Datsun 1200s came with front bucket seats except in a few countries where a front bench seat was available. Front seat style include: fixed, tilting (folding) and reclining. The coupe rear seat folds down. Different trim levels got different materials, namely vinyl or vinyl with cloth inserts. Sedan and Coupe seats generally differ in the cut and level of support padding. Some market like Australia produced seats locally. Head restraints were optional in some markets, but standard in USA.
Operation
You can adjust the seat back to any desired position, even horizontal, by simply pulling the lever up.
- Folding: 2-door models
- Reclining: some models
- Coupe rear seat folds down
sedan STD,DX - fixed, straight-cut pattern. recliner OPTION sedan GL, GX - recliner with x-pattern cloth sedan 2-door - folding, straight cloth coupe 2-door - folding, x-pattern cloth truck - fixed, no recliner possible
Coupe Seats - sporty trim, but light with very little padding
Sedan Seats - flatter, with a bit more padding
B110 GX-5 - hi-back seat, black KPB110 GX - hi-back seat OPTION with ovoid recliner control * laterally-padded seats KPB110 GL - laterally-padded seats B210 - low-back seats with small headrest KB210/KPB210 - hi-back seats with round recliner control KPB210 GLL/GXL - low-back seats with small headrest B120 1978-1989 hiback seats, BROWN B120 1989-1994 hiback seats, Black with GREY inserts
Highback Seats
High-back seats have the headrest portion built-in.
#GX-5 Hiback seats have GL-type cloth
#Sunny Truck Late (from 1978 April) has rounded headrest (no seam)
#PB110 OPTION seat has GX-type fabric
GL/GX Style
Cushions are cut in an x-pattern to make slightly bolstered. GL and GX sedans uses this style. All coupes (including Coupe DX) use this style.
Inserts have 5-rib style
GL/GX cloth inserts Coupe DX is all vinyl
GL sedan used coupe-style cushions
Location
Front seat risers
A seat cross member
B inside seat bracket
C outside seat bracket
Also see: Coin Tray
Sunny Truck
Many/most/all? B120 have a fixed (non-sliding) passengers side seat rail, but all 1200 rails interchange so you can replace it with an adjustable seat rail.
1971-1978 Black low-back seats 1978-1989 Brown hi-back seats 1989-1994 Gray hi-back seats
-7803 Early Datsun 1200 utes * sedan seat bottom * Truck unfinished back * fixed (non-reclining) * thin headrest 87700-G1001 Head Restaint Assy OPTION ALL(assist)
7803-8910 - Brown high-back seat (needs no external headrest)
Coupe, Sedan seats fit in ute, no problem, even though they are a little thicker than truck seats
Catalytic Converter Seats
later seats have passenger side lower mount -- to clear the catalyst bulge in the floor.
1976-1978 B-210 pictured here (1989-up Sunny Truck is similar)
Connectors
A connector is used to attach the seatback.
* H10 STD FIXED connector * H12 STD 2-DR FOLDING device [non-reclining] * H11 DX RECLINING [+folding] black cover * H18 GL,GX RECLINING [+folding] chrome cover
FIXED Connector early | mid-model ute
Upholstery
STD/DX Vinyl Leather (black or yellow)
GL fabric insert (black or blue Tricotᵂ)
GX plaid insert (brown or black)
Stock Seats
Standard, Deluxe and Reclining Seats
Aussie-Market
1200 Coupe seats (custom fabric) in Datsun 1000
Ute
Australia-market B120 seats are not suitable for sedans as the back is not finished, but are extra thin compared to sedan seats with a slim-profile headrest. JDM seats are same/similar.
The rear of the seats (all years) have a rubber bumper for the rear panel.
08513-41612 SCREW, pan head tapping M4x16 + 86805-15400 RUBBER PACKING
Bench Seat
120Y bakkie and 1400 bakkie (B140) came with a 3-passenger bench seat
Mazda 1000 Bench seat which has been retrimmed
North America
Canada & USA models * 1973 models had blue or beige seats. Black was available (again) on from 0173 * 1971-1972 models: * Coupe: Black, Beige or (optional) Yellow * Sedan: Black, Yellow, Gray * Reclining seats standard on coupe * Sedan had reclining seats OR folding non-reclining seats with (optional) * Sedan had some sort of optional front seats
Occupant Sensor for Seat Belt Warning System
Parts
- 86982-A0600 Eyelet 'A' Seat Back $1.12
- 86983-A0600 Eyelet 'B' Seat Back $0.85
- 87550-H1603 Slide-seat LH $44.33
- 87500-H1603 Slide-seat RH
- 87400-M3000 Hinge-recline RH $179.58
- 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
- 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FIX TO SLIDE
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors sometimes called coin trays. These fit above the floor just to the outside of each seat.
GX-5
#Highback seats have the headrest portion built-in, and were factory fitted to Datsun 1200 GX-5 sedans and coupes.
GX-5 front bucket seat * high-back style with integrated headrest * same five-rib pattern as all Coupe/GL type seats * basically is GL seat with a different back
Sedan & Coupe are same seat per Catalog C-231, but contrary to this are listed as having different cushions:
* Coupe: H41 coupe GL cushion * Sedan: H33 sedan GL cushion
Facelift
H33 SEAT COMPLETE GL SEDAN H34 SEAT COMPLETE GX SEDAN H41 SEAT COMPLETE GL COUPE H42 SEAT COMPLETE GX COUPE H72 SEAT COMPLETE GX-5 COUPE/SEDAN H42 CUSHION ASS'Y GX COUPE H41 CUSHION ASS'Y GL/GX-5 COUPE H33 CUSHION ASS'Y GL/GX-5 SEDAN H34 CUSHION ASS'Y GX SEDAN
PB110
Sunny Excellent PB110 seats are exactly like regular 1200 seats except for the colors and fabric style are upscale designs. They even use the same seat #Connectors, #Rails and Headrests.
1970-1971 1400 Coupe H25 DX inserts have a center double-stripe H26 GL inserts have four horizontal sections H27 GX inserts have three vertical sections
1970-1971 1400 Sedan H28 DX inserts have three stripes H29 GL is like Coupe GL, includes H26 cushions H30 GX is like Coupe GX, includes H27 cushions
Sedan GX Striped fabric brown & black
Sedan GX — with non-standard fabric?
OPTION high-back seats (like #GX-5 but with GX-type plaid fabric) | OPTION Coupe GX
Datsun 1000 Seats
Headrests
See main article: Headrests
Alternative Seats
Factory non-1200 Bucket Seats Sport Seats Recaro Seats Vintage Racing Seats
Aftermarket seats
Seat Rails
Adapting Seats
NOTE: When bolting in seats, use high-strength bolts (10.8 spec), so that in a minor accident the bolts do not break.
Many, many seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
Chassis Brackets - for flat seat runners
Australia Legalities
Rear Seats
See Main Article: Rear Seat
See Also
* Seat Photo Index
