Overhaul
From Datsun 1200 Club
Category: Engine Mechanical
When overhauling the engine due to low compression or excessive blowby, new piston rings are installed to bring it back to specification. Normally a re-bore and new pistons are not required -- it is not part of an overhaul. All other parts are inspected and measured (but only replaced if damaged or out-of-specification). To finish the overhaul, new gaskets are installed.
If your engine is requiring an overhaul, consider saving time and money by purchasing a good used engine. Often one can be found on trader sites or by asking in the Classifieds. This is also a good time to upgrade to an A14 or A15 engine.
Also see:
*  Engine Overhaul & Service Data (in Japanese)
  • If you are only trying to fix oil leaks, a re-gasketting is called for and an overhaul is not needed
  • If the engine has a rod knock or main bearing knock it probably needs and overhaul. But you may only need to replace the bearings if the engine is in otherwise good shape.
  • If the engine sometimes doesn't run right, don't start with an overhaul but instead troubleshoot it. It may an ignition or carburation issue -- which an overhaul won't fix
Engine overhaul includes:
* New piston rings
* New Rod bearings and Main bearings (if required)
* New gaskets
* Replacement of any out-of-spec parts
Parts that are unlikely to last another 100,000 miles/160,000km are often replaced even if still in working good condition, including the Water pump. Bolt-on Accessories such as Smog Pump and alternator are not part of an engine overhaul.
Not normally part of an overhaul unless out-of-spec or damaged:
* Cylinder Block
* Cam bearings
* Camshaft
* Head milling
* Bolts, including Rod bolts and Head Bolts
* Carburetor, Distributor or Alternator
Installation
When installing an overhauled engine, it is customary to replace these parts:
Overhaul vs Re-manufacture
A re-manufactured engine is a used engine restored to as-new condition. As such, ALL service parts are replaced even if they are working fine or within factory specification.
9764_51458ddc008e4.jpgPost 432430
* Pistons
* Piston rings
* Bearings
** Main Bearings
** Rod Bearings
** Cam bearings
* Camshaft and Lifters
* Cylinder Head:
** Valve springs
** Rocker arms
* Timing Chain and tensioner
* Gasket
* Oil pump
* Welch Plugs
* Acessories including:
** water pump
Non-service Parts
Non-service parts do not require periodic service, last indefinitely, and are not normally replaced unless damaged. They should of course be inspected at overhaul or remanufacture time:
* Pushrods inspected for straightness
* Bolts including
** Head Bolts
** Rod Bolts
** Main Bearing Cap bolts
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Overhaul"
This page has been accessed 4,145 times. This page was last modified 10:15, 1 May 2018. Content is available under Datsun 1200 Club.
