Bike Carbs
From Datsun 1200 Club
Category: Fuel System
Motorcycle carbs, bike carbies. Flat-slide, constant vacuum or variable venturi carburetors.
TUNING is critical. Bike carbs as-is run poorly on automotive engines. But with the right jet or needle selection they can run very well.
20090614115344DSC07055.jpg 13162.jpgAlbum 13162
bike carbs on A12Y engine
449.jpgAlbum 449
adapt carbs from your favorite motorcycle
12690.jpgAlbum 12690
Suzuki GSX-R (aka GSXR)
11716.jpgAlbum 11716 14887.jpgAlbum 14887 17584.jpgAlbum 17584 18108.jpgAlbum 18108 18109.jpgAlbum 18109
Yamaha YZF-R1 (aka R1) carbs are a fad in USA as of 2012.
ヤマハ
Adapter Kits
* Tube & Flange adapters
* Cast/Machined adapters
* Welded adapters
* Twin Weber manifold
Tube & Flange
24290.jpgAlbum 24290 19320.gifAlbum click to view
Machined adapter
19966.jpgAlbum 19966
Cast adapter
18714.jpgAlbum 18714
MSR carbs fit any DCOE type manifold
2583.jpgAlbum 2583
Fits on modified standard manifold
18837.jpgAlbum 18837 4830.jpgAlbum 4830
Custom Manifolds
Fabricate your own manifold
16247.jpgAlbum 16247 18181_5728b8ed6c09b.jpgPost 478584
Keihin CV
The Keihin brand were used on nearly all brands of bike, Yamaha, Honda, Suzuki, Triumph etc.
CV (Constant Velocity) is an SU-type carburetor, with a vacuum slide raising and lowering a jet needle.
CV34 discussion
IMG_0292.jpgPost click for topic 21796.jpgAlbum 21796 21797.jpgAlbum 21797
CV36
7952_4da1459955031.jpgPost 363180 7952_4da145a225b6f.jpgPost 363180 7952_4da145aaafc2d.jpgPost 363180
Harley 41 (1988-up)
14887_4f6866bd4c37f.jpgPost 401574
34
16149_4f6715ee0ab50.jpgPost 401465 16149_4f671620d2d4d.jpgPost 401465
CVK40
15516.jpgAlbum 15516
Honda 28
Keihin FCR
Keihin Flat CR (FCR)
961.jpgAlbum 961 18834.jpgAlbum 18834
2197.jpgAlbum 2197 2198.jpgAlbum 2198
rallytwit made 73.22 RWHP on his A-series.
39mm FCR carbs with a near standard GX motor; ported head, headers 2 inch exhaust and 14lb flywheel. As far as reliable FCR carbs are stone axe reliable. For street (or racing) use you would have to do some tuning but it's not a big deal. I only needed an hour of dyno time to get the car 95% dialed. My only problems were because the carbs were on 175HP A-series powered sports racer so the jets were way off what my motor needed............lots of guys use these on street bikes and they are standard equipment on MX bikes. 32MM would likely be better for a street car, the 39's on my car border on over-carbed.
As fars as how the motor runs they are the bomb the motor sings......revs like mad and instant throttle response.
Flatslide FCR Sidedraft
Flatslide FCR Downdraft
CR-MX off road ruggedized
Roundslide CR
FCR41 kit for oval-port A-series
fcr41-3.jpg 15730.jpgAlbum 15730
12371_4afe74dbe49e4.jpgPost 290634 12371_4afe74ef2f1fe.jpgPost 290634 12371_4afe7712605ba.jpgPost 290634
Cast Adapter Kit
18714.jpgAlbum 18714 18715.jpgAlbum 18715 18716.jpgAlbum 18716
Fumiya Kit
Datsun 1200 enthusiasts Fumiya sells these
19962.jpgAlbum 19962 19963.jpgAlbum 19963 19964.jpgAlbum 19964 19965.jpgAlbum 19965 20005.jpgAlbum 20005 20006.jpgAlbum 20006 20008.jpgAlbum 20008 19966.jpgAlbum 19966
Matsuoka MSR
http://www.matsuoka-m.com/web/carburetor
Matsuoka MSR carbs
1047.jpgAlbum 1047
MOTOR SPORTS PRO SHOP まつおか
3073.jpgAlbum 3073
Matsuoka MSR are like FCR but about $1000 US cheaper. They use the same sliding throttle valve design. They're made by Mikuni. Manifold can be any DCOE (Weber/Dellorto/Solex) type.
2582.jpgAlbum 2582 2583.jpgAlbum 2583
new, jetted to your spec: 96K yen (1230 AUD) or with manifold and linkage closer to 200K yen.
Feral said:
When I say just about as good as injection I mean the low speed response from the Mikuni flat slides is incredible. It will still not be as accurate as any well laid out injection system, but really do work very well
MSR Flat Valve 42 mm 238,000
MSR Flat Valve 45 mm 258,000
MSR Flat Valve 48 mm 298,000
Mikuni
Mikuni also made constant velocity (CV) carburetors. The venturi size is what sets the HP characteristics. CVs use the same bore size as venturi size except for a fixed obstruction to generate vacuum.
Mikuni BS series. For example 1980- Suzuki GS1000 came with BS34 carbs (34mm) for 90 HP. A 1981 Kawasaki KZ1000 fitted with BS34s made 102 HP.
Mikuni BS series
variable venturi
constant velocity design
Side draft
Mikuni BD series
Downdraft
These being CV carburetors are similar to SU carburetors. They have a traditional butterfly throttle but the actual airflow is controlled by the round slide (piston) that floats up by vacuum action. It is opposed by the dome spring.
