Chassis numbers
Revision as of 09:41, 4 September 2017; view current revision
Category: General Information
The B110 chassis number is stamped on the cowl and on the engine-compartment plate.
See Nissan chassis codes for explanation of model numbers.
モデルNo.プレート表示 Model Number Plate display
Engine numbers should match the Plate. Engine numbers are here (right side of block, near back just under cylinder head):
770.jpgAlbum 770 A1216699.jpgAlbum 16699 A14
エンジン番号表示 Engine Number Display
See main article: Engine ID Mark
取付および打刻位置 Installation and embossing position
Model Number Plate
Custom plate
1981-up Model Plate
See main article: VIN
Oct 1981 (Japan) and 1981 Model year (USA) changed to a more detailed plate:
21048.jpgAlbum 21048
L-: L-level emissions (1981 Oct - 1989 Oct)
G: Long Wheelbase
Model: B122 [Sunny Truck]
T: 4-speed
Color: 002 White
トリム Trim: C
Engine: A12 gasoline engine
S: Single carburetor
Axle: HC41 H165 4.10 ratio
Plant 4: Aichi Machine
Australia
Japan assembled B120
11209_4b88cf8fce523.jpgUpload click to view
See main article: Australian-assembled
15403.jpgAlbum 15403
B120
12780.jpgAlbum 12780
ADR Mod Plate
22393.jpgAlbum 22393
ADR compliance plate - B120
12779.jpgAlbum 12779
ADR compliance plate - B310
Show plates by datskool
th_datskool_pty.jpg th_datskool_B110.jpg installed
Caution Plate コーション プレート
Model Number Plate モデルNo.プレート 表示
7-1 保安基準適合 (Safety Standard, 1970?)
5-6 Safety Standard
12226.jpgAlbum 12226 13666.jpgAlbum 13666
Japan badges list:
GX 83 HP
19810.jpgAlbum 19810
  • Horsepower: 83 PS
  • Torque: 7.1 Newton Meters
B120
B120-066350 - 68 PS 保安基準適合 8-4 [Safety Requirements]
24031.jpgAlbum 24031
1975 GB120 - 68 PS 保安基準適合 0-4 [Safety Requirements]
H-GB120 68 PS 保安基準適合 0-12 [Safety Requirements]
131127: 1978 April - 1979 July
L-GB122-023187 (1984 November), Plant 4 Aichi Machine
23169.jpgAlbum 23169
15198.jpgAlbum 15198
25511.jpgAlbum 25511
B310 with A12A
25510.jpgAlbum 25510
New Type
Beginning October 1979, plate includes model subtypes and trim codes
B310 with A12A
25509.jpgAlbum 25509
Thailand
23429.jpgAlbum 23429
New Zealand
Nissan Motor Distributors (N.Z.) Ltd.
22403.jpgAlbum 22403
In addition to regular Nissan plates, Land Transport NZ (formerly Land Transport Safety Authority) may add a "Low Volume Vehicle Certification Plate":
16899.jpgAlbum 16899
Brought to you by the Low Volume Vehicle Technical Association
Warranty Of Fitness (W.O.F.)
22401.jpgAlbum 22401
South Africa
140Z
11952.jpgAlbum 11952
1400 B140
26694.jpgAlbum 26694 26696.jpgAlbum 26696
26697.jpgAlbum 26697 26699.jpgAlbum 26699
USA & Canada
1971 quench chamber cylinder head
69 HP: 9233.jpgAlbum 9233
1972-1973 open chamber cylinder head
68 HP: 12220.jpgAlbum 12220
USA Ratings:
* Horsepower: 68 or 69 SAE HP
* Torque: Not listed
For an explanation of SAE and why some are 68, others are 69, see: Performance.
Tune-up/Dyno Label
Tune-up/Dyno sticker as applied to underhood
14994.jpgAlbum 14994:14805-H3900 (1972)
See Main Article: Emission Controls#Specifications
Vehicle Emission Control Information (Tune-up details)
12227.jpgAlbum 12227:14805-H7000 (1973)
The Intertia Wheel Weight (dyno setting): 2000 lbs
12230.jpgAlbum 12230:14808-H7000 (1973)
FMVSS Build Plate
In addition to the Nissan chassis numbers, USA models have an FMVSS build plate:
11924.jpgAlbum 11924
Color Number
See main article: Color Number Tag
Custom Plates
2987.jpgAlbum 29873187.jpgAlbum 3187
Serial Numbers
JDM Catalog 11/1971
  • Sedan: From B110-226985
  • Coupe: From B110-877228
Maybe this is the serial numbers where 3N71B automatic was first introduced. Translation is difficult
USA Catalog
  • U = United States models
  • N = Canada models. Also some U models were sold in Canada.
  • A = Automatic transmission-equipped models
Reference: Datsun 1200 USA & Canada Parts Catalog Model B110 Series (C-0030U), 4th Overall Revision, December 1973
1200 Coupe
11915.jpgAlbum 11915
  • KLB110TU
  • KLB110TN
  • KLB110AU
ZFrom (L)B110-764205From Apr-71
ZFrom LB110-640001From Jan-72
ZFrom LB110-477893From Jun-72
FFrom (L)B110-877228From Apr-71
FFrom (L)B110-940001From Jan-72
FFrom LB110-975540From Jul-72
[I'm guessing the "Z" means the Zama plant, and "F" means the Fuji Heavy Industries plant. This fits because only some Coupe models were marked F, while all sedans were built at the Zama plant.]
1200 2-Door Sedan
11916.jpgAlbum 11916
  • LB110TRU
  • LB110TRN
  • LB110ARU
ZFrom (L)B110-247023From Apr-71
ZFrom (L)LB110-341001From Jan-72
Monroney Sticker
See Monroney Sticker
Vehicle Identification Number
Starting in 1980, Datsuns were marked with an international-standard 17-digit VIN number.
Engine
See Engine ID Mark
Transmission
Manual transmission number
23605.jpgAlbum 23605
23606.jpgAlbum 23606 23607.jpgAlbum 23607 23608.jpgAlbum 23608
1882.jpgAlbum 1882 9233.jpgAlbum 92331947.jpgAlbum 1947 11952.jpgAlbum 11952 12223.jpgAlbum 1222312224.jpgAlbum 12224 12225.jpgAlbum 12225 18183.jpgAlbum 18183 20010.jpgAlbum 20010
20016.jpgAlbum 20016 C22 Vannette
8463.jpgAlbum 8463 KB10 Plate
