Head Porting
(Redirected from Porting)
Category: Cylinder Heads
Head porting means to re-shape the cylinder head inlets/outlets for better flow. Either to smooth out the original castings for improved power, or to enlarge them for higher RPM.
See also: CCing
There are two types of porting:
  • Porting for maximum HP. The downside is that power shifts to high RPM (power at low RPM is reduced). The full length of the ports are enlarged. If your goal is maximum HP, better to get the best head to start with (GX with A14 valves or Nissan Competition head)
  • Porting to maximum the head efficiency. By doing 1) #Port Matching and 2) Bowl Cleanup you ensure the head is working well (and there is no downside, all RPM is improved)
1777.jpgAlbum 1777
Quote by sagemanone:
Port and polish will yeild power gains and 3 or 5 angle valve grinds help also hand grinding the sharp lips in the valve pocket helps the flow into the combustion chamber. Any reputable high performance machine shop should be able to do any of the work to your head you ask them to do if you ask them for spacific items to be done. If they seem puzzled or can't answer ALL your questions real easily take your head and run the other way. Don't be discouraged and don't be afraid to try to be creative . I heard of guys cutting down L16 valves after modifying the ports and installing the matching seats in an A14 to get marvelous increases in flow .So let your pocket book and imagination guide you.
One other thing ,Look for the factory goodies like the GX option stuff that could be ordered like the GX duel SU intake ( Iam looking for one myself) And NISMO still has some neat stuff they sell right out of a catalog . Iam hoping to put a list togather that will be on My web page as to the sources for all the places for the parts we Datsun A/nuts need . I hope to Launch that web page soon and you will all be invited!!!
All Datsun A-series engines come from the factory with a 3-angle valve job (even though most V8s didn't have this good feature). So certainly don't do anything less!
PortsSize (mm)ExhaustRaisedNote
round2827x26no1971 A12
round28?lowered1977 GFU
Oval - Small28x30?no1973 A13
Oval - Medium28x3228x26noA14E, A15E
Oval - Regular28x3428x26noMany A14s
Oval - Large (GX)30x35 - 3627x29 or 28x26YesA12GX (1971-1973)
Quote by azza_bijan:
Go for the high comp. head (not dished out). These have 9.5:1 compression. A15s in AUS are mainly high comp Don't enlarge the ports matching to the inlet, they are already large enough. Enlarge around the exhaust valve area and out and get some cut down 1600 valves to fit. The exhaust porting hugely boosts better flow and power. If you are rich or race, do the inlets. I got my head done for $300AUS. Then get good manifolds (handmade steel inlets $200AUS are as cheap as new aluminiums but are port matched to the head and work heaps better).
"high comp" means closed chamber heads, which yields maximum HP. The "dished out" heads are the open chamber type, which reduce emissions with the downside of slightly lower HP and more temperamental timing issues (including dieseling run-on problems). Either type can be used with high compression.
Closed Chamber (heart-shaped) VS Open Chamber
26426.jpgAlbum 26426
9.5:1 compression is achieved by using lesser dish in the piston, which the H89 engine uses. Datsun also used closed chamber heads on 8.5:1 engines, by fitting pistons with a larger dish. See Compression Ratio for more information.
BIG port, semi-open chamber by Reg Cook
26229.jpgAlbum 26229
Port Matching
The goal of port matching is to smooth the transition of the head and manifold. It's not to increase flow for higher rpm, but rather to prevent loss from different sizes. For example where head is smaller than manifold. Use a gasket matching the larger port (trim it to match), then use Dyekem Blue to paint to the piece using the gasket as a stencil.
Use a Dremel tool and remove only enough material to match. You can also use a round hasp file, take your time and it'll come out OK. With a Dremel, use a carbide bit for the rough cuts, a sand paper cone to clean it up (or, a butter cutter may also work for both).
GX port 2mm higher than A14/A15 oval port
26770.jpgAlbum 26770
Rallytwit: As for port matching just make sure you take a little at a time, the GX intake should have a larger port than the H89 head ... Start by getting rid if the step and just get a smooth transition. I'm not a porting expert by any means but I'd say maybe all of an inch into the head at most.
