Speedometer
Revision as of 09:21, 24 December 2011; view current revision
Speedometers were either in kilometers (JDM) or miles (USA). Australia started with mph and then switched to kph. Some speedometers had a trip meter.
1972 USA Owners manual (see page 8,9 for Speedometer):
Instrument and Controls
Variations
  •  ?? 100MPH w/o tripmeter (US standard equipment)
  •  ?? 100MPH with tripmeter
  • 24850-H3400 1200 120MPH SPEEDOMETER Includes tripmeter
  • Facelift GX - 180 kph
  • 24850-H1816 ASSY-SPEEDOMETER 100MILE/H
  • 24850-H7000 ASSY-SPEEDOMETER 100MILE/H From 7/72 [With 10 mph markings]
JDM Sunny Truck
  • 24850-B8600 SPEEDOMETER ASSY -7803 [Rectangle]
  • 24850-G1670 SPEEDOMETER ASSY 7804- [Round]
Metric-Imperial Conversion
Sometimes on eBay Australia you can get the vintage conversion stickers.
OR
Take the face plate and scan it on the flatbad scanner, then modify it. Finally, print a new one out with the photo printer. You can modify the font, colors, etc. Bolt it to the speedo using the standard screws.
Speedometer Calibration
There are two basic reasons for speedos reading fast or slow:
  1. Factory speedometer tolerance is usually 5% fast to 10% slow (this is in general, I don't know what Nissan's specs are)
    1200 Top Speed discusses this. One magazine test noted the 1200 speedometer in the test car was 7% slow. My 1200s have been between 7.5% - 10% slow (with stock running gear include tire size). Also see speedo off
  2. Different size tires than original, changed diff ratio or transmission
For the latter, there is a mechanical solution of changing to the appropriate speedo-drive gear at the back of the transmission:
For the former, where you have the "right" size tires, final gear ratio and stock transmission -- the speedometer itself may be calibrated.
Odometer Calibration
Before messing with the mechanism, make sure the odometer (distance counter) is correct. If it is not, different transmission-to-speedometer cable pinion gears are called for.
Get on the highway and drive. As you pass the mile markers note the indicated milage. A 10 mile drive is good for accuracy. If the odometer reads 10.0 miles it is perfect. But if it read 11.0 mile it is running 10% off.
  1. Change the pinion gear to correct.
  2. Or, change tire size (diameter) to correct.
  3. Or, use a speedometer adapter ratio adapter at about $150
Once you get the odometer reading correctly, then move to confirm the speed needle readings.
Mechanism Calibration
Where can you go to get a speedo calibrated? Can it be done at home?
Assuming your odometer reading is now verified correct, proceed to calibrating the needle reading.
You can:
  1. Change the pointer position. This is good if the speedometer is off by say 2mph at all speeds.
or
  1. Change the magnetic tension. This will adjust the scale across the board. Be careful as it is easy to ruin it
    For ideas, see: Recalibration of Speedometer
Bench Test
You can turn the speedometer cable with an electric drill. As long as you have a way to adjust it to run at a steady speed, you can test it versus the odometer.
Parts needed:
  1. reversible electric drill to drive the speedo cable
  2. 500W dimmer switch to vary constant drill speed
  3. 60W light bulb (dimmer requires this)
  4. Extension box
  5. Outlet plug
  6. Electric wiring
NOTE: Danger. Use caution and properly grounded and boxed connections. Do not attempt at home. Use professional equipment.
A typical reversible electric drill may run at 2500 RPM. The speedometer is 50mph=1024 rpm, so turn the Dimmer down about 1/3 from full to start.
Pull trigger fully to run drill at constant speed. Then vary the dimmer switch to show 60mph.
With a stop watch, time exactly 60 seconds. If the odometer moves exactly 1.0 miles it is good. If you are not sure, run for three minutes. If it shows 3.0 miles it is perfect. Otherwise record the reading.
Repeat for 30 mph and 90 mph.
Calculate the MPH difference at each speed.
Road Test
  1. Compare against roadside radar box
  2. Timing test. Go out on highway and drive at steady mph while you time the mileposts.
    1. 10 miles 60 mph should take exactly 10 minutes
    2. 5 miles 30 mph should take exactly 10 minutes
Compare both a high and low speed.
