Stripes
Revision as of 23:59, 26 September 2021; view current revision
Category: Paint
The purpose of racing stripes is to identify the car among many other similar cars during a busy race. You can also make your street car stand out by applying stripes.
Factory Stripes
SSS
See Main Article: Datsun 1200 SSS
S1 Stripe
Portugal thin stripe with inset 'DATSUN' at the rear.
1447.jpgAlbum 1447 14057.jpgAlbum 14057 46.JPGAlbum 46 1449.jpgAlbum 1449 1452.jpgAlbum 1452
Option 'Datsun' Side Strip
JPN K5040-00067
USA 99990-00107
174_6150f3478980d.jpgPost 495906
27055.jpgAlbum 27055 14333_53cf2031f1e13.pngPost 458263
Bold "DATSUN" side stripe adds sportscar flare to the 1200. Makes the car look lower and longer. Stripe is top quality "Scotchcal" vinyl. Each letter is formed with individual pieces of tape to let the original car paint show through for a clean, neat, perfectly colored letter! 71" long, available in black or white.
27054.jpgAlbum 27054 174_56da185c241c7.jpgPost 476899
K5040-00067 TAPE-masking 'D A T S U N' (10 m) Coupe
20634.jpgJDM OPTIONS
"DATSUN" SIDE STRIPE, Part Number 99990-00107 (white). * 9990-00108 (black) $16.75 USD
The Datsun 510 catalog has the same stripe kit, and the description is worded more accurately.
The "DATSUN" side stripe kit comes ready to apply, and adds sports car flair to your automobile. The "Scotchcal" vinyl retains its luster and is long-lasting. Letters are individually formed allowing the original paint to show through. The side stripe is 71" long. Available in black or white.
The re-creation on this red 1200 doesn't let the car color show through
Different version seen on B210 (narrow spacing, different font)
174_59ead54e9c89b.jpgPost 486509 174_59ead559b03e5.jpgPost 486509 26916.jpgAlbum 26916
Option 3/4-inch Side Stripe
174_6150f331f1e03.jpgPost 495906
3/4" SIDE STRIPE KIT, Part Number 99990-00109 (white) * 99990-00110 (black) [$14.00 USD] Thin line side striping to add a subtle touch to the 1200's beautifully sculptured lines. Side striping consists of a 1/4" stripe between two 1/8" stripes for a total slim-line 3/4" stripe. 25 ft. of striping provided, all in high quality "Scotchcal" vinyl. Available in black or white.
27479.jpgUSA OPTIONS
B120 Bakkie
Nissan South Africa stripes
B120
GX Side Stripe
Datsun 1200 GX
8580.jpgAlbum 8580
Sedan and Coupe
8883.jpgAlbum 8883
Black & white
1748.jpgAlbum 1748 1749.jpgAlbum 1749
From 1970-1971 Catalog
?unlisted?
GX-5
GX-5 tape stripe looks similar but differs for Sedan & Coupe, specifically the key holes & side duct places differ.
Coupe Stripe leading edge is cut at an angle and has a notch for the side vents
Sedan strip straight-cut leading edge
19277.jpgAlbum 19277 5487.jpgAlbum 5487
174_5c25f2891e8ac.jpgPost 490280 174_5c25f2963eeb9.jpgPost 490280
19087.jpgAlbum 19087
GX-5 Black and Red
1873.jpgAlbum 1873 1872.jpgAlbum 1872 1970.jpgAlbum 1970 1971.jpgAlbum 1971
1816.jpgAlbum 1816 1833.jpgAlbum 1833
Nissan Part Numbers from 1972 JDM catalog:
Sedan
76820-H7200 STRIPE SET-accent
* 76822-H7200 SHEET-accent stripe (R.H.)
* 76823-H7200 SHEET-accent stripe (L.H.)
Coupe
76820-H7210 STRIPE SET-accent
* 76822-H7210 SHEET-accent stripe (R.H.)
* 76823-H7210 SHEET-accent stripe (L.H.)
174_5d635b11d79b2.jpgPost 492380
Factory brochures show a Black & Yellow stripe, which is not in the catalog:
25661.jpgAlbum 25661 22548.jpgAlbum 22548
carps version
13022_4d8b104f2a76a.jpgPost 361007 13022_4d8b103ecf019.jpgPost 361007 13022_4d8b10686a032.jpgPost 361007
PB110
PB110
GX
Sedan & Coupe use the same stripe sets
24168.jpgAlbum 24168
76821-H2703 STRIPE SET-accent (black & yellow) (L.H.) SGX, CGX
76820-H2703 STRIPE SET-accent (black & yellow) (R.H.) SGX, CGX
174_4d4f28033ea8a.jpgPost 355956
76821-H2702 STRIPE SET-accent (white & yellow) (L.H.) SGX, CGX
76820-H2702 STRIPE SET-accent (white & yellow) (R.H.) SGX, CGX
174_55f8fa577ddd8.jpgPost 472376
GL
  • K5040-00195 TAPE-marking (960mm) as req. S-GL
  • K5040-00196 LABEL-marking (R.H.) S-GL
  • K5040-00197 LABEL-marking (L.H.) S-GL
PB210 1400
ACCENT STRIPE - SEDAN GX
76820-H6000 ACCENT STRIPE SET
  76822-H6000 SHEET-accent stripe (R.H.)
