The Nissan L-series engine (as in the 1600/510) is a good swap. Inexpensive, readily available both in USA and Australia, and these are a larger engine family than the Nissan A Engine. From L13 to L18, they are nearly identical on the outside. The L20B 2-liter engine is a tall-block variation but it still will fit under the hood and without cutting the sheetmetal. The Z-series Engine is closely related but has a crossflow cylinder head.
Discussions
Engines
- L13: early Datsun 510 Standard models came with L13. Don't bother to swap this, an A14 is better.
- L14: Nissan put the L14 in the Japan-only PB110.
LZ20 DOHC engine
- LZ Engine: A super-rare racing engine was the LZ20 twin-cam, fitted to 1200 racing cars.
See main article: [LZ engine]]
Crossmember
Transmission
Transmissions for Z engine and L engine bolt to either engine but the L engine is slanted by about 10 degrees, so it affects the angle the shifter comes out.
engine tilt
- Note the CA Engines have a different bell pattern so their gearboxes do not fit the L Engine.
Using a stubby transmission will line up with the 1200 shifter hole. It is about 5 or 6 inches shorter than the more common L-engine transmissions. These are also called shorty or short-tailed.
- Stubby is ~26.3 inches -- same length as Datsun 510 automatic transmission
4-speed stubby gearboxes are common:
- 1968-1973 Datsun 510 ("1600") F4W63
5-speed stubby gearboxes comes from:
- 1981-1985 R30 Skyline with L24 six-cylinder engine
- 1977-1979 200SX USA S10 (L-series engine, FS5W63 "smoothcase" dogleg)
- 1968-1973 PL510 (L-series engine, F4W63 "bottom pan")
- 720 FS5W71B "ribbed case" used on certain 720 4X4s (long wheelbase?)
- Z-engined series
- may have had an L series in 1980 only
Comparo
- Regular
- ~31.5 inches overall transmission length
- transmission extension housing about same length as (front) transmission case
- From the bottom front of the bell housing to the cross member bolts is ~21-1/2"
- Stubby
- ~26.3 inches overall transmission length
- transmission extension housing about 5" shorter than transmission case
Or use a standard L-engine tranmission. The only bit of cutting wil be 1/2 of the gearstick hole but that can be welded that back in the other side to make the factory rubber shifter gasket fit back in. You can see it here:
Photo Gallery: L Engine transmission comparison photos at http://forum.ratsun.net/showthread.php?t=2373 Ratsun.net]
L20B Swap
The L20B is a 2-liter four cylinder engine. Not to be confused with the L20 six cylinder.
- no holes cut
- just panel beat the lower corners of the front of the tunnel with a hammer, as the L series is wider
- modify the engine mounts and make a crossmember
- 1200 crossmember had the mounts trimmed to an angle simular to that of an 810, then cut the 810 mounts in 1/2 to finish the job and locate the motor lower and improve the mounting angles.
- 810 oil sump is a near-perfect fit in the 1200, reshape it a little just so it will clear the crossmember, maybe 1/2cm with a hammer
- fitting the radiator in isn't a problem. you'll need a thermostat-controlled fan in front of the radiator (i.e. on the grill side)
Sources
- Datsun 810 Australia model with L20B engine
- Datsun 620 pickup circa 1977, USA with L20B engine