Flat Side
* Mikuni RS
* Mikuni HSR
* Mikuni TM
Flat Slide
25219.jpgAlbum 25219
15059.jpgAlbum 15059 25741.jpgAlbum 25741
16312.jpgAlbum 16312 16311.jpgAlbum 16311
VM
Mikuni VM - late model round-slide series http://www.mikuni.com/pdf/vmmanual.pdf
VM28 may be ideal for a stock A12 (see Carburetor Sizing) - and are only $100 each.
VM28SC
26425.jpgAlbum 26425
BDST
BDST
D=Downdraft
CV constant velocity
BDST36 is the famous Honda CBR600F3 carburetor 85-100 hp (F1 used 32 mm carburetors)
11358.jpgAlbum 11358
BDSR
BDSR
D=Downdraft
R=Radial slide
BDSR40 is the famous Yamaha R1 carburetor 150hp
BS32
Mikuni BS32 was chosen by Nissan to power the A-series engine in the 1970 Sunny Cab (model C20).
25688.jpgAlbum 25688
16010-G0301 BS32-5A [from '69-7]
16010-G0302 BS32-5B (from '70-1)
25687.jpgAlbum 25687
16189-G0320 JET-slow No. 45
16036-25522 JET-slow air bleed No. 210
16296-G0320 JET-air, 0.8 diameter
16033-G0340 JET-main R170
16295-G0320 JET-enrichment, No. 50
16346-G0320 SPRING-diaphragm
16353-G0320 SET-needle
16354-G0320 NEEDLE-jet
1970 A10 engine from Cherry Cab
174_6786ddfa33727.jpgPost 498712 174_6786dde0cf9fb.jpgPost 498712
16546-G0300 Air Cleaner ELEMENT
BS34
 90 hp 1980- Suzuki GS1000
102 hp 1981 Kawasaki KZ1000
SX650 1989-1984
* 132.5 main jet
* 2.5 pilot jet
* Y-O needle jet
* 5HX12 needle
BS34s are rather forgiving and will at least run most engine set ups with stock jetting. W
The pilot air jet is removable, and the main air jet is fixed.
3 main circuits of the carb
* slow speed or idle (mix screw and pilot jet)
* midrange (slide, slide needle, and needle jet)
* high speed or main (main jet)
These all overlap the circuit next to them and changes made to one will slightly effect the other
Float height on the brass floats is 27.3mm. For later units with plastic floats, 22 mm. +/-1mm. BS34 are are fitted with drain valves opened by a screw, with a hose nipple on the outlet. To read fuel level, attach the sight tube to the outlet and set vacuum petcocks, if fitted, on "Prime," and open the screw until fuel flows into the sight tube. With the motorcycle level, hold the sight tube upright beside the carburetor body. Fuel should rise in the tube no higher than the lower lip of the carb body where it overlaps the float bowl, and no lower than 2 mm. below it.
The pilot circuit fuels the engine in low-speed operation, when the slide is lowered.
real Mikuni jets are availible . Get them from the stock size up to two over on the pilots and up to three over on the mains. Follow the guide and test them to see what your engine needs. http://www.amckayltd.com/carbguide.pdf
Tuning kit
* Pilot jets
* Needles
* Main jets
BS34 Jet Needle
5IX11 richer
5HX12 leaner
Needle Jet
Needle Jet
Y-O
336-Y0
Yahama 1200
5220.jpgAlbum 5220 5221.jpgAlbum 5221
fcr,msr,keihin,cycle carb,bike carb
961.jpgAlbum 961 1001.jpgAlbum 1001 1047.jpgAlbum 1047 1348.jpgAlbum 1348 2584.jpgAlbum 2584 2812.jpgAlbum 2812 3073.jpgAlbum 3073 4830.jpgAlbum 4830 5220.jpgAlbum 5220 5221.jpgAlbum 5221 5222.jpgAlbum 5222 6310.jpgAlbum 6310 6746.jpgAlbum 6746 6747.jpgAlbum 6747 6751.jpgAlbum 6751 10205.jpgAlbum 10205 11716.jpgAlbum 11716 12478.jpgAlbum 12478 15244.jpgAlbum 15244 15245.jpgAlbum 15245 15516.jpgAlbum 15516 15326.jpgAlbum 15326 15532.jpgAlbum 15532 15533.jpgAlbum 15533 17096.jpgAlbum 17096 17097.jpgAlbum 17097 17139.jpgAlbum 17139 18503.jpgAlbum 18503 18833.jpgAlbum 18833 18834.jpgAlbum 18834 18836.jpgAlbum 18836 18837.jpgAlbum 18837 18968.jpgAlbum 18968 18973.jpgAlbum 18973 18974.jpgAlbum 18974 18975.jpgAlbum 18975 19317.gifAlbum 19317
19513.jpgAlbum 19513 19974.jpgAlbum 19974 21016.jpgAlbum 21016 21136.jpgAlbum 21136 21924.jpgAlbum 21924 21955.jpgAlbum 21955 22387.jpgAlbum 22387
Photo Uploads
7952_4c12f17ce6e30.jpgUpload click to view 12371_4afe7762ca6a9.jpgUpload click to view 12371_4bea70231471b.jpgUpload click to view 833_4c0875eb2fe7e.jpgUpload click to view 12229_4b931e9927483.jpgUpload click to view 12229_4b931ea61845d.jpgUpload click to view 12229_4b931eb04920b.jpgUpload click to view 12229_4b931ebef09a2.jpgUpload click to view 737_4a70fcfebc056.jpgUpload click to view 833_4c0876999ad3a.jpgUpload click to view 737_4a2e3916cd7f9.jpgUpload click to view
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Bike_Carbs"
This page has been accessed 69,699 times. This page was last modified 22:09, 14 January 2025. Content is available under Datsun 1200 Club.
