Speedometer
Revision as of 06:33, 8 July 2008; view current revision
Speedometers were either in kilometers (JDM) or miles (USA). Australia started with mph and then switched to kph. Some speedometers had a trip meter.
1972 USA Owners manual (see page 8,9 for Speedometer):
Instrument and Controls
Variations
  •  ?? 100MPH w/o tripmeter (US standard equipment)
  •  ?? 100MPH with tripmeter
  • 24850-H3400 1200 120MPH SPEEDOMETER Includes tripmeter
Metric-Imperial Conversion
Sometimes on eBay Australia you can get the vintage conversion stickers.
OR
Take the face plate and scan it on the flatbad scanner, then modify it. Finally, print a new one out with the photo printer. You can modify the font, colors, etc. Bolt it to the speedo using the standard screws.
Speedometer Calibration
There are two basic reasons for speedos reading fast or slow:
  1. Factory speedometer tolerance is usually 5% fast to 10% slow (this is in general, I don't know what Nissan's specs are)
    1200 Top Speed discusses this. One magazine test noted the 1200 speedometer in the test car was 7% slow. My 1200s have been between 7.5% - 10% slow (with stock running gear include tire size). Also see speedo off
  2. Different size tires than original, changed diff ratio or transmission
For the latter, there is a mechanical solution of changing to the appropriate speedo-drive gear at the back of the transmission:
For the former, where you have the "right" size tires, final gear ratio and stock transmission -- the speedometer itself may be calibrated.
Where can you go to get a speedo calibrated? Can it be done at home?
  • Scale Adjusted for low gearing, looks good printed on photo paper and bolted to speedometer.
  • I modified mine to change the scale since I didn't want to get under the car and change the plastic speedo gears.
Amplifier Speed Switch
USA model from 0772 use an amplifier speed switch.
  • 25035-H7000 ASSY-AMPLIFIER SPEED SWITCH
Australia models also used it, dates unknown.
Custom Faces
See Custom Dash Faces
Speedometer Cable
The cable for manual transmission and Automatic are different
Nissan Part Numbers
B10
  • 25058-89914 ASS'Y-SHAFT, flexible speedometer B10 M/T
  • 25058-89915 ASS'Y-SHAFT, flexible speedometer B10 Automatic
B110 - both interchange
  • 25058-H1000 ASS'Y-SHAFT, flexible speedometer Length=1500 NLA
  • 25058-H1001 ASS'Y-SHAFT, flexible speedometer Length=1400 NLA
  • 25050-H5000 ASS'Y-SHAFT, flexible speedometer Length=1700
    • B5050-Y8101 supercedes 25050-H5000 $51.22
  • 25050-H5900 ASS'Y-SHAFT, flexible speedometer Length=1650 w/Master Vac NLA
  • 25050-H7403 ASS'Y-SHAFT, flexible speedometer w/63-series trans
  • 25050-H7410 ASS'Y-SHAFT, flexible speedometer A14 automatic
  • 25050-H7411 ASS'Y-SHAFT, flexible speedometer A12
Drive Ratios
Stock 1200 Speedometer gear ratio:
  • 17/5 (17 tooth pinion, 5 tooth worm drive on trans output shaft)
  • 18/5 for Wagon
Available ratios
56-Series Transmission and 60-Series Transmission
  • 32703-15400 PINION SPEEDOMETER 17T
  • 32702-15400 ASSY-PINION SPEEDOMETER 17T
  • 32703-H1000 PINION SPEEDOMETER 18T
  • 32702-H1000 ASSY-PINION SPEEDOMETER 18T (B120, 1975-1979)
  • 32702-H1001 ASSY-PINION SPEEDOMETER 19T (B120, 1980 up)
Automatic Transmission
  • 32703-P2621 PINION SPEEDOMETER 20T (auto)
  • 32703-P2620 PINION SPEEDOMETER 20T (auto)
  • 32702-P2719 ASSY-PINION SPEEDOMETER 19T (auto)
63-Series Transmission
  • 32703-N9016 PINION SPEEDOMETER 16T
  • 32703-N9018 PINION SPEEDOMETER 18T
  • 32703-N9019 PINION SPEEDOMETER 19T
226.jpg 1085.jpg 2192.jpg 2729.jpg 4352.jpg 5043.jpg 8881.jpg 9301.jpg 10675.jpg 10754.jpg 10934.jpg 10935.jpg 11799.jpg 12944.jpg 13092.jpg
