Nissan chassis model B310 was the fourth-generation Sunny. They were sold during Model years 1979-1982 and marketed in various countries as the Datsun 210 or Datsun Sunny. In some countries it was designated Datsun 120Y, Datsun 130Y, Datsun 140Y or Datsun 150Y, depending on the engine fitted.
For more details and how the Sunny family was developed, see History of Datsun 1200.
WikiMedia - Sunny California (sweepback) Wagon
B310 vs. 310
Datsun 210 was the fourth-generation Sunny family:
1978-1982 B310, marketed as Datsun 210 in the US
It is sometimes confused with the Datsun 310, which was a totally different model.
Datsun 310 was a front-wheel drive model from the Cherry/Pulsar family:
1979-1983 Datsun 310 (Nissan model N10)
Bumpers
- North American models have the front running lights in the grille, while others have the running lights in the bumpers.
- As always, North America got the large 'park bench' bumpers while other countries got boxy but lighter bumpers.
North America Identification
- 1979 Model year and early 1980: round headlights
- 1980 late Model Year: square headlights 'D' grille emblem
- 1981-1982 Model Years: square headlights 'DATSUN' grille emblem
- WHLB310 - Wagon, Calfornia-style (semi-fastback wagon)
- H9300 - Nissan part type H93
- 65HP - lo-po (economy) A14 Engine
1981 Chassis plate
This style plate was first used in 1980
- Nissan Motor Co., Ltd. Japan: If you didn't know, Datsuns were made by Nissan
- Type KPB310: K = Coupe, P = bigger engine, B310 is the model line
- Chassis No. JN1PB04S2B9259790: VIN (Vehicle Identification Number)
- Model KPLB310FUG: Kuupe, Left-hand drive, Five-speed, United states, GL
- Color, Trim 804 P
- Engine A15 Engine(S) 1488cc: S = single carb
- Trans Axle FS5W60A HB37: 60-Series Transmission and Hitachi 3.700 ratio Differential
- Plant 9: Fujiya
- LB310RSU (2-dr sedan, Standard,United States)
- A12A Engine, 1237 cc (different from A12 engine)
- HA38: Hitachi differential 3.8 ratio, A-style carrier
Badges
Round headlight grille
- Sedan, Coupe -7909
- Van (V)
- 62300-H8510 GRILLE ASSY-RADIATOR
- 62392-H8500 ORNAMENT-FRONT
Square headlight grille 7910-
- Sedan, Coupe, Wagon (W)
- 62310-H8502, 62310-H8503 GRILLE ASSY-RADIATOR
- 62392-H8505
- 62395-H8705 K, W-GX 7910-8010
- 62395-H8705 S, W-GX 8011-
- 62395-H8705 4S GX 7910-8010
- 62312-H8501 GRILLE ASSY-RADIATOR
Side badge
- 78801-H8500 EMBLEM-SIDE REAR RH -7909 ['SUNNY' block letters]
- van to 8109
- 78801-H8505 EMBLEM-SIDE REAR RH 7910- ['Sunny' script letters]
- van from 8110-
Year
- 1978: Japan only
- 1979: Export first year
- 1980: Change to square headlights, intermittent wipers
- 1981: Change to rectangular gauges
- 1982: final year
Models
Suspension
B310 for Japan and USA was fitted with Datsun A10 (Stanza/510) front suspension, including the struts and steering linkage. This includes the large 245mm disc brake rotors.
Rear Axle
- B310 sedans and coupes got coil-spring 3-link rear axle assembly.
- Wagons got coil spring (Wagon = slant-back wagon, called "Calfornia" in Japan market)
- Vans (square back wagon) got a leaf spring rear axle
- GX models (including California wagon) got a rear sway bar
The differential is H150 in all cases.
