There is no page titled ":Tire". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Changing tire (1135 bytes)
20: [[Category:Wheel And Tire]][[Category:Maintenance And Daily Care]] - Wheel and Tire (7619 bytes)
3: {{See|Tires}}
5: '''[[1972#Wheel_and_Tire|Wheel and Tire]]''' is a section in the Datsun 1200 [[owners man...
8: {{OwnersManual|26|27|<hr>'''[[Wheel and Tire]]'''
10: ... Tire pressure lower than recommended will reduce tire and ride qualities.
12: ... the life and ride of the vehicle, because "hard" tires tend to magnify rather than absorb road shocks a...
Page text matches
- Datsun 1200 encyclopedia (3415 bytes)
31: * [[:Category:Wheel And Tire|Wheel And Tire]] - Racing History (26063 bytes)
110: * Tires: 7.0/21.0-13, 7.4/21.8-13
237: ...21407;光 Hikari Hagiwara No. 2 Sugimoto Tire Torii Sunny
247: ...3798;良夫 Yoshio Kojima No. 34 Kosugi Tire Bell R Sunny
293: ...7425;郎 Shimoda Jiro No. 9 Hawk Hagi Tire Torii Sunny
297: ...3538; Sato Shigeru No. 6 Friend Fraternity Tire Shop Sunny - Engine Swaps (25981 bytes)
82: ...ay the A15 is 7% larger displacement across the entire RPM range. I'll trade a 1% peak power disadvantag...
352: Tire-smokin' fast no-petrol Datsun 1200s. It's Electri... - Rear Axle (11788 bytes)
87: ... the best all-around ratio for the stock-diameter tires, balancing enough torque for take-off with incre...
103: ...g it will top out about 80 mph with the stock 12" tire diameter. - Part Numbers Index (8259 bytes)
55: ...ont Axle Part Numbers|Front Axle]] & ROAD WHEEL & TIRE
57: ...Rear Axle Part Numbers|Rear Axle]] & ROAD WHEEL & TIRE - Nissan Part Numbers (8833 bytes)
38: ...tr><tr><td valign=top>57</td><td valign=top>Spare tire section</td></tr><tr><td valign=top>60</td><td va... - PB110 (13462 bytes)
1: ... of the PB110 are the same as B110, including 12" tires and same dashboards.
124: == Wheel and Tire ==
125: As with all B110, the PB110 Excellent used 12" tires. - 56-Series Transmission Parts (14945 bytes)
451: * 32010-H5251 TRANSMISSION ASSY B210 GFK ratiol tire
452: ...H5253 TRANSMISSION ASSY B210 GFK from 73-10 ratio tire - Wheels (18326 bytes)
25: <tr><td>tire size</td><td>?-12</td><td>6.00-12<br>155SR-12</td...
122: * Tire balancing weight: 10-70 gr (0.35-2.47 oz), spacin...
127: ...s center line). This offset perfectly centers the tire inside the wheel well.
129: ...5-width tire or a wider 165-width tire. Any wider tire, such as 175-width, requires a 5" wide wheel to m...
132: * Choosing Wheel Offset for wide tires - Tires (15252 bytes)
1: ...nsion travel and clearance with no rubbing of the tire on the body.
4: USA Sales Window Sticker (w/w tires -- no charge)
7: The largest width tire that fits a stock 1200 body are:
16: ...le 16" will fit better than a regular-profile 13" tire. Yes, a 205/40R16 is smaller in height than a 155...
18: USA 1200 whitewall tire - [[Bridgestone]] Skyway-II 6.00-12 - Repair Manual (20350 bytes)
184: ...safety, tools explanation (nice photos of tools), tire and spark plug troubleshooting photos. They even ... - Tune-up (10772 bytes)
23: # Check [[Tires|tire]] pressures when cold (driving less than 1 mile)....
79: ... disconnected and capped</td></tr><tr><td><strong>Tire Pressures</strong></td><td>B110 - 6.00-12</td><td... - Owners manual (9135 bytes)
41: [[1972#Wheel_and_Tire|Wheel and Tire]]
76: [[Tires#Daily Care|Wheel and Tire]]
203: * Braking, acceleration and tire load [[Performance]] statistics for B110 (1200), ... - B20 (4330 bytes)
22: size: B20 tray fits entirely within Hilux tray
99: white sidewall tire - Brake Swaps (21279 bytes)
9: * Coilover swaps permit wider tires
17: * Large or wide [[Tires#Wide_Tires|tires]] will improve brake contact patch and so are a ...
19: ...the application of the car weight bias, brake and tire sizes (See [[Brake Proportioning]]). For mismatch...
20: * Bigger tires. Yes, this has a big effect on brakes, because m... - 1/4 mile time log (25722 bytes)
120: * WHEEL/TYRE package: Standard Road Tires 14"
186: ...eel/ Tyre package:shorter-than-stock tires, wider tires (165/55-R12)
311: * TIRE/WHEEL package:155/80/12 - OEM (1595 bytes)
1: ...to Nissan. Or converserly, since Nissan sold many tires for Bridgestone, Bridgestone would consider Niss...
10: ... exception to this is tires: In the USA at least, tires are warranted separately from the rest of the au...
17: * {{wiki|Bridgestone}}, Japan's premier tire supplier
18: ** Tires - B210 Parts Donor (3999 bytes)
22: * A12 models -- entire 56-series Transmission
25: * [[Wheels]], 12" as-is, 13" with tire change
26: * [[Tire Sizes|Tires]] (13" tires require corresponding 13" wheels) - B310 (13887 bytes)
375: tire edge to body edge - FMVSS (10934 bytes)
35: * 68-01 Standard No. 109 New Pneumatic Tires for Passenger Cars
36: ** the famous "DOT" approved tire standard
37: * 68-04 Standard No. 110 Tire Selection and Rims for Passenger Cars