Adjustment
  1. If all reading are off by a fixed MPH, carefully move the needle to correct it.
  2. If the readings get worse the faster it goes, the mechanism needs calibration.
    NOTE: haven't tried this yet. Don't know how well it works
    1. Adjust pointer so 30 mph reading is correct
    2. If 90 mph reading is now incorrect, adjust cup drive
Changing Scale
You can easily change the scale to make it read correctly, or to make a 180 kph scale. The downside is that the odometer (distance counter) will be inaccurate.
  • Scale Adjusted for low gearing, looks good printed on photo paper and bolted to speedometer.
  • Use a light, removable contact cement. Otherwise if you just tack the edges or a places, the photo will eventually buckle and warp and interfere with the needle movement.
  • I modified mine to change the scale since I didn't want to get under the car and change the plastic speedo gears.
Amplifier Speed Switch
USA model from 0772 use an amplifier speed switch.
  • 25035-H7000 ASSY-AMPLIFIER SPEED SWITCH
Australia models also used it, dates unknown.
Custom Faces
See Custom Dash Faces
280Z speedometer fits:
  1. Swap the mounting cups as the 280Z unit is deeper
  2. Drill a hole for the trip meter shaft through the back
  3. The face is to large for the opening in the 1200 housing, so carefully reduce the diameter by 1/8 inch
Speedometer Cable
The cable for manual transmission and Automatic are different
Rockauto.com $7.76
Nissan Part Numbers
B10
  • 25058-89914 ASS'Y-SHAFT, flexible speedometer B10 M/T
  • 25058-89915 ASS'Y-SHAFT, flexible speedometer B10 Automatic
B110 - both interchange
  • 25058-H1000 ASS'Y-SHAFT, flexible speedometer Length=1500 NLA
  • 25058-H1001 ASS'Y-SHAFT, flexible speedometer Length=1400 NLA
  • 25050-H5000 ASS'Y-SHAFT, flexible speedometer Length=1700
    • B5050-Y8101 supercedes 25050-H5000 $51.22
  • 25050-H5900 ASS'Y-SHAFT, flexible speedometer Length=1650 w/Master Vac NLA
  • 25050-H7403 ASS'Y-SHAFT, flexible speedometer w/63-series trans
  • 25050-H7410 ASS'Y-SHAFT, flexible speedometer A14 automatic
  • 25050-H7411 ASS'Y-SHAFT, flexible speedometer A12
Cable Breaks
The speedometer cable usually lasts forever. There are two common reasons why it will break:
  1. Mechanical kink or breakage, for example if you drive over a tree branch and it pulls the cable
  2. Bad or missing engine ground wire.
I think you'll find this is caused by poor/dirty ground strap from the engine to the body inside the engine bay.
It only takes once, and the cable it screwed, as it melts the nice polyethylene coating on the inside.
See how the cable's protective plastic appear worn..I'd say it melted during starter crank. Then when the cable gets some speed up, the plastic grabs and the cable snaps.
Drive Ratios
Stock 1200 Speedometer gear ratio:
  • pinion teeth/worm teeth on trans output shaft
  • 17/5 (3.90 diff)
  • 18/5 for Wagon (4.11 diff)
To adjust the speedometer for different diameter tires, change the transmission cable pinion cog.
* If speedo reads too fast, fit a bigger cog
* If speedo reads too slow, fit a smaller cog
Given that stock is a 17 tooth pinion, moving to one more or less tooth is about 6% change. So by changing the pinion you can only get it to ±3 mph accurate. For example, at 100 mph, within 3 mph. Or at the standard 50 mph rating, a reading between 1½ mph (48½ to 51½) is the best you can hope for. For finer tuning the speedometer itself needs calibration. Or you could fit different diameter rear tires.
EXAMPLE: If you are reading say 60 when you are really going 50 then the speedo cable needs to slow down by about 20% to read more accurately. If the speedo drive has a 17 tooth cog in it try to find a cog that reduces by 20%. 17 X .20 = 3.4 teeth... 17 + 3.4 = 20.4 teeth, the closest is a 20 tooth cog.
