Mazda rotary engine swap
Revision as of 21:32, 15 October 2016; view current revision
Categories: Engine Modifications | Engine Swaps
The Mazda rotary engine is a good match for Datsun 1200 -- it is light and compact. It makes more power than a piston engine of the same size and weight. The engine weight is down low so it doesn't interfere with good handling.
Performance
Also See: wikipedia:Mazda Wankel engine
Typical engine power in stock form:
  • 12A: 100-130 HP, 100-115 lb. ft. torque
  • 13B EFI: 135 hp, 133 lb. ft. torque
  • 13B-Turbo (1987-1991 "Turbo II"): 185-200 HP
  • 13B-REW (twin turbo) 255-280 hp
  • 13B-MSP (RX-8) 237 hp USA, 191-250 hp world
Quarter Mile acceleration performance ranges from quick to insanely quick. With a totally stock rotary engine you won't be wanting for power.
  • 19.8 secs at 65 mph: Stock Datsun 1200 piston engine (baseline)
  • 16.1 at 90mph: bone stock 12A rotary engine tuned by ear
  • Ange's 13.7 second 12A bridgeport
  • JVML's 8.1 second 13B twin turbo
Rotor Power
6353.jpgAlbum 6353
Discussions
Engine
The Mazda rotary comes in two common sizes: 12A and 13B. In Australia, choose a 10A for street legal swaps. Everyone else, choose the 13B. There are less common versions, the old 10A and the ultra-rare and expensive 20B triple rotor.
8040.jpgAlbum click to view 12A
158.jpgAlbum click to view Mazda 13B carbureted
15021.jpgAlbum click to view 13B Fuel Injected
93.jpgAlbum click to view Mazda 13B Turbo rotary engine
2050.jpgAlbum click to view Factory EFI 13B Turbo
3008.jpgAlbum click to view 13B Turbo with factory intercooler
14572.jpgAlbum click to view 20B triple rotor
Engine Mounts
Front Mount
Most use the front-mount case. If your rotary doesn't have it, you can retro-fit it using a 12A timing cover (which fits on 13B).
1787.jpgAlbum click to view 2616.jpgAlbum click to view 2700.jpgAlbum click to view 2701.jpgAlbum click to view 2702.jpgAlbum click to view 2703.jpgAlbum click to view 15144.jpgAlbum click to view 20618.jpgAlbum click to view
Template:PhotoPostH Template:PhotoPostH
Side Mount
Cut out about 10mm out of the standard 1200 crossmember and brace it. Weld new custom-made brackets.
5448.jpgAlbum click to view
Cutcut_zps954618cf.jpgPost click for topic
Mad Dat 13BT Fitting Kit allows the newer-type rotary engine side mount, their crossmeber curves down so the top of the cross member is lower.
Datrotor fabricated these for a 13B:
d06cfa0b.jpgPost click for topic
Motor Plate
For racing a motor plate can be used. Not recommended for a street car as it transmit vibration directly to the body.
2915.jpgAlbum click to view
Oil Pan
Use the Moroso oil pan for Datsun 1200.
24941.jpgAlbum 24941
Transmission
Use the transmission that comes with the rotary engine (the Mazda transmission).
19869.jpgAlbum click to view
Driveshaft
A custom driveshaft to mate the Mazda transmission with your differential will have to be fabricated. Any driveshaft shop can make this for you.
Shifter
A new shifter mount hole may need to cut? Look into doing the shifter extension mod otherwise your shifter will be a little bit to far back for comfort (it will sit in between the front seats right in front of the handbrake).
15141.jpgAlbum click to view
Transmission Mount
Mount the gearbox the with a similar bracket to ca18 one.
9423.jpgAlbum click to view
or make a new gearbox crossmember:
IMG_20130115_192832.jpgPost click for topic
Tunnel
Some fabricate a large tunnel. Is it necessary, or just used with beefy racing transmissions?
In any cause, you'll have to make the tunnel higher through the middle and make space for the clutch fork, or cut a hole for the clutch fork.
11107.jpgAlbum click to view 1788.jpgAlbum click to view
Alternatively you can fit an aftermarket hydraulic throwout bearing to replace the clutch fork.
Differential
The least 12A engine outputs 100 lb. ft. of torque. The stock Datsun 1200 H145 diff can handle that.
