Rocker cover
Revision as of 02:52, 9 March 2009; view current revision
Category: Engine Mechanical
The Rocker Cover or valve cover covers the top of the Cylinder head including the Rocker arms and valvesprings. The rocker cover is painted Datsun Blue, which is a darker blue than the air cleaner. The rocker cover is also known as a valve cover or tappet cover.
1346.jpg '90s A-series
Also see: Oil cap
  • B10 (A10 engine): Black 'Datsun' label on top
  • Datsun 1200 A12: Embossed 'Datsun', single threaded boss on right side for fuel rail
  • B210 A14: No threaded bosses on side (fuel rail does not bolt to rocker cover)
  • B310: Embossed 'Nissan'
GX Cover
For the twin-carb 1200GX Engine#Rocker Cover:
  • fuel-rail mounting brackets are in different place
  • choke cable bracket is in different place
Breather
See: PCV System
Customizing
Polishing
Chrome Plated
Painting
Alloy Covers
Aluminum light-alloy covers were never shipped on a Datsun 1200, but newer engine covers and aftermarket covers are available.
Nissan Pulsar OEM cover
Armbrust
Nippon Armbrust
Tomei
Morris Minor World
Others
GASKET-ROCKER COVER
  • 13270-18000, 13270-18001 B10, B110, B210 to '74-5
  • 13270-H1000 B210 from '74-6, B310 all
  • 13270-H1010 B310 [select use?]
COVER ASS'Y-valve rocker
  • 13264-18001 B10
  • 13264-18002 B10 from engine A10-173620
  • 13264-18003 B10
  • 13264-H0100 B10
  • 13264-H1000 'Datsun' B110 exc. GX
  • 13264-H2300 B110 GX
  • 13264-H7800 'Datsun' B120 7510-7907
  • 13264-W8501 'Nissan' B120 7908-8910
  • 13264-95W00 'Nissan' B120 8910-
  • 13264-H5001 'Datsun' B210 A12S
  • 13264-H5702 B210 A12T
  • 13264-H7200 B210 A14S Van
  • 13264-H7800 B210 Van
  • 13264-H8200 B210 A12S Sedan, Coupe
  • 13264-H8400 B210 A14T
  • 13264-H7800 B310 Van to 7909
  • 13264-W8501 B310 Van from 7910
  • 13264-H8500 B310 A12S, A14S Sedan, Coupe
  • 13264-H9200 B310 A14E to 7909
  • 13264-H9201 B310 A14E 7910-8010, A15E 8011-
  • 13264-G3400 B310 A13S, A15S 8011-
B310 USA
13264-H7201 B310 A12A USA -0780
13264-H9500 B310 A12A USA 0880-
13264-H7201 A14 FED (KFU), A14 CAN
13264-H7260 A14,A15 FED (EXC KFU) A14,A15 CAL
13264-H9500 A14,A15 USA 0880- 13264-H7260
