Tunnel
From Datsun 1200 Club
Categories: Body | Transmission | Automatic Transmission
Datsun 1200 originally fitted with automatic transmission has a much larger tunnel. It makes it easier to swap in larger transmissions or larger engines.
Comparo: Manual transmission cover vs automatic transmission cover
18963.jpgAlbum 18963
Manual Tunnel is very small to fit the small stock transmissions and increase space inside the passenger compartment:
884.jpgAlbum 884 2133.jpgAlbum 2133
The manual body has one piece lower dash panel with no joins whatsoever - the bellhousing part of tunnel is one piece with firewall.
26010.jpgAlbum 26010
By contrast the Auto body has separate dash panel and floor. The transmission cover is spot welded in. The welding seam is clearly noticeable on the firewall at the back of the engine.
7475.jpgAlbum 7475
Manual tunnel has no seam
7476.jpgAlbum 7476
8197.jpgAlbum 8197 174_57f59d054a0b9.jpgPost 295233
NOTE: Unlike a B110, the B210 has the same floor auto and manual - the stick and slushbox tunnels are the same on a B210.
Swapping Tunnel panels
You can swap the larger automatic tunnel into a manual transmission car. The B210 tunnel is nearly identical to the 1200 automatic tunnel. In turn, the 610 (180B) tunnel is nearly the same as the B210 tunnel. See #Tunnel Swaps below.
Modified Tunnel
Just take a big hammer and bang the tunnel sheet metal ("massage it") to get more clearance.
880.jpgAlbum 880
Or cut part of the tunnel and weld on a bigger section
438.jpgAlbum 438
You can also move the gearbox mounts back to suit various transmissions
5008.jpgAlbum 5008
Maddat Tunnel
Product No TT1200SR Transmission Tunnel. Suit 1200 with SR20 or CA18 Gearbox. Comes with rubber gear stick boot. These can be installed in about half a day.
Note: fitment requires removal of heater box.
For 1200 SR conversions, it will allow the gearbox to be removed while the engine is still in the car. Very simple to install, just sit over existing tunnel, trace with texta. Then cut out inside the line by 10mm, weld the tunnel from inside the cab. From underneath now tap up that 10mm lip (can be made easier if heated up with oxy), run some seam sealer around the joint to finish off.
14580.jpgAlbum 14580
Custom Tunnels
Others have successfully bolted or welded in tunnels from:
Tunnel Swaps
The standard B110 uses one piece lower dash. The Auto dash is two pieces (lower dash + cover).
The rear half of the tunnel is part of the floor
26009.jpgAlbum 26009
In actual practice when swapping, the "tunnel" is cut out of the dash and floor.
manual transmission
67300-H1000 ASS'Y-PANEL, dash, lower [manual transmission]
74300-H1010 ASS'Y-FLOOR, front [manual transmission]
74306-H1020 ASS'Y-PANEL, A/T floor cover, front [automatic transmission]
67300-H1021 ASS'Y-PANEL, dash, lower [automatic transmission]
74300-H1021 ASS'Y-FLOOR, front [automatic transmission]
Auto Tunnel Swap
Auto tunnel is very large to fit the 71-series Automatic Transmission, but still fits under the heater box.
8539.jpgAlbum 8539
Auto Tunnel retrofit - tunnel can be cut out, then the new tunnel welded to the floor & firewall:
18965.jpgAlbum 18965
8710_4d510d896ac3e.jpgPost 356203 8710_4d510dca2bb13.jpgPost 356203 8710_4d8d9c50cdd42.gifPost 361190 18964.jpgAlbum 18964
Shoey's diagram
jay_t_dim_sm.jpgPost click for topic
B210/610 Tunnel
Includes 120Y & 180B.
Fits into 1200
19957.jpgAlbum 19957
Fits into a 1200 and still allows for a stock heater:
8527.jpgAlbum 8527 10242.jpgAlbum 10242
NOTE: All B210/120Y use the larger size tunnel
However the B210 floor pans differ:
  • from 1200 as to where the transmissions mount points are. You can move the brackets if necessary
  • B210 used eight different tunnels. See Tunnel Comparison.
A10 Tunnel
Several club members have fitted an A10 Stanza tunnel to the 1200.
unfamilia:
the satnza tunnel in- looks ok, but i wouldnt recomend it as an easy swap(my first one but piggys 3rd or 4th one). 120y was most stright forward he said, but heaps of room around this one
A10 tunnel in 1200
21199.jpgAlbum 21199
B310 Tunnel
B310 Sunny tunnel is same as A10, but for A-series gearboxes.
17554_598098d4d9f46.jpgPost 485749
Shifter Location
Stock shifter location is well forward of the seat rail riser
10318_4c46da6abdaec.jpgPost 328659
Photo showing where to cut the tunnel to fit a standard "short" L-series or CA-series transmission.
2118.jpgAlbum 2118
Cut the hole bigger ...
12055.jpgAlbum 12055
Or just move the hole back and weld it back in:
9582.jpgAlbum 9582
1200 auto tunnel with shifter location raised and moved back | stock tunnel
003-1.jpgPost click for topic 26416.jpgAlbum 26416
71-series Modifications
71-series Transmission is used by later L-series engine, Z-series engine, FJ-series engine, CA and SR engines.
S13 gearbox clearance in manual tunnel
4696.jpgAlbum 4696
Rear of tunnel modification:
5064.jpgAlbum 5064
Reverse Lamp
To fit a 60-Series Transmission 5-speed, move the gearbox Mounts 115mm back:
5009.jpgAlbum 5009 5008.jpgAlbum 5008
To remove the brackets, drill out the spot welds
24199.jpgAlbum 24199
56A Modification
To clear that nasty clutch fork in the later type 56A trans
5843.jpgAlbum 5843 23057.jpgArticle click to go
See Also
Also see: Transmission tunnel Photo Index
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Tunnel"
This page has been accessed 32,387 times. This page was last modified 20:39, 1 August 2017. Content is available under Datsun 1200 Club.
