There is no page titled ":Wiper". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Wiper Motor (3035 bytes)
1: ...onal standard type rotary electric [[Windshield]] wiper motor.
4: * [[Wipers]] for linkage, blades & inserts
6: * [[Wiper Motor Repair]]
7: * [[Wiper Motor Upgrades]]
8: * [[Wiper Wiring]] - Wiper Wiring (4007 bytes)
1: {{BackTo|Wipers}}
3: ...ts to ground (earth). 12V is supplied to both the wiper motor and washer motor by the same fuse whenever ...
5: {{See|Intermittent Wipers}}<br>
6: = Wiper Motor =
9: ... not turn until GROUND is supplied by pulling the wiper switch knob. - Wiper Motor Repair (13662 bytes)
1: The Datsun 1200 windshield/windscreen [[Wiper Motor]] is very reliable. A 38-year-old unit was ...
4: Also see: [[Wiper Motor Photo Gallery]]
7: ...otobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiper/th_20100207113115DSC08495.jpg
11: ...otobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiper/20100207101824DSC08422.jpg photo]
12: ...otobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiper/20100207101824DSC08422.jpg</img> - Wiper Motor Upgrades (1567 bytes)
1: Datsun 1200 uses wiper motor with two speeds: Slow and Normal. What can ...
3: ...e: [[Wiper_Motor#Intermittent_Wipers|Intermittent Wipers]]
5: = Honda Wiper Motor Upgrade =
6: ...civic+del+sol,1.6l+l4+sohc,1169030,wiper+&+washer,wiper+motor,8824 $76 Rockauto]
12: ... amplifier from a Datsun 1200 with [[Intermittent Wipers]]. - Wiper Relocation (778 bytes)
1: ... for a smooth look, then reverse mount (hide) the wiper washer motor behind firewall. Would it need to be...
6: For more detail photos, see [[Wiper Motor Repair]]
9: ...>{{Photo|20100207101244DSC08418.jpg|Datsun%201200/wiper}} - Wiper Switch (4213 bytes)
1: Also see: [[Wipers]] and [[Wiper Wiring]]
4: Datsun 1200 came with two different wiper switches.
5: * New (intermittent) Wiper Switch: rectangular 6-connector
6: * Old (original type) wiper switch: square 6-connector with blue wires
10: <br>New Wiper switch (intermittent type) has one blue wire. - Wiper Part Numbers (2704 bytes)
2: [[Wipers]]
6: 28880-H1000 DRIVE ASS'Y-windshield wiper (up to '72-9)
7: 28880-H1001 WINDSHIELD WIPER ASSY (from '72-10) > 28880-H1000
23: 26380-H1000 ASS'Y-ARM, wiper 2
24: 26380-H2300 ASS'Y-ARM, wiper 2 GX [aerofoil type] - Wiper Motor Photo Gallery (3987 bytes)
1: [[Wiper Motor Repair|<-- Return to Wiper Motor Repair]]
3: ... {{Photo|20100207105246DSC08475.jpg|Datsun%201200/wiper|width=SM}} - 620 Wiper Switch (4942 bytes)
1: {{BackTo|Wiper Switch|620}}
3: Datsun [[620]] truck uses a NILES wiper switches look identical to Datsun 1200 switches, ...
8: ... Datsun 620 with Deluxe trim have an intermittent wiper switch
10: Datsun [[620]] truck uses a NILES wiper switches look identical to Datsun 1200 switches, ...
12: All 620 wiper switches use Datsun 1200 [[knobs]] (type H10 or H...
Page text matches
- Parts Sources (15979 bytes)
28: * Wiper blade - Part Numbers Index (8259 bytes)
97: [[Wiper Part Numbers|Wiper & Washer]] - Datsun B10 (14041 bytes)
141: ... lamps, Back-up lamp, Double tone horn, Two speed wiper, Cigarette lighter, Windshield washer, Additional... - Bar Cluster Gauge (2347 bytes)
14: four holes for Choke cable, Wiper Switch, Light Switch - B20 (4330 bytes)
29: * STD model now gets 2-speed wiper as standard equipment
62: two-speed wiper motor
72: anti-skate wiper blades
98: 2-speed wiper (1969) - MIN712 (3084 bytes)
32: (oil, overflow and wiper water) - Wipers (8777 bytes)
1: The wiper motor bolts to the engine compartment firewall. L...
4: The windscreen wipers are about both the outside parts, and the linkag...
9: * Wiper Motor
21: <br>'''WIPER AND WASHER SWITCH'''
22: ...r low speed and the second is for high speed. The wiper switch also controls the windshield washer. To op... - Options (10139 bytes)
15: ☐ [[Wipers|Anti-wind lift wiper blades]]
108: * [[Wipers|Wiper]] Switch kit
109: * [[Wipers|Wiper]] Blades
195: * [[Wipers|Anti-wind lift wiper blades]] - Instruments and Controls (12492 bytes)
274: == Wiper and Washer Switch ==
275: <br>{{SeeEx|see=Main|Wipers#Operation|Wipers}} - Dashboard removal (7203 bytes)
23: ... troubleshoot wiring, or to replace/lubricate the wiper linkage. Having the dash out makes changing the r...
83: * Lubricate the wiper linkage. This is a Heim-joint/rose-joint type of ...
103: ... lid is held in place mostly by the knobs (Radio, Wiper Switch, Lighting Switch and Choke). - Wiring Diagram (7077 bytes)
159: 12. Windscreen wiper
164: 17. Windscreen wiper switch - A12GX Part Numbers (8108 bytes)
212: * 26380-H2300 ARM ASS'Y-wiper 2
213: ** 26381-H2300 NUT-wiper arm 2
214: * 28360-H2300 BLADE ASS'Y-wiper 2
215: * 26370-A4001 BLADE ASS'Y-wiper 2 GX-5 (op. on all other models) - Kangaroo Bag (3274 bytes)
3: ...mmer, plain water may be used, but in winter only wiper fluid with anti-freeze properties should be used ...
16: * Turn key to ON, twist wiper switch to verify correct washer action.
49: {{See|Wiper Part Numbers}}
58: [[Wiper Part Numbers|27440-H1001]] NOZZLE ASSY-WASHER B11... - Periodical Maintenance and Lubrication Schedule (3155 bytes)
68: * Check [[Wipers|Windshield Wiper]] blades - Chrome Trim (1561 bytes)
20: * [[Wipers|Wiper]] arms - B310 Parts Donor (4306 bytes)
20: * The wiper motor and other electrical parts have reverted to... - Fuse Box (12072 bytes)
17: * 'W' 15 AMP Wiper, Washer, Heater
93: 15A RADIO HEATER WIPER ラジオ ヒータ...
115: 15A Radio Heater Wipers
176: * [[Wiper Wiring|Wiper]] - Turn Signals (8098 bytes)
247: * Wiper switch - B210 Honey Bee (9685 bytes)
69: * No Wiper blade high-speed fin (uses basic type from 620 tr... - Sunny Truck Wiring (1960 bytes)
46: * 25260-G1060 SWITCH ASSY-WIPER 8110-
47: also 7804-8109 w/INTMT WIPER
48: * 28890-B8060 AMP-INTERMITTENT WIPER
