Stock Wheels
- 12" diameter
- 4-inch wide
wheels | B10 | B110 | 1977 US B210 A14 | 1980 NA B310 |
size | 3-1/2 J-12 | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
offset | ? | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
tire size | ?-12 | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less | |
lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
Datsun Option Wheels
- 40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
- 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
- Also used on 200SX (S10 silvia) 1977-1979
B310 Wheels
ホイール
Sunny 1200 Race Wheels
Sports Options CatalogRace Road Wheel Parts 1 40300-H5021 ROAD WHEEL FR 8Kx14 inch 40300-H5020 ROAD WHEEL FR 9Kx14 inch 40397-N3120 SPACER-Safety Bolt (16) 40398-N3120 SEAL-Rubber (16) 2 40399-H50?? BOLT-Safety (16) 3 40209-A0220 SPACER-Road Wheel (4) for aluminum, t=5 4 40222-A0220 BOLT-Wheel FR (8) M12 x 1.25 x 50 5 40223-A0220 BOLT-Wheel RR (8) M12 x 1.25 x 50 6 40224-H5020 NUT-Wheel (16) (Taper) 7 40224-E7210 NUT-Wheel (16) (Taper) Chrome-plated cap nut
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Also See: Vibration
Wheel Offset
STOCK = 30 mm offset
Scrub Radius
Largest Sizes to Fit 1200
- Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the Offset must be reduced from +30.
- Rear: +30 Offset works best with Datsun 1200, allowing the largest width tyres (205-width tyres).
Rear
- 9": 13 x 9 zero offset, tire 215/50r13
Ute Rear
Weights
Stock Datsun 1200 Wheels (12 x 4) weigh 11 pounds each. Virtually all aftermarket alloy wheels are heavier, except for very expensive magnesium wheels.
See main article: Wheel Weights
Wheel Adapters
Wheel Spacers
See main article: Wheel Spacers
If the wheel offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
See Rims
Aftermarket Wheels
See Rims
Compatible Wheels
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13)
- pefect for the rear
- may need a 1/4 inch spacer on fronts to clear the brake caliper
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Rear-wheel-drive Mitsubishi
What WONT work:
- early Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- some SAAB
FWD Rims
- Acura Vigor 1991-1994
- Acura TC 1992-1995
- Ford Laser (KA to KH)
- Hyundai Excel
- Kia 2001- (67.1 center)
Saab Wheels
- 1979-1983 SAAB 900
Sigma Rims
Sigma Turbo rims 15 inch 4x114.3
15x6
Toyota
Celica
A40 Celica 1978-1981
Corolla RWD
E30 1974-1979 E70 1979-1983
Supra
A60 Celica XX 1981-1986
Nissan-Datsun Wheels
Bakkie White-spoke Wheels
B140 Champ wheels (trail duster style aka white-spoke steels)
A-LINE "Spoke White" of the Steel Outback Range (8-spoke)
R30 Rims
15 X 6 Skyline R30 wheels
R31 Pintara
R31 Pintara 15x6 rims
R31 Skyline
R31 Skyline spare steel wheels
"Pursuit/chaser" style wheel may be used on Datsun 1200.
See main article: Pursuits
R32 Skyline
8" wide, fit with PCD adapters?
Stanza SSS
Australian-assembled 1981-1983 Stanza SSS (PA10MX) has 13" alloy rims.
SSS wheels reportedly not fit 1200 without spacers.
C22
USA C22 40300-V6104 5.5-JJX14 +40 <> 40300-V6120 40300-V8000 SPARE <> 40300-V8077 [8-hole steel] 40300-17C25 AL [turbine]
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
810
810 Datsun 810/200B/180B/Bluebird
C-type 13" (also used by S10) & E-type 14"
A-type 5.5x14 40300-R4625 with nut set KOHBE <> 40300-U9625 40300-R4626 with locking nut set KOHBE <> 40300-U962640300-R4671 40300-U8925 A-type 14" (export option)
Datsun 810 factory OPTION B & OPTION C wheels: 13" x 5"album B-type 6-spoke 40300-U7527 B-type 5Jx13 40300-U7528 B-type 5Jx13 locking C-type 8-slot 40300-W6027 C-type 5Jx13 40300-W6028 C-type 5Jx13 locking
B-type
full
Australia 200B Aspen GL (optional GX) 14x6 (20-spoke)
E-type 32-spoke SSS, LN 5.5JJx14 40300-S0625 with nuts 40300-S0626 locking nut
200B SX (32-spoke) 14x6
910
USA 910 "Datsun 810" and "Maxima" 40300-N8810 40300-N8870 <1> 40300-N8804 40300-W1000 40300-W1004 <5> 40300-W1014 40300-W1070 <5> 40300-W1004 40300-W2426![]()
40300-W2428
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
See main article: TRX Wheels
Pulsar
N12
Pulsar N12 4.5x13 FC/FL/SSS/GF (Prince Liberta Villa, sold by Nissan Bluebird Shop) ?40315-01M20 WHEEL DISC ORNAMENT
Pulsar N12 5Jx13 Alumi 40300-01M25/40300-01M26/40300-01M28/40300-01M85/40300-01M86/40300-01M88 40300-01M70/40300-01M76
13x5
EXA Rims
EXA wheels N12 or N13 ???