But many 12A put out 115 lb. ft. of torque, which calls for a stronger diff. The H150 from a B210 or B310 can handle this.
Stock 13B engine calls for an H165.
Any modified rotary (especially if the turbo boost is raised) will need a stronger differential, such as a Nissan H190. Drag racing versions need the ultra-strong Ford 9".
See: Rear Axle Swaps
Exhaust
For the 13BT, run headers to the rear firewall across to the passenger side.
93.jpgAlbum click to view 158.jpgAlbum click to view 383.jpgAlbum click to view 581.jpgAlbum click to view 912.jpgAlbum click to view 959.jpgAlbum click to view 965.jpgAlbum click to view 1078.jpgAlbum click to view 1384.jpgAlbum click to view 1539.jpgAlbum click to view 1540.jpgAlbum click to view 1547.jpgAlbum click to view 1549.jpgAlbum click to view 1756.jpgAlbum click to view 1757.jpgAlbum click to view 1787.jpgAlbum click to view 1788.jpgAlbum click to view 1820.jpgAlbum click to view 2049.jpgAlbum click to view 2050.jpgAlbum click to view 2065.jpgAlbum click to view 2066.jpgAlbum click to view 2067.jpgAlbum click to view 2237.jpgAlbum click to view 2558.jpgAlbum click to view 2616.jpgAlbum click to view 2681.jpgAlbum click to view 2700.jpgAlbum click to view 2701.jpgAlbum click to view 2702.jpgAlbum click to view 2703.jpgAlbum click to view 2848.jpgAlbum click to view 2914.jpgAlbum click to view 2915.jpgAlbum click to view 3008.jpgAlbum click to view 3078.jpgAlbum click to view 3427.jpgAlbum click to view 3483.jpgAlbum click to view 3548.jpgAlbum click to view 3549.jpgAlbum click to view 4484.jpgAlbum click to view 4486.jpgAlbum click to view 4655.jpgAlbum click to view 4694.jpgAlbum click to view 4949.jpgAlbum click to view 5006.jpgAlbum click to view 5448.jpgAlbum click to view 5979.jpgAlbum click to view 5980.jpgAlbum click to view 6353.jpgAlbum click to view 6757.jpgAlbum click to view 7226.jpgAlbum click to view 7374.jpgAlbum click to view 7690.jpgAlbum click to view 7697.jpgAlbum click to view 7698.jpgAlbum click to view 7699.jpgAlbum click to view 7700.jpgAlbum click to view 7703.jpgAlbum click to view 7704.jpgAlbum click to view 8040.jpgAlbum click to view 8051.jpgAlbum click to view 8320.jpgAlbum click to view 8467.jpgAlbum click to view 8469.jpgAlbum click to view 8472.jpgAlbum click to view 8555.jpgAlbum click to view 8557.jpgAlbum click to view 9422.jpgAlbum click to view 9423.jpgAlbum click to view 9501.jpgAlbum click to view 9550.jpgAlbum click to view 10801.jpgAlbum click to view 11107.jpgAlbum click to view 11246.jpgAlbum click to view 11284.jpgAlbum click to view 11285.jpgAlbum click to view 12605.jpgAlbum click to view 13279.jpgAlbum click to view 13280.jpgAlbum click to view 13837.jpgAlbum click to view 13961.jpgAlbum click to view 14572.jpgAlbum click to view 14573.jpgAlbum click to view 14574.jpgAlbum click to view 15021.jpgAlbum click to view 15028.jpgAlbum click to view 15129.jpgAlbum click to view 15141.jpgAlbum click to view 15144.jpgAlbum click to view 15356.jpgAlbum click to view 15642.jpgAlbum click to view 15696.jpgAlbum click to view 16118.jpgAlbum click to view 16120.jpgAlbum click to view 16180.jpgAlbum click to view 16373.jpgAlbum click to view 17281.jpgAlbum click to view 17292.jpgAlbum click to view 17294.jpgAlbum click to view 18150.jpgAlbum click to view 18226.jpgAlbum click to view 18344.jpgAlbum click to view 18345.jpgAlbum click to view 18692.jpgAlbum click to view 18695.jpgAlbum click to view 18818.jpgAlbum click to view 18819.jpgAlbum click to view 19867.jpgAlbum click to view
13btestfit_zps9fc1baa3.jpgPost click for topic
