Mazda rotary engine swap
Revision as of 09:14, 25 December 2016; view current revision
Categories: Engine Modifications | Engine Swaps
The Mazda rotary engine is a good match for Datsun 1200 -- it is light and compact. It makes more power than a piston engine of the same size and weight. The engine weight is down low so it doesn't interfere with good handling.
Performance
Also See: wikipedia:Mazda Wankel engine
Typical engine power in stock form:
  • 12A: 100-130 HP, 100-115 lb. ft. torque
  • 13B EFI: 135 hp, 133 lb. ft. torque
  • 13B-Turbo (1987-1991 "Turbo II"): 185-200 HP
  • 13B-REW (twin turbo) 255-280 hp
  • 13B-MSP (RX-8) 237 hp USA, 191-250 hp world
13279.jpgAlbum 13279
Quarter Mile acceleration performance ranges from quick to insanely quick. With a totally stock rotary engine you won't be wanting for power.
  • 19.8 secs at 65 mph: Stock Datsun 1200 piston engine (baseline)
  • 16.1 at 90mph: bone stock 12A rotary engine tuned by ear
  • Ange's 13.7 second 12A bridgeport
  • JVML's 8.1 second 13B twin turbo
Rotor Power
6353.jpgAlbum 6353
Discussions
Engine
The Mazda rotary comes in two common sizes: 12A and 13B. In Australia, choose a 10A for street legal swaps. Everyone else, choose the 13B. There are less common versions, the old 10A and the ultra-rare and expensive 20B triple rotor.
12A (1146 cc, equivalent to 2.4 liter piston engine)
19408.jpgAlbum 19408
Mazda 13B (1308 cc, equivalent to 2.6 liter piston engine) carbureted
158.jpgAlbum 158 8555.jpgAlbum 8555
13B Fuel Injected
15021.jpgAlbum 15021
Mazda 13B Turbo rotary engine
93.jpgAlbum 93
Mazda 13B Turbo Factory EFI
2050.jpgAlbum 2050
13B Turbo with factory intercooler
3008.jpgAlbum 3008
20B triple rotor
14572.jpgAlbum 14572 174_5858bfca31446.jpgPost 482854
Engine Mounts
Cut out about 10mm out of the standard 1200 crossmember and brace it. This allows the engine to sit low enough.
Cutcut_zps954618cf.jpgPost click for topic
Front Mount
Most use the front-mount case.
Mount circled in green. Original engine mounts are removed (circled in red)
5448.jpgAlbum 5448
Topic - Weld or bolt new custom-made brackets to the front of the chassis rails
If your rotary doesn't have a front-mount case, you can retro-fit it using a 12A timing cover (which fits on 13B).
15144.jpgAlbum 15144 1787.jpgAlbum 1787
2616.jpgAlbum 2616 2700.jpgAlbum 2700 2701.jpgAlbum 2701 2702.jpgAlbum 2702 2703.jpgAlbum 2703 20618.jpgAlbum 20618
Side Mount
Mad Dat 13BT Fitting Kit allows the newer-type rotary engine side mount, their crossmember curves down so the top of the cross member is lower.
Datrotor fabricated these for a 13B:
d06cfa0b.jpgPost click for topic
Motor Plate
For racing a hard-mounted motor plate can be used. Not recommended for a street car as it transmit vibration directly to the body.
2915.jpgAlbum 2915
Oil Pan
Use the Moroso oil pan for Datsun 1200.
24941.jpgAlbum 24941
Transmission
Use the transmission that comes with the rotary engine (the Mazda transmission).
19869.jpgAlbum 19869 8040.jpgAlbum 8040
Driveshaft
A custom driveshaft to mate the Mazda transmission with your differential will have to be fabricated. Any driveshaft shop can make this for you.
Shifter
A new shifter mount hole may need to cut? Look into doing the shifter extension mod otherwise your shifter will be a little bit to far back for comfort (it will sit in between the front seats right in front of the handbrake).
15141.jpgAlbum 15141
Transmission Mount
Mount the gearbox the with a similar bracket to ca18 one.