Sometimes the inlet manifold is smaller than the head ports -- especially after a full port job has been done to the head. In this case, grind the manifold out to match:
26454.jpgAlbum 26454
Bowl Cleanup
A 5-angle valve job is said to be as efficient as a fully smoothed seat (stock is 3-angle valve job). In any case, make sure the valve seat to intake bowl transition doesn't have any sharp edges/mismatches.
Tapered valve guide | Short-side radius smoothed out
4414.jpgAlbum 4414 4415.jpgAlbum 4415
Tools
Flow
Professional porters use a Flow Bench to measure the airflow of the unmodified cylinder head, then after smoothing or enlarging the port, measure the flow again. This is to ensure the modifications actually work. Not only should the airflow improve, but the air/fuel charge swirl must not be retained.
It is entirely possible to enlarge the ports, yet ruin the airflow of the head
Example 1
dattoman's cylinder head
measured at 25" water pressure
A14 regular oval port head with 38/33 (oversize) valves
NOTE: Measurements taken for lifts up to .600 inch. Standard cam is .315" lift x 1.44 rocker ratio = .454 inch. Note that flow of this head doesn't improve much after .500" or so. So this is appropriate for a valve lift about .500". To obtain this high valve lift, 1.65 (high-ratio) rocker arms may be used with a stock lift cam (8mm cam lift) for a lift at valve of .519".
Notice too that airflow has increased even at stock lifts, so a high lift is not strictly necessary for improved horsepower. But higher lift will give additional power.
UNMODIFIED PORTS w/oversize valves
LIFT(inch) .100  .200  .300  .400  .500  .600
INTAKE CFM 52.89 91.62 118.3 118.6 124   126.8
EXAUST CFM 43.03 71.71  93.5 111.1 124.2 129.6
AFTER MODIFICATION
INTAKE CFM 59.14 103.3 129.7 135   140.6 141.2
EXAUST CFM 52.37 80.92 103.4 122.8 129.2 130.9
This flow chart also notes the Swirl, which is good at all lifts, indicating the engine will most likely run good at all speeds and throttle openings. Some engines (for example, the Street Hemi) has massive flow but poor swirl and didn't run well at partial throttle -- which is OK for the drag strip but not good for street driving.
Example 2
rally1200's cylinder head
measured at 32" water pressure
A14 standard head
Measured at 32" water pressure -- so it's not directly comparable to CFM ratings measured at 25"
NOTE: Flow measurements were done for lifts up to .460", which is approximately the maximum of the stock cam profile (standard lift)
LIFT(inch) .100  .200  .300  .400  .460
INTAKE CFM 52.1  96.82 115.8 121.8 119.3
EXAUST CFM 42.2  69.1   86.2  96.7 101.1
AFTER MODIFICATION
INTAKE CFM 52.37 97.82 133.4 150   154.4
EXAUST CFM 46.39 76.33 93.51 106.4 113.1
14509.jpgAlbum 14509
Porting For Maximum Flow
kale: had it on the dyno to tune the carbies and was making circa 110hp at the treads
kale A14/A15 port: "flows enough for 160hp" via 42mm in. 33mm exh. smaller 7mm stems
12144.jpgAlbum 12144 12143.jpgAlbum 12143
Profile
H89 (A14/A15 oval port) casting thickness
14435.jpgAlbum 14435 14434.jpgAlbum 14434
A14 oval port head cross profile:
1017.jpgAlbum 1017 1018.jpgAlbum 1018
GX profile
th_1746.jpgAlbum click to view
th_1747.jpgAlbum click to view 1777.jpg 1791.jpg 4414.jpg 4415.jpg 4416.jpg 4744.jpg 4949.jpg 5215.jpg 5536.jpg 5537.jpg 6257.jpg 10426.jpg 11276.jpg 11286.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Head_Porting"
This page has been accessed 34,507 times. This page was last modified 20:49, 29 May 2019. Content is available under Datsun 1200 Club.
