There is no page titled ":Lighting". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Lighting System (2956 bytes)
101: {{Main|Lighting System Diagnoses}} - Lighting System Diagnoses (1422 bytes)
1: Lighting system problems can be caused by many things. So ... - Side Lighting Parts Numbers (1685 bytes)
- Lighting Switch (2655 bytes)
6: RHD and LHD 1200s use the same lighting switch (except Australia). However the wiring har...
16: LIGHTING SWITCH
20: (1) Remove connector from back of the lighting switch.
22: (2) Depressing the lighting switch knob, turn it counterclockwise, and remove...
24: (3) Loose the escutcheon, and remove the lighting switch from the cluster lid.
Page text matches
- Parts Sources (15979 bytes)
89: ... which are not specific to Datsun: [[Battery]], [[Lighting System|headlights (standard 2-headlight units), d... - Part Numbers Index (8259 bytes)
100: [[Side Lighting Parts Numbers|Side Lighting]] SIDE MARKER LAMP - Lamp Wiring (8455 bytes)
1: The lighting circuits generally use Green wires. Newer 1200 ut...
9: The lighting circuits generally use Green wires:
16: [[Lighting Switch]] and [[Turn signal switch]] circuits
33: When the [[Lighting Switch]] is pulled out one or two stops, these li...
40: ...is supplied to the main Green/Blue wire via the [[Lighting Switch]]. - Lighting System (2956 bytes)
101: {{Main|Lighting System Diagnoses}} - Alternator (7571 bytes)
166: ...f you are running high-power headlights, off-road lighting systems, or high-power stereo gear, using a high ... - Parts interchange (3718 bytes)
25: * [[Headlights]] and other [[Lighting System|light bulbs]] - FMVSS (10934 bytes)
74: = Lighting = - Matsuoka (882 bytes)
8: GX-style [[Mirrors]], [[Lighting System|taillights]], chromed [[Grille]], Suspensi... - Options (10139 bytes)
52: ** 25160-H1010 ASS'Y-SWITCH-lighting & fog lamp GL
53: ** 25160-H1110 ASS'Y-SWITCH-lighting & fog lamp GL - South Yokohama (1210 bytes)
18: [[Badges]], tailgates, GX-style [[Mirrors]], [[Lighting System|taillights]], chromed radiator [[Grille]],... - Instruments and Controls (12492 bytes)
232: Also see: [[Lighting Switch]] - Dashboard removal (7203 bytes)
103: ...n place mostly by the knobs (Radio, Wiper Switch, Lighting Switch and Choke). - Headlight Wiring (9056 bytes)
14: * [[Lighting Switch|Light Switch]]
36: RHD and LHD use the same [[Lighting Switch]] with a 6-spade-connector. But for LHD ap...
111: R: Lighting fuse
121: ...dlight relay, instead full power goes through the lighting switch and the dash harness. But a serious peform... - Bumper (11597 bytes)
124: ...model, and are distinguished by the license plate lighting provision. [[PB110]] used the same rear bumpers a...
227: == License Plate Lighting ==
230: ...th its dual lamps was already bright enough). The lighting moved from the bumper to near the plate. - Fenders (4252 bytes)
6: ... side lamps, to meet [[FMVSS#Lighting|FMVSS 108]] Lighting Standard of 1970 - Headlights (14408 bytes)
1: {{BackTo|Lighting_System|Headlights}}
10: * [[Lighting_System#Headlights|Lighting System]] for specifications
196: ....3.5 Type D headlighting system. (a) A Type D headlighting system consists of two Type 2D1 headlamps ...
383: [[Category:Lighting System]]{{End}} - Trim (9361 bytes)
192: * [[Lighting System|Backup Lights]] - Minor Maintenance (1176 bytes)
22: * [[Lighting System#Headlights|Headlights]]
23: * [[Lighting System|Directional lights]]
24: * [[Lighting System#Rear License Plate Lamp|License plate ligh...
25: * [[Lighting System|Side marker lights]] - Chrome Trim (1561 bytes)
12: * [[Lighting System|License Plate Lamps]]
22: * [[Lighting System]] side light surrounds - Lighting System Diagnoses (1422 bytes)