Teeth% change50 mph reading
16106.25%53.1
17100.00%50.0
1894.44%47.2
1989.47%44.7
Correction Table, increase Teeth by:
Actual mph Desired mph Tooth
40 50 3+
43 50 2+
47 50 1+
50 50 0+
Estimated Tire Correction Table (for 3.9 diff)
Size Diameter Difference Pinion ~Error
165/55R12 19.1 88% 19T 0%
165/60R12 19.8 91% 18T -2%
165/70R12 21.1 97% 17T 3%
155/80R12 21.8 100% 17T 0%
175/70R13 22.6 104% 16T 2%
195/50R15 22.7 104% 16T 2%
165/70R14 23.1 106% 16T 0%
205/45R17 23.5 108% 16T -2%
185/60R15 23.7 109% 16T/15T 3%
205/40R18 24.5 112% 15T 0%
  • NOTE: while they are color-coded, order by part number, not by color. For example, 63-series and 56-series cogs (pinion gears) use different color coding.
  • They are easy to replace by removing the roll pin...use your original Cog Body (Sleeve).
56 & 60 Series
56-Series Transmission and 60-Series Transmission
  • PINION (32703)
  • 32703-18001 PINION ASSY-SPEEDOMETER (15T)
  • 32703-18000 PINION ASSY-SPEEDOMETER (16T) $10.55 USD
  • 32703-15400 PINION SPEEDOMETER 17T [White] $17.02 USD
  • 32703-H1000 PINION SPEEDOMETER 18T [Blue] $15.67 USD
  • SLEEVE W/PINION ASS'Y (3702)
  • 32702-15400 ASSY-PINION SPEEDOMETER 17T $17.02 USD
  • 32702-H1000 ASSY-PINION SPEEDOMETER 18T (B120, 1975-1979)
  • 32702-H1001 ASSY-PINION SPEEDOMETER 19T (B120, 1980 up)
Automatic Transmission
  • 32703-P2616 PINION SPEEDOMETER 16T (auto) $23.22 USD
  • 32703-P2617 PINION SPEEDOMETER 17T (auto) $12.78 USD
  • 32703-P2618 PINION SPEEDOMETER 18T (auto) $23.43 USD
  • 32703-P2619 PINION SPEEDOMETER 19T (auto) $12.78 USD
  • 32703-P2620 PINION SPEEDOMETER 20T (auto) $12.83 USD
  • 32703-P2621 PINION SPEEDOMETER 21T (auto) $21.12 USD
  • 32702-P2719 ASSY-PINION SPEEDOMETER 19T (auto) $30.80 USD
63-Series
  • 32703-N9016 PINION SPEEDOMETER 16T $13.28 USD
  • 32703-N9017 PINION SPEEDOMETER 17T $12.42 USD
  • 32703-N9018 PINION SPEEDOMETER 18T $12.42 USD
  • 32703-N9019 PINION SPEEDOMETER 19T $11.80 USD
Application
56 & 60 Series
  • B110 with 3.90: 17T
  • B110 with 4.11: 18T
  • B210 with A13: 17T
  • B210 with A13: 18T (optional Sedan)
  • B210 with A14: 17T to 0376
  • B210 with A14: 16T from 0476
  • B310 with A12 North America: 17T
  • B310 with A14/A15: 16T
FS5W63A
NOTE: 63 5-speed and 4-speed pinion gears have a different part numbers, so perhaps do not interchange.
  • 32703-N9016 16T
    • JDM A10 F5
    • USA B210 F5
  • 32703-N9017 17T
    • USA S10 1977-1979
    • USA D21 2WD F5
    • USA GC22 1987-1989 Nissan Van [RS5W71C]
  • 32703-N9018 18T
    • USA D21 F4 1988-1989
    • USA D21 2WD F5 1986-1992 SELECT
  • 32703-N9019 19T
Pinion or Assembly
Each drive gear (on the output shaft of the transmission) works with a variety of different pinion gears.
For the A-series gearboxes, there is only one size of drive gear, which works with 16-19 teeth pinions. The sleeves are all the same, so all you need is the gear (not the assembly).
Different transmission have different methods:
Jeep - offset holder is rotated to various positions for each gear
GM TH350 - two drive gears, each works with a range of driven gears
720 - all have 6T drive gear
56-series, 60, driven gear is machined on the shaft
4W63, 71B, 71C replaceable gear
226.jpg1085.jpg2192.jpg2729.jpg4352.jpg5043.jpg8881.jpg9301.jpg10675.jpg10754.jpg10934.jpg10935.jpg11799.jpg12944.jpg13092.jpg
