There is no page titled ":08310". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Radio (17165 bytes)
334: * 08310-50812 SCREW(FOR UNIT) OP - Engine block (4022 bytes)
16: 08310-61214 SCREW-MACHINE (2) - Seats (12925 bytes)
241: * 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
242: * 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FI... - EGI (26751 bytes)
247: * 08310-40814 SCREW (2)
441: ** 08310-51614 BOLT (10)
573: * 08310-53012 SCREW - Glovebox (4083 bytes)
85: 08310-41662 SCREW-MACHINE M4 (2)
96: 08310-41691 SCREW (2) - Headlights (12557 bytes)
266: [[NES_Part_Numbers#3|08310-40812]] Rim-retaining screw (3 per side) - Horn (5033 bytes)
115: * 08310-51014 SCREW (fixing horn relay) - Trunk (6282 bytes)
54: 08310-50812 SCREW (3) - Rocker cover (9250 bytes)
198: ...08360-61612 SCREW-MACHINE FIXING ROCKER COVER 6 > 08310-61612 $0.65 - Block & Pan Part Numbers (3896 bytes)
39: 18 08310-61214 SCREW-MACHINE (2) - Head Part Numbers (4318 bytes)
72: ...08360-61612 SCREW-MACHINE FIXING ROCKER COVER (6) 08310-61612
73: 21 08310-61612 SCREW-MACHINE FIXING ROCKER COVER (6) - Manifold Part Numbers (1933 bytes)
35: 19 08310-51610 SCREW-SET A12 - Oil Pump Part Numbers (1423 bytes)
21: 5 08310-53010 SET-BOLT BODY TO COVER A12 - Fuel Part Numbers (24315 bytes)
382: * 08310-40812 SCREW 3 SEDAN EVAPO -
429: * 08310-40812 SCREW-MACHIN 3 COUPE - - Accelerator Pedal (2831 bytes)
35: 08310-51014 SCREW
39: * 08310-51214 SCREW (2)
75: * 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX - License Lamp (4394 bytes)
31: * 08310-41420 SCREW (2) - Back Door Part Numbers (2137 bytes)
48: 08310-61414 SCREW-with lock washer 4 1972
49: 28 08310-62062 SCREW-with lock washer 4
57: 35 08310-62014 SCREW-with lock washer 4 - Raw List (34158 bytes)
64: 08310-61214 SCREW-MACHINE
144: 08310-61612 SCREW-MACHINE FIXING ROCKER COVER
380: 08310-51610 SCREW-SET
426: 08310-53010 SET-BOLT BODY TO COVER
634: 08310-40812 SCREW - Raw List 2 (24619 bytes)
54: 08310-40812 SCREW
101: 08310-40812 SCREW-MACHIN
390: 08310-51062 SCREW-MACHINE WITH LOCK WASHER
420: 08310-30612 SCREW
429: 08310-61014 SCREW - Raw List 3 (29968 bytes)
561: 08310-51012 SCREW
