Steering wheel
Revision as of 03:23, 9 March 2025; view current revision
Categories: Body | Steering System
Datsun 1200 and Truck variants were fitted with a variety of steering wheels. They are 15 inch diameter wheels (overall diameter 15.75"/40cm). They have a 5/8" (16mm) thick rim section.
Connects To
B110
GL, DX and GX comparo
27308.jpgbrochure
#DX (1-spoke) used on Standard and Deluxe trims. Also used by 1971-1978 Truck.
3700.jpgAlbum 3700
#GL (3-spoke)
6467.jpgAlbum 6467
#GX (3-spoke metal)
3158.jpgAlbum 3158
SSS
6595.jpgAlbum 6595 6787.jpgAlbum 6787
PB110 used the same steering wheels as B110
460.jpgAlbum 460
#B120 Sunny Truck 1980s | 1990s
21323.jpgAlbum 21323 21324.jpgAlbum 21324
B10
The Datsun 1000 (B10) wheels were different from B110 items.
STD | GL | SPORTS
14227.jpgAlbum 14227 3626.jpgAlbum 3626 20578.jpgAlbum 20578
NOTE B210 handle will bolt to the 1200 steering column.
DX
GL (available in plastic or wood-like)
10874.jpgAlbum 10874
GX Type (available in leather or wood-like)
3656.jpgAlbum 3656
B310
B310 steering wheels reportedly use a different spline and so apparently do not fit B110 or B210 steering column.
B310 GX in B110
25884.jpgAlbum 25884
Nismo
Nismo 10th Anniversary
20652.jpgAlbum 20652
240Z OPTION looks similar - and does not fit 1200
12579.jpgAlbum 12579
Appears to have Horn Pad 48410-E4600 (S30)
The Colin handle looks very similar but comes with different horn buttons. コーリン ダットサン ハンドル
Removal and Installation
First, remove the horn pad. To remove the horn button, remove the two screws from behind the wheel (B110 normal) or push in and twist for GX type.
STD/DX: screws on back side
GX type - push in and twist anti-clockwise to remove
26420.jpgAlbum click to view 26421.jpgAlbum click to view
Next, unbolt the steering shaft large nut. Do not remove it all the way, keep it on so the wheel won't fly off while popping the wheel from the shaft.
Be sure to use a wheel puller:
5106.jpgAlbum 5106
Occasionally you can remove the nut and "pop" it off by hitting it from behind with your fists, but you risk the chance of having it hit you in the face when it pops loose. Discussion
Be safe, don't worry. Only about $15 new for a simple type.
24703.jpgAlbum 24703
Ute wheel in Coupe
2689.jpgAlbum 2689
B210 GX in B110
9848.jpgAlbum 9848
B210 GL in Datsun 1200
13914_4df4b7a34787b.jpgPost 371646 25886.jpgAlbum 25886
Other wheels fit the hub but may not match the trim. The B110 steering wheel hub uses the same bolt pattern as:
45mm between bolts (1-15/16 inch)
* 1970-1976 B110 (Sunny/1200)
* 1974-1978 B210 (Sunny/120Y)
* 1977-1979 S10 (Silvia/SX200)
* 1976-1977 F10 (Cherry)
* 1979-1982 N10 (Pulsar/210)
Only three Datsun models used the small diameter steering column shaft, those models being the B10, B110 & B210. The B10 used blinker canceling pins that were reasonanly close together & this made it unique, The B110 & B210 share the same specs so the hub/boss is interchangeable between these two models.
B310 GX in B110 (with B110 GX horn button)
2129.jpgAlbum 2129
26308.jpgAlbum 26308
All other Datsun models [at least those from the mid 60's], including the B310, used a larger diameter shaft & the boss for any of these will be too big in the hole.
B110
Including PB110
48498-H1000 EMBLEM 'S' MARK DX
48498-H1100 EMBLEM 'D' MARK DX
#DX Two-spoke 48400-H1000,48400-H1001 ASS'Y-WHEEL-steering Std, Dx
#GL Three-spoke 48400-H2000,48400-H2001 ASS'Y-WHEEL-steering GL
#GX metal three-spoke 48400-H2300,48400-H2301 ASS'Y-WHEEL-steering GX
OPTIONAL - There were two Optional Steering Wheels
  • 48400-H1200 ASS'Y-WHEEL-steering (wood) OPTION ALL (per JDM catalog)
    metal three-spoke, one-slot spokes covered with plastic trim
  • 48400-H2310 ASS'Y-WHEEL-steering (foam skin) OPTION ALL (per JDM catalog)
    metal three-spoke (at 2, 10, and 6 o'clock), one-slot spokes uncovered
    14654.jpgAlbum click to view
5298.jpgAlbum click to view
These wheels were derived directly from the B10 option wheel. They made a new hub (boss) to suit the 1200 column & a new horn button to 'update' them but are otherwise the same.
