Spotters Guide: How to identify Datsun rear axle assemblies.
ID
Bolt Pattern
H145 has 8-stud removable center. H150 and H165 also use 8 bolts. But only the H145 is 8-stud (the others use bolts).
H145 round 8-STUD H150 round 8-bolt H165 round 8-bolt H190 round 10-bolt BW octagonal 8-bolt
Flange
H150: 45 x 54 mm round or rectangular flange
There are some differences between flanges on H165's, some long (~217.5mm from carrier mounting face to driveshaft flange face), some short (~202.5mm). Depth of hole for centering boss varies also.
Size
H145 measures 145mm H150 measures 150mm H165 measures 165mm H190 measures 190mm
Pre-1980
B10: H145, 3.900 VB10: H145, 4.375 (van/wagon) B20: H145, 4.375 S.T.D. / 4.625 Optional (ute/pick-up) B110: H145 3.900 VB110: H145 4.111 (van/wagon) PB110: H165 4.111 B120: H165 4.111 (ute/truck) B210 1974: H145 3.900 B210 1975-up: H150 3.700 or 3.889 PB210: H165 GB211: H165 B310: H150 various A10: H165 various
1980-up
Axle Codes H = Hitachi removable gear carrier (pumpkin/centre section) HA - H145 (145mm diameter ring gear, 5.709 inch) HB - H150 (150mm diameter ring gear, 5.906 inch) HC - H165 (165mm diameter ring gear, 6.496 inch) HD - H190 (190mm diameter ring gear, 7.480 inch) ALUMINUM CARRIER HE - H190 CAST IRON CARRIER HF - H190A revised for strength
Counting
39 divided by 11 = 3.545 ratio
Pinion gear is similarly stamped
BW
Australian-assembled B110 sedans used a Borg Warner Model 60 rear axle, starting in Late 1971. It has an octagonal gasket, instead of the round gasket of the Japan diffs. It is also a Salisbury type (non-banjo) so it has a bolt-on cover, while all Japan diffs have a bolt-in gear carrier.
See main article: Borg Warner Differential
H145
NOTE: Aussie-built B110 sedans with a non-removable diff center use the BW60 diff.
H145 is a Hitachi design with 145mm ring gear (5.71 inch).
B10 H145 uses a hand brake cross Rod -- a solid rod (B110 uses hand brake cables)
B110 H145 uses hand brake Cables (no rods)
Coupe
full
H150
See main article: H150
H150 looks like H145 (only 5mm larger), but has these major differences:
* H150 fastens to the axle housing with bolts instead of studs * H150 orginally was fitted to 1975-1978 B210 and 1979-1982 B310
H165
H145: Vent to left of diff H165: Vent to right of diff
Brake Line Split
1200 splitter is on right side of RHD coupe & sedan splitter is on left side of RHD ute splitter is near center of LHD coupe & sedan
Flexible Hose (from chassis to rear axle) is the same RHD/LHD. Splitter is the same.
Shock Mount
See main article: Leaf Springs
Sedan vs Coupe: sedans have a shock bracket for the axle housing, which coupes lack.
Sedan mount
Coupe/van/truck
post
Bound Bumpers
1200 Coupe/van/truck has bound bumpers
1200 Sedan does not have this, as the bound bumper is built into the top of the shock absorbers.
Brake Adjusters
See main article: Rear Brakes
B110, B120 to 1989, B210 has manual adjuster
B120 from 1989 (H165) has star-wheel auto-adjuster
B310 (H150) A14/A15 adjuster assembly (automatic with star wheel)
