Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Genuine Nissan badges are metal or plastic depending on the year made.
Various early B110 Sunny Emblems (Japan)
1972 JDM Facelift emblems
Market Differences
- Japan market 1200s used "Datsun", "S" badges and "Sunny" badges
- Export market 1200 used "Datsun", "D" badges
Colors
Most badges, especially the script ones, are simple silver color.
Sedan "S" and "D" grille emblems have red and blue bars:
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
Some are faded after all this time:
Most are faded to no color after 40 years:
Coupe
See main article: Coupe Badges
Sedan
Grille
Center Ornament
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
Grille Left Side Badge
EARLY LEFT SIDE GRILLE
FACELIFT LEFT SIDE GRILLE BADGES
62330-H3125 EMBLEM SET-radiator grille "DELUXE"
compare to rear badge
84823-H1000
62330-H3325 EMBLEM SET-radiator grille "GL"
compare to early rectangular badge
62330-H3425 EMBLEM SET-radiator grille "GX"
compare to early wide badge
or rear see-through badge
62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
84823-H7200
Side
C-pillar Emblem
Rear
Left Rear Deluxe - differs from similar looking front facelift badge
Left Rear GL - photo needed 84823-H2001 early, 84823-H3300 1972
Left Rear GX "see-through" script (compare to front GX badges which have a background attached)
GX 5-Speed 84823-H7200
compare to front facelift badge
NOT 1200: This is early 610 84821-U1200 MARK-trunk lid '5-SPEED'
Center Rear (left of license plate)
Sports badge
Early "Full Automatic" 79200-H1020
Late "Full Matic" 79200-H2820 from '71 April, 79200-H3200 1972
Unknown badge - What is the badge under the right taillight?
1972 GL Sedan rear
keywords: エンブレム
Sunny Truck & Ute
LHD Badges
* Okinawa used 'S' and 'Sunny'
* Other LHD markets use 'D' and 'Datsun'
Front
62311 ORNAMENT-FRONT オーナメント、フロント
- -7803 trucks used Sedan grille and emblems "D" (Export) or "S" (JDM)
- 7804-8910 trucks used Coupe-like grille with unique rectangular center emblem
- 8911-1994 trucks use a square headlight grill with 'NISSAN' emblem on left side
- * 62392-G1265 ORNAMENT-FRONT 9810- カクガタ NISSAN
Rear
- Through 1974 'Sunny 1200' script below RH tailgate latch
- 84822-H1000 EMBLEM-trunk lid (SUNNY 1200) ALL トランク リッド エンブレム
- 84823-H1000 MARK-deluxe DX [fitted below Sunny emblem] デラックス マーク
LHD market B120 'Nissan' sticker
- 14807-89910 STICKER-FUEL
- 99070-89909 PLATE-MODEL NUMBER 8504-8910
- 96905-15200 LABEL-LOADING CAPACITY -8109 [white on black?]
- 96905-89900 LABEL-LOADING CAPACITY 8110- [black on white?]
- 96906-89900 LABEL-FRIGID ZONE 8110-
- 96908-G5100 LABEL-REAR 'NISSAN' 8910-
- 96908-G1661 LABEL-REAR 'SUNNY' short body 8110-
- 96908-G1665 LABEL-REAR 'SUNNY LONG BODY' long body 8110-
Black stickers with silver writing
white sticker with black writing
Loading Capacity Label '最大積載量500kg' (Maximum payload 500kg)
Side Emblems
78801 EMBLEM-SIDE REAR, RH エンブレム、サイッド リヤ RH
- -7409 only DX comes with side emblems
- * 76854-H1000 -7510 DX
- - 8102 Sunny Truck uses 'Sunny' script-type sedan side emblems through February 1981
- 8911-up: no side emblems
B140 Bakkie
- B140 LDV 1400 Bakkie uses "NISSAN" grille letters
- 2006 Bakkie front with "Nissan" oval grille emblem
Van
Van uses the same badges as Sedan:
* Grille 'S' ornament (including facelift version) * No grille trim badges (Deluxe, GL or GX) * 'Sunny' rear quarter badge * 'Sunny 1200' rear badge * 'Deluxe' rear badge (DX only, early version) * 'Sports' rear badge (DX 4-speed only)
In addition, Van used these unique badges:
96905-18100 LABEL-loading capacity '400 kg' * lower left side
96907-G1100 LABEL-4 speed Van-Std T, Van-P T * lower right side???
Custom
'DATSUN 1200' coupe badge + unknown 'VAN' badge
1200 SSS
The Datsun 1200 SSS sedan was a product from Datsun New Zealand.
SSS left-side grille emblem
SSS badges
82858-U0800 - same as 610/180B SSS
- SSS badge on the glove box. Anyone have a photo?
Non-1200 SSS
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
910 Bluebird SSS 62892-W3500 Front Grille Mark 8201-8907 [triangular 'SSS']![]()
62896-W1200 Front Mark 7910-8112 [octagonal 'SSS']
810 Bluebird SSS [Sedan:62396-U7625, Coupe:62396-U8325]
62397-U7600 'SSS' ~120 mm long
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
- 'Sunny' badge
- 'Nissan Full Auto Matic' badge
- Steering wheel badges
Datsun 1200 S1
The Datsun 1200 S1 2-door sedan was a Datsun of Portugal offering.
- S1 grille badge
- S1 boot badge, fitted to left of the right taillight
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Part Sources
* Nissan USA and Nissan Japan are out of badges * Nissan Australia apparently still has some. * eBay has them from time to time * Yahoo Japan Auctions always has some * Too Intense usually has some 1200 badges * Aoba Auto * South Yokohama * Matsuoka
Be careful of the quality:
Malaysia repro vs Nissan item: This reproduction badge has has poor chroming and what appears to be hand-painted coloring that doesn't exactly stay within the lines. However, other reproduction badges may be high quality.
エンブレム バッジ マーク