  76823-H6000 SHEET-accent stripe (L.H.)
76820-H6001 ACCENT STRIPE SET
  76822-H6001 SHEET-accent stripe (R.H.)
  76823-H6001 SHEET-accent stripe (L.H.)
B310
'210' B310_Brochures#United_States
'SUNNY' 1981 B310_Brochures#Canada
76872-H9205, 76873-H9205 アクセントストライプ 金地 黒 Sedan, Coupe '77~ (Scotchcal tape)
EGI accent stripe???
Common Pinstripe
Like a Datsun dealer would apply to a new 1200.
2855.jpgAlbum 2855
Thin perimeter stripe
2326.jpgAlbum 2326
Bustle Stripe
1650.jpgAlbum 1650
Bumblebee Stripe
1719.jpgAlbum 1719 1720.jpgAlbum 1720 1721.jpgAlbum 1721
Lightning Stripe
2437.jpgAlbum 2437 16816.jpgAlbum 16816 16817.jpgAlbum 16817
Leman Racing Stripes
The original racing stripes.
7353.jpgAlbum 7353
Thin Double Rally Stripe
10717.jpgAlbum 10717 6818.jpgAlbum 6818 16175.jpgAlbum 16175
Classic Double Rally Stripe
10379.jpgAlbum 10379 10444.jpgAlbum 10444 14.jpgAlbum 14 15.jpgAlbum 15 322.JPGAlbum 322 463.jpgAlbum 463 764.jpgAlbum 764 1475.jpgAlbum 1475 2029.jpgAlbum 2029 2325.jpgAlbum 2325 2838.jpgAlbum 2838 15496.jpgAlbum 15496 15498.jpgAlbum 15498 2878.jpgAlbum 2878 2991.jpgAlbum 2991 2994.jpgAlbum 2994 4513.jpgAlbum 4513 5203.jpgAlbum 5203 6728.jpgAlbum 6728 8402.jpgAlbum 8402 8403.jpgAlbum 8403 10834.jpgAlbum 10834 11263.jpgAlbum 11263 12818.jpgAlbum 12818 13726.jpgAlbum 13726 13728.jpgAlbum 13728
Offset Stripe
15028.jpgAlbum 15028 6280.jpgAlbum 6280 6754.jpgAlbum 6754 9336.jpgAlbum 9336 16882.jpgAlbum 16882 17209.jpgAlbum 17209 17210.jpgAlbum 17210 17212.jpgAlbum 17212 1281.jpgAlbum 1281 1282.jpgAlbum 1282 1584.jpgAlbum 1584 2383.jpgAlbum 2383 17954.jpgAlbum click to view 17949.jpgAlbum click to view
200B
12152.jpgAlbum 12152 11756.jpgAlbum 11756
BRE Stripes
The famous pattern of the 1968 Datsun team by Pete Brock of BRE, itself an evolution of racing hash marks/fender strips.
See main article: BRE paint schemes
th_nasmie_majiet_nissan_1400_racing_de.jpg 2953.jpg 13002.jpg 11601.jpg 795.jpg th_msv5-2.jpg
Scallops
Paint scallops is an old hot rod style. Try it on a 1200.
1200 Pickup with Primer paint and scallops
14450.jpgAlbum 14450
13767.jpgAlbum click to view 13960.jpgAlbum 13960
2570.jpgAlbum 2570
Tricolor
Datsun Colours - red, white and blue
13714.jpgAlbum 13714
Misc
Dazzle stripes
18189.jpgAlbum 18189
Strobe Stripe on Sublime Green paint. Buy stripe kit from Trimbrite pn R76010
174_5ae3800ee57fe.jpgPost 488190 22717.jpgAlbum 22717 22716.jpgAlbum 22716
Diagonal
18089.jpgAlbum 18089
Yenko stripe
20090.jpgAlbum 20090
Spear
174_55ea1bf73d2be.jpgPost 471955 174_55ea1becdb6be.jpgPost 471955
Reverse Boss
17745.jpgAlbum 17745
classic Racing Forg paint scheme
Starsky & Hutch Style
5776.jpgAlbum 5776
90s Style
7009.jpgAlbum 7009 14352.jpgAlbum 14352
