Instruments and Controls
Revision as of 03:09, 25 December 2015; view current revision
Category: Body
Instruments and Controls is a section in the Datsun 1200 Owners manual.
1972 USA Owner's Manual (starting page 8):
1974 Export Pickup Owner's Manual (starting page 6):
* Seat Belt Warning System
* Speedometer
* Tachometer (OPTIONAL)
1972 USA Owner's Manual (page 9):
Water Temperature Gauge
th_10.jpg 1972 USA Owner's Manual
If the pointer stays on the "H" side for more than two minutes, stop the vehicle and let the engine cool down, keeping it at 1,000 to 1,500 rpm.
By "H" they mean out of the large middle range (way over to right-side -- the H area).
Also see: Thermostat or Temperature Gauge
Fuel Gauge
The fuel gauge is part of the Cluster Gauge
The position of the pointer will vary slightly during acceleration, braking and when the car is going up or down a hill.
From the 1973 Datsun 1200 Factory Service Manual.
Ohms Mark
35   Half
Stock Fuel level gauge, ss measured by club members:
  • Empty mark: 73-88 ohms input
  • Full mark: 12 ohms
ang94541 uses an aftermarket Autometer 3515, which does doesn't match the Nissan sender except at the empty mark. It is designed for the unusual Ford senders.
  • 3515 Empty mark: 73 ohms
  • 3515 Full mark: 10 ohms
Reference: Forum: Fuel sending unit specs
Also see: Fuel tank (includes Fuel Sender specs)
Indicator/Warning Lights
Also see: Wiring
Ignition Warning Light
Oil Pressure Warning Light
Headlight Beam Indicator Light
Brake System Warning Light
Turn Signal Indicator Lights
Switches
Also see: Wiring
Ignition Switch
Also see:
* Keys
* Locks
* Ignition Switch
1972 USA Owner's Manual (page 11):
ignition switch ... is integrated with the steering lock device
1974 Export Pickup Owner's Manual (pages 9,10):
(Optional)
The key can be inserted or withdrawn only when the switch is in the "GARAGE" or "LOCK" position. In the "GARAGE" position, however, the steering is not locked.
(3-position)
The "ON" position allows you to turn on the ignition system as well as all the other electrical circuits.
No mention is made of what the OFF position is for. Presumably its use is the same as the "GARAGE" position.
Notice that the standard 3-position type does not have an "ACC" position.
5-position switch vs 4-position switch:
Note addition of ACC position, which power Radio & Rear Defroster
Portugal market:
Interruptor de ignićāo [Ignition switch]
Desligado [OFF]
Ligado    [ON]
Arranque  [START]
Light Switches
Also see: Lighting Switch
Light Switch
When you pull the switch knob to the first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
At the second position, the parking lights are still on and the headlight beams are lit, then if you push the turn signal lever switch forward, the headlight high beams will be turned on ... Pull the lever toward you, and it will be changed over to low beam.
The key takeaway here is that:
  • Knob in the 1st Position, NO HEADLIGHTS for US models
  • Knob in the 1st Position, LOW BEAMS work for other countries, including Japan-market
B120 1974 Export owner's manual
LIGHT SWITCH
The light switch clearance lights, parking lights, headlights, taillights, license plate light and instrument panel lights.
With the light switch knob pulled on, the following lights will be on.
1st position:
Clearance, parking, tail, license, instrument panel lights and then headlight low beams.
With the turn signal switch lever pulled up, the headlight low beams can be turned on.
2nd position:
Headlights and other lights
If you push the turn signal switch lever forward, the headlight high beams will be turned on.
INSTRUMENT PANEL LIGHT CONTROL (For Australia only)
The instrument panel light control is integral with light switch. The brightness of instrument panel lights can be adjusted by turn the light switch knob.
Turning the knob clockwise will darken the instrument panel lights.
Turn Signal Switch and High Beam Switch Lever
Hazard Warning Switch
th_12.jpg 1972 USA Owner's Manual
...first of two positions, parking lights, taillights, license plate lights and instrument panel lights are turned on.
Light switch operation differs between Australia models and other markets. Turn Signal operation (T/S) is the same?
Wiper and Washer Switch
To operate the washer, turn clockwise and hold the knob for a moment, or until there is enough fluid on the glass to wash off the dirt. Do not operate the washer for more than thirty seconds continuously.
Horn
Just press the button to sound the Horn.
th_13.jpg 1972 USA Owner's Manual
Parking Brake Lever
If the ignition switch is on when the parking brake lever is applied, the brake warning light will glow.
Heat Glass Switch
Optional equipment.