9423.jpgAlbum 9423
or make a new gearbox crossmember:
IMG_20130115_192832.jpgPost click for topic
Tunnel
Some fabricate a large tunnel. Is it necessary, or just used with beefy racing transmissions?
In any cause, you'll have to make the tunnel higher through the middle and make space for the clutch fork, or cut a hole for the clutch fork.
11107.jpgAlbum 11107 1788.jpgAlbum 1788
Alternatively you can fit an aftermarket hydraulic throwout bearing to replace the clutch fork.
Differential
The least 12A engine outputs 100 lb. ft. of torque. The stock Datsun 1200 H145 diff can handle that.
But many 12A put out 115 lb. ft. of torque, which calls for a stronger diff. The H150 from a B210 or B310 can handle this.
Stock 13B engine calls for an H165.
Any modified rotary (especially if the turbo boost is raised) will need a stronger differential, such as a Nissan H190. Drag racing versions need the ultra-strong Ford 9".
See: Rear Axle Swaps
Exhaust
For the 13BT, run headers to the rear firewall across to the passenger side.
Rotary-Powered Datsun 1200 photo index
Here are some pictures from our club photo album. Click a pic for larger photos, details, and discussion:
rota 1200
project 1200
1200 rotary prototype.
rotor ute
my 2nd datsun
my !st 1200
supercharged 13b 1000
oh yes ....
DATSUN 1200 FROM GUATEMALA CITY CENTRAL AMERICA
black drag 1
black drag 2
13b 2dr blue drag 1a
13b 2dr blue drag 1b
13b 2dr blue drag 1c
13b 2dr blue drag 1d
13b 2dr blue drag 1e
1972 1200 datsun w/Rotary
13b1000ute bay
100013b interior tunnel
project 2 13bturbo 1000
rotary coupe w/15" SAAB rims
rotary 1200 ute
rotary 1200 ute
my 1000 ute
1000 dragsedan
13b mounts
pic for d
some of the puertorican best
series 5 13b turbo rotary
very nice indeed!
8 second 1200 13b turbo
coupe
avenge
nother 13b 1200
1200 drag race coupe
drag coupe
rotary powered 1200
supernats
early prototype rotary
1200 ute (perfection)
rotary mounts in 323 spud
powercruise coupe
yellow rotary coupe
what noisy exhaust
93.jpg 158.jpg 383.jpg 581.jpg 912.jpg 959.jpg 965.jpg 1078.jpg 1384.jpg 1539.jpg 1540.jpg 1547.jpg 1549.jpg 1756.jpg 1757.jpg 1787.jpg 1788.jpg 1820.jpg 2049.jpg 2050.jpg 2065.jpg 2066.jpg 2067.jpg 2237.jpg 2558.jpg 2616.jpg 2681.jpg 2700.jpg 2701.jpg 2702.jpg 2703.jpg 2848.jpg 2914.jpg 2915.jpg 3008.jpg 3078.jpg 3427.jpg 3483.jpg 3548.jpg 3549.jpg 4484.jpg 4486.jpg 4655.jpg 4694.jpg 4949.jpg 5006.jpg 5448.jpg 5979.jpg 5980.jpg 6353.jpg 6757.jpg 7226.jpg 7374.jpg 7690.jpg 7697.jpg 7698.jpg 7699.jpg 7700.jpg 7703.jpg 7704.jpg 8040.jpg 8051.jpg 8320.jpg 8467.jpg 8469.jpg 8472.jpg 8555.jpg 8557.jpg 9422.jpg 9423.jpg 9501.jpg 9550.jpg 10801.jpg 11107.jpg 11246.jpg 11284.jpg 11285.jpg 12605.jpg 13279.jpg 13280.jpg 13837.jpg 13961.jpg 14572.jpg 14573.jpg 14574.jpg 15021.jpg 15028.jpg 15129.jpg 15141.jpg 15144.jpg 15356.jpg 15642.jpg 15696.jpg 16118.jpg 16120.jpg 16180.jpg 16373.jpg 17281.jpg 17292.jpg 17294.jpg 18150.jpg 18226.jpg 18344.jpg 18345.jpg 18692.jpg 18695.jpg 18818.jpg 18819.jpg 19867.jpg
13btestfit_zps9fc1baa3.jpgPost click for topic
