a return fitting can be Teed into the filler ...
  20. Ignition Switch (12669 bytes)
    217: <br>NOTE: The two wires at the front of the Lock Cylinder are for the [[Key Warning Bu...
Search in namespaces :
List redirects   Search for