For 24-spoke, see Cheviot Classic 13x5.5
F31
Nissan F31 was badged "Nissan Leopard" or "Infiniti M30".
buy at rtw wheels
buy at wheel collision
1990-1992 Infiniti M30 slanted 8 slot 15 x 6.5 +25 4 on 4-1/2 bolt circle Pilot hole diameter 66 mm 23 lbs left & right wheels
F31 Japan 8602-8808 14x5.5+30 7-slot styled steel 40300-58L05 8602-8702 VG20 [F31,C32] 40300-58L07 8702-8808 VG20 [F31,C32] 15x6+30 10-slot styled steel 40300-59S00 8602-8702 V20T.XS [F31,C32,R31] 40300-59S07 8702-8808 V20T.XS GOLD [F31,C32,R31] 8808-9805 VG20E *(VG20DT+VG30#) 40300-59S08 8905- VG20E *(VG20DT+VG30#) CHROME [F31] 8602-8808 spare steel 4x15 4-slot VG20 40300-03E00 8602-8808 <> 40300-28E15 <7> 40300-16E15 VG30.ULTIMA 40300-59S15 8602-8808 ALL 40300-59S15 8808- 8602-8603- alloy 8-slant/spoke 6.5x15 40300-F6226 RH 8808- <> 40300-F6228 GOLD VG20DT+VG30# *VG20E 40300-F6626 RH 8808- <> 40300-F6628 SILVER VG20DT+VG30# *VG20E 40300-F6627 LH <> 40300-F6225 40300-F6526 8602-8808 <> 40300-F6528 VG20T.XS2+VG30D.ULTIMA *(*VG20E.XJ#+*VG20T.XS) 40300-F6527 LH
Spare Tire
15x4T+40 40300-28E15 キイロ 4ケシ 60ネン キネンシヤ <> 40300-03E00 <7> 40300-16E15 * C23 Vanette * M10/M11 * S12/S13/RS13 Silvia * W10 * T12/T12Y * A31 * F31 * R31 * C32/C33 * P10/P10E * R32 * U11/U12/U13
40300-16E15 15x4T BLACK steel クロ <7> 40300-28E15 * B15 * C23 * K30S * P11/P11E * R33 * RS13/S14 * U14 * W10/WP11 * C34 * U13
S110
S110 1980-1983 Nissan Silvia Datsun 200SX/180SX/240RS 40300-N8810 4TX16 SPARE 40300-N8900 5JX14 0179-0783 40300-N8910 5JX14 0781-1081 40300-N8427 5.5JJX14 AL [16-spoke] 40300-N8825 5.5JJX14 AL <4> 40300-11S25 [16-spoke 5.5x14 +25] 40300-S6027 5.5JJX14 AL <4> 40300-N8427 [32-spoke 5.5JJ14 25]![]()
S13
?40300-15U28 15X6JJ silver Hitachi [K504] * RS13 Type-X 9505- option * R33 some * S14 option K.2WS.QSalbum
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole USA * Base: 195/60R15 * SE: 205/60R15
10-hole Spare 15" x 4", 4 Lug, 4.5" Bolt Pattern![]()
40300-50F26 silver top 15x6JJ+40 7-star * RS13 (S13 Hatchback/180SX) * A31 aero type silver * C33 * R32 including V Selection 2 and 60th Anniversary![]()
Z-car Rims
Datsun S30 "Fairlady Z" or 240Z/260Z/280Z Datsun S130 "Fairlady Z" or 280ZX
See main article: Z Rims