The optional wheels are different from the B10 mainly in the horn button and the hub part (the wheels themselves appear to be the same, but were only sold as an assembly).
  • The 1200 horn button is wider at the top, and narrower where it bolts to the wheel
  • The 1000 horn button is the opposite (narrower at the top)
Also, the 1200 hub part where it meet the steering column is bigger diameter. So the 1200 hub flares out slightly to this larger diameter. The 1000 hub is completely cylindrical.
Note that the 1000 hub on the right is cylindrical & has closely spaced blinker pins, while the 1200 hub on the left is conical, or bell shaped & has pins more widely spaced.
The wheel & the complete horn switch assembly are identical between the B10 OPTION wheel and the B110 OPTION wheel.
DX
3700.jpgAlbum 3700
GL
457.jpgAlbum 457 GL_handle-1.jpg GL_handle-2.jpg 48400-H20_a.jpg 48400-H20_b.jpg
GX
27710.jpgbrochure
48420-H2325 ASS'Y-PAD, horn GX
48498-H2300 EMBLEM-'GX'
metal three-spoke, each spoke has a divided slot
21781.jpgAlbum 21781 460.jpgbrochure 21782.jpgAlbum 21782
20500.jpgAlbum 20500 6420_5c245d42bc651.jpgPost click for topic 6420_5c245d4844684.jpgPost click for topic
174_5d6c1978354fa.jpgPost 492427 174_5d6c19806668d.jpgPost 492427 174_5d6c1a99ad5dc.jpgPost 492427 174_5d6c1aa2026a7.jpgPost 492427
B120 Sunny Truck
#Early Black | #Mid Brown | #Late Gray
Center Emblem
* 48498-H1000 -7803 NLA
* 48409-H5002 7804-7907
* 48409-G1660 'S' 7908-
  27043.jpgAlbum 27043
Early Black
Early 1971-1978 B120 used the B110 STD/#DX wheel, same as coupe, sedan and wagon
21325.jpgAlbum 21325
48400-G1000 -7803
18259.jpgAlbum 18259 11149.jpgAlbum 11149
Mid Brown
1978-1989, same as B210 steering wheel#STD, DX (brown only)
48400-G1060 7804-7907 Dark Brown
48400-G1660 7908-8910 Brown
Late Gray
1989-1994, same as before except Gray
48400-95W00 8910- [Gray]
Bakkie
South Africa B120, 120Y & B140 bakkies
1979-1989 brown
1990-2008 brown or gray
30090.jpgAlbum 30090 13025.jpgAlbum 13025
S10
1977-1979 Datsun 200SX (Silvia) used a steering wheel that looks like the B210 GX wheel.
  • Black 48400-N5810/48400-N5815
  • Brown 48400-N5811/48400-N5816
  • Brown, light 48400-N7800 1979
  • Green 48400-N5812/48400-N5817
  • Blue 48400-N7801 1979 only
Does this fit small shaft (B110/B210) or large shaft (B310)?
Aftermarket Wheels & Hubs
Aftermarket steering wheels look great and have better shapes and sizes than factory wheels.
Aftermarket steering wheels generally require an adapter hub.
Cherry
See also: X-1R
E10 Nissan Cherry wheel in B110
Pulsar
Nissan Pulsar EXA steering wheel in B110
1327.jpgAlbum 1327
misc
Unknown Datsun
33704364422_9f3314ff22_z.jpgflicker click to view
Datsun B10 OPTiON wheel with aftermarket (Nismo?) 'GT' horn button
12703_4b51d0e0898c6.jpgPost 300158
aftermarket horn button (fits GX wheel?)
Left: 240Z wheel modded for 1200 | Right: B10 wheel with Nismo horn button
5372.jpgAlbum 5372
ステアリング ホイール ハンドル
