ALL 1200-related Pages from 1984 Catalog
Proven names like Electromotive, Bob Sharp Racing, Tilton, Koni, Venolia and Iskenderian, backed by a complete line of non-USA [JDM] and competition parts from the factory make this the most comprehensive competition catalog ever.
For other catalogs, see Nissan Competition
NISSAN COMPETITION PARTS
Table of contents:
![th_Competition198401.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198401.jpg) |
- 1200, B210, 210, 310/N10 Page 34 [sic, page 36]
- Miscellaneous Page 60
1200 Parts
Piston and Camshaft
Cylinder Head, Valves and Lubrication
Cooling
Hitachi Twin Carb
![th_Competition198440.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198440.jpg) |
The GX/SU induction system was a production line option on non-USA versions of the 1200 and B210. Requires use of GX cylinder head. The GX system can be adapted to virtually any A-series engine.
Pulleys and Electrical
![th_Competition198441.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198441.jpg) |
- Pulleys (A-series)
- Electrical System (A-series)
Tachometer, Speedometer and Exhaust
Flywheel, Clutch and Transmission
![th_Competition198443.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198443.jpg) |
- Flywheel & Clutch
- Transmissions
Differential
Stabilizer and Shocks
![th_Competition198445.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198445.jpg) |
- F10 & N10/310 Final Drive Gears (To 7/81)
- Wheel Studs & Nuts
- Brakes
- 1200 Stabilizer Bars
- 54611-H2300 20MM FRONT BAR
- 54617-H2300 BUSHING FOR 54611-H2300 2 REQ.
- 99996-H4301 QUICKOR 25MM FRONT BAR KIT
- 99996-H4351 QUICKOR 19MM REAR BAR KIT
- B210 Stabilizer Bars
- 54611-22301 19MM FRONT BAR
- 54617-22020 BUSHING FOR 54611-22301 2 REQ.
- 99996-H4060 INSTALLATION KIT FOR 54611-22031
- 54611-22030 23MM FRONT BAR
- 54617-22030 BUSHING FOR 54611-22030 2 REQ.
- 99996-H4060 INSTALLATION KIT FOR 54611-22030
- 210 [Datsun B310] Stabilizer Bars
- 310/N10 Stabilizer Bars
- Koni Shock Absorbers
- Front
- Rear
- 99996-1714N 1200/FRONT 2 REQ.
- 99996-2359A 1200/REAR (COUPE ONLY) 2 REQ.
- 99996-1912R B210/FRONT
- 99996-2359A B210/REAR (COUPE ONLY)
- 99996-2002P 210/FRONT
- 99996-2378B 210/REAR (EXCEPT WAGON)
- 99996-1130B 210/REAR (GAS)(EXCEPT WAGON)
- 99996-2002T 210/FRONT (SPORT)
- 99996-2378J 210/REAR (SPORT)(EXCEPT WAGON)
- 99996-2005P F10 & 310/N10/FRONT
- 99996-2205B F10 & 310/N10/REAR
Suspension and Fiberglass Parts
![th_Competition198446.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198446.jpg) |
- 1200 Coupe Racing Suspension System
- B210 Coupe Racing Suspension System
- 210 Racing Suspension System
- 210 Misc. Suspension Components
- 310/N10 Coupe Racing Suspension System
- 1200 Coupe Factory Fiberglass Parts
![th_Competition198447.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198447.jpg) |
- B210 GT4 Fiberglass Parts
- 210 Fiberglass Parts
Miscellaneous
Mikuni Accessories
![th_Competition198462.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198462.jpg) |
- Mikuni/Solex Accessories
- Main Jets
- Air Jets (Countersunk Type)
- Pilot Jets
- Outer Venturi (40PHH)
- Outer Venturi (44PHH)
- Needle Valve ASSY
- Velocity Stack
![th_Competition198463.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198463.jpg) |
- Mikuni/Solex Accessories [continued]
- Jet Blocks
- Main Bleed Pipe (Emulsion Tube)
Spark Plugs
Non-resistor plugs can be used in racing, where allowed. Resistor plugs are used in street cars as they do not interfere with radio communications.
- Champion Spark Plugs
- 99996-00N60 N60 REGULAR TIP SPARK PLUG [B9ES equivalent]
- 99996-00N2G N2G GOLD TIP SPARK PLUG [B9EVX equivalent]
- 99996-0N59G N59G GOLD TIP SPARK PLUG [B95EGV equivalent]
- 99996-0N57G N57G GOLD TIP SPARK PLUG [B105EGV equivalent]
- 99996-0N10Y N10Y PROJECTED TIP SPARK PLUG
- 99996-00N9Y N9Y PROJECTED TIP SPARK PLUG [BP6ES equivalent]
- 99996-00N8Y N8Y PROJECTED TIP SPARK PLUG
- 99996-00N7Y N7Y PROJECTED TIP SPARK PLUG [BP7ES equivalent]
- 99996-00N6Y N6Y PROJECTED TIP SPARK PLUG [BP8ES equivalent]
- 99996-0N60Y N60Y PROJECTED TIP SPARK PLUG [BP10ES equivalent]
- Spark Plug Spacer
- 99996-N6732 .096 SPARK PLUG SPACER
- 99996-0N677 .135 SPARK PLUG SPACER
Special Tools
![](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/Brochures/Nissan%20Competition%201984/th_63c.jpg) |
- Special Tools
- EG167-00000 UNI-SYN CARB ADJUSTMENT GAUGE
- ST358-50000 BRAKE ADJUSTMENT TOOL
Literature
Labels
![](http://datsun1200.com/uploads/thumbs/20963.jpg)
- Nissan/Datsun Die-cuts & Labels
- 99996-X1001 'DATSUN' BLACK (1.5" x 12")
- 99996-X1002 'DATSUN' WHITE (1.5" x 12")
- 99996-X1003 'NISSAN' BLACK (1.5" x 12")
- 99996-X1004 'NISSAN' WHITE (1.5" x 12")
- 99996-X1010 'DATSUN' BLACK (3.5" x 34")
- 99996-X1011 'DATSUN' WHITE (3.5" x 34")
- 99996-X1013 'NISSAN' BLACK (3.5" x 34")
- 99996-X1014 'NISSAN' WHITE (3.5" x 34")
- 99996-X2001 'DATSUN...WE ARE DRIVEN' BLACK
- 99996-X2002 'DATSUN...WE ARE DRIVEN' WHITE
- 25371-N3121 IGNITION CUT-OFF SWITCH LABEL (CIRCLE)
- 25371-A7600 IGNITION CUT-OFF SWITCH LABEL (TRIANGLE)
Wearing Apparel
![th_Competition198464.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198464.jpg) |
- Wearing Apparel
- T-shirts
- Tank Tops
- Halter Top
- Patches
Posters
![th_65.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/Brochures/Nissan%20Competition%201984/th_65.jpg) |
- Posters
- 99996-P0003 '74 B210 C/S
- 99996-P0006 '76 B210 C/S
- 99996-P0012 '77 B210 C/S
- 99996-P0013 '77 B210 IMSA RS
- 99996-P0014 Z/B210 IMSA
- 99996-P0017 '78 B210 C/S
- 99996-P0020 '79 B210 C/S
Poster Gallery
