1973 USA Service Manual
Revision as of 07:10, 1 November 2023; view current revision
Category: Documentation
<-- back to Repair Manual
Nissan factory service manual for the 1973 Datsun 1200, North America edition.
DATSUN 1200 SERVICE MANUAL MODEL B110 SERIES NISSAN MOTOR CO., LTD. TOKYO, JAPAN
14103.jpgAlbum 14103
Index
QUICK REFERENCE INDEX
GI GENERAL INFORMATION
ET EMISSION CONTROL AND TUNE-UP
EM #ENGINE MECHANICAL
EL ENGINE LUBRICATION SYSTEM
CO COOLING SYSTEM
EF FUEL SYSTEM
EE #ENGINE ELECTRICAL SYSTEM
ER ENGINE REMOVAL & INSTALLATION
CL CLUTCH
TM TRANSMISSION
AT AUTOMATIC TRANSMISSION
PD PROPELLER SHAFT & DIFFERENTIAL CARRIER
FA FRONT AXLE & FRONT SUSPENSION
RA REAR AXLE & REAR SUSPENSION
BR BRAKE
WT WHEEL AND TIRE
ST STEERING
FE ENGINE CONTROL FUEL & EXHAUST SYSTEM
BF BODY
BE #BODY ELECTRICAL
SE SERVICE EQUIPMENT
FORWARD
This service manual has been prepared for the purpose of assisting service personnel of authorized NISSAN/DATSUN dealers in providing effective service and maintenance of the 1973 Datsun 1200.
Since proper maintenance and service are absolutely essential in satisfying the owners of Datsun, this manual should be kept in a handy place for ready reference and should be carefully studied.
This manual includes procedures for maintenance adjustments, minor service operations, removal and installation, and for disassembly and assembly of components.
The #Quick Reference Index on the first page enable the user to quickly locate and desired section. At the beginning of each individual section is a table of contents, which gives the page number on which each major subject begins. An index is placed at the begining of each major subject within the section.
The #Special Tools, when required, presented at the "SE" section.
All information, illustration and specifications contained in this manual are based on the latest product information available at the time of publication approval.
Right for alternation of specifications and methods at any time are reserved.
TOKYO, JAPAN
(C) 1972 NISSAN MOTOR CO., LTD.
ENGINE MECHANICAL
SECTION EM ENGINE MECHANICAL
EM-1  #GENERAL DESCRIPTION
EM-4  #ENGINE DISASSEMBLY
EM-8  #INSPECTION AND REPAIR
EM-25 #ENGINE ASSEMBLY
EM-33 #SERVICE DATA AND SPECIFICATIONS
EM-38 #TROUBLE DIAGNOSES AND CORRECTIONS
GENERAL DESCRIPTION
ENGINE ASSEMBLY
EM-25
ENGINE ASSEMBLY
EM-25 PRECAUTIONS
EM-30 EM-25 CYLINDER HEAD
EM-25 PISTON AND CONNECTION ROD
EM-26 ASSEMBLING ENGINE
EM-27 ...
Fig. EM-74 Flywheel installation
EM-33
GENERAL SPECIFICATION
TIGHTENING TORQUE      Unit: kg-m (ft-lb)
Cylinder head bolts    5.5 to 6.0
Connecting rod nuts    3.2 to 3.8
Flywheel bolts         6.5 to 7.5 (47 to 54)
Main bearing cap bolts 5.0 to 6.0 (36 to 43)
Camshaft gear bolts    4.0 to 4.8
Oil pan bolts          0.4 to 0.6
Oil pump bolts         1.1 to 1.7
Oil strainer bolts     0.9 to 1.4
Crank pully bolts       15 to 16
EM-34
a) Valve Mechanism
SECTION EE ENGINE ELECTRICAL SYSTEM
BATTERY EE-1
STARTING MOTOR EE-3
CHARGING CIRCUIT EE-15
ALTERNATOR EE-16
REGULATOR EE-23
IGNITION CIRCUIT EE-29
DISTRIBUTOR EE-29
IGNITION COIL EE-36
SPARK PLUG EE-37
BODY ELECTRICAL
SECTION BE BODY ELECTRICAL
BE-1  #WIRING
BE-6  #FUSE
BE-7  #LIGHTING SYSTEM
BE-15 #HORN
BE-18 #METERS AND GAUGES
BE-26 #WINDSHIELD WIPER AND WASHER
BE-29 #IGNITION SWITCH AND STEERING LOCK
BE-31 #CLOCK
BE-32 #RADIO
BE-34 #HEATER
WIRING
BE-1 WIRING
WIRING HARNESS BE-1
  Engine Compartment harness BE-1
  Instrument harness BE-2
  Body harness BE-2
WIRING DIAGRAM BE-4
  Fig. BE-14 Wiring diagram for manual transmission model
  Fig. BE-15 Wiring diagram for automatic transmission model
INSPECTION BE-6
FUSE
BE-6 FUSE
LIGHTING SYSTEM
BE-7 LIGHTING SYSTEM
CONTENTS
BE-7  #HEAD LAMP
         Description
         Sealed beam replacement
BE-8    Aiming adjustment
BE-8  #FRONT PARKING AND TURN SIGNAL LAMP,
       SIDE FLASHER (MARKER) LAMP,
       AND LICENSE LAMP
BE-9  #REAR COMBINATION LAMPS
BE-10 #BULB SPECIFICATIONS
BE-10 #TURN SIGNAL AND DIMMER COMBINATION SWITCH
         Removal
BE-11 #LIGHTING SWITCH
         Removal
      #HAZARD WARNING SWITCH
BE-12 #PASSING LIGHT SWITCH
        #Head lamp
BE-13   #Turn signal lamps
BE-15   #Tail and stop lamp, license lamp, back up lamp
BE-10
  • Removal
LIGHTING SWITCH
BE-11
BE-11
HORN
BE-15 HORN
Main: Horn
METERS AND GAUGES
METERS AND GAUGES BE-18
CLUSTER LID BE-18
SPEEDOMETER BE-19
FUEL GAUGE AND TEMPERATURE GAUGE BE-19
OIL PRESSURE AND IGNITION WARNING LAMPS BE-20
HAND BRAKE WARNING LAMP BE-21
BULB SPECIFICATIONS BE-21
TROUBLE DIAGNOSES AND CORRECTIONS BE-22
  Speedometer BE-22
  Thermometer and fuel meter BE-23
  Oil pressure and ignition warning lamps BE-23
BE-26 WINDSHIELD WIPER AND WASHER
Main: Wipers
BE-29 IGNITION SWITCH AND STEERING LOCK
CLOCK
BE-31 CLOCK
Main: Clock
RADIO
BE-32 RADIO
Main: Radio
HEATER
BE-34 HEATER
Main: Heater
