Dashboard
From Datsun 1200 Club
Category: Body
Various dashes were used for various countries, trims, and years. Standard used rectangular gauges, while GL and GX used round gauges. Deluxe (DX) could use either, for example all USA models use round gauges.
Terminology
In Nissan official terminology, the "dash" is the cowl & firewall. But in common usage, the dash is the instrument panel or gauges therein and sometimes refers to the dash pad.
Gauges
11744.jpgAlbum 11744
Dash Panels &mdash see Firewall ダツシュ パネル
24072.jpgAlbum 24072
Instrument Panel is the entire removable pod assembly (commonly called the Dash) インストルメント パネル
5044.jpgAlbum 5044 5046.jpgAlbum 5046 23456.jpgAlbum 23456
The metal frame is the Instrument Panel Assembly
24118.jpgAlbum 24118
Gauge Cluster — see Cluster Gauge
21616.jpgAlbum 21616
Dash facia is Cluster Lid.  クラスター リツド
24073.jpgAlbum 24073
Dash pad is the Instrument Panel Pad.  インストルメント パツド
23277.jpgAlbum 23277
Dash includes the pad, instrument panel, and dash frame
Glovebox is on the passenger side
26012.jpgAlbum 26012
Defroster vents connect to the dash frame
26013.jpgAlbum 26013
Instrument Panel
  • Rectangular gauge instrument cluster (角/kaku): Standard, Deluxe Sedan
  • Round gauge instrument cluster (丸/maru): Deluxe Coupe, GL, GX
2149.jpgAlbum 2149
STD
804.jpgAlbum 804 11149.jpgAlbum 11149
DX Coupe with 160kph or 100mph speedometer
1350.jpgAlbum 1350 29901.jpgAlbum 29901
GL
5172.jpgAlbum 5172
1970-1971 (flat type)
11440.jpgAlbum 11440
1972 Japan (hooded type)
13214.jpgAlbum 13214
Bottom view showing glovebox and Fuse Box
B110サニーインパネ inpane
Defrost Finishers
defrost finisher (ventilation garnishes/ventilation trim)
Trim Levels
Datsun 1200 trim packages received different factory equipment.
RECTANGLE GAUGE
STD:      Rectangle with OPTION clock
DX Sedan: Rectangle with OPTION clock
NOTE: North America DX sedan came with round gauges
ROUND GAUGE
DX Coupe: Round with OPTION clock
GL:       Round with clock
GX:       Round with Tachometer
          * clock moved to Console
          * 180 kph speedometer
Tachometer and Clock were both OPTION
26413.jpgAlbum 26413
Datsun Sunny Excellent 1400 PB110 trim levels were outfitted the same way except that DX Sedans came with round-gauge dashes.
1972 Facelift
Kilometers vs Miles
Miles only
10290_4a2f72d1a2c39.jpgUpload click to view
Miles only
Kilometers only
9082_4ae0b82060332.jpgUpload click to view
Sunny Truck Dash
13485.jpgAlbum 13485
Early
1971-1978 rectangle dash the same as B110 STD/DX -- but only with black interior.
8400.jpgAlbum 8400
JDM DX utes got a shifter console.
Japan | Australia
16662.jpgAlbum 16662 11149.jpgAlbum 11149
12506.jpgAlbum 12506
Bar meter re-design added color to the speedometer as these circa 1977 photos show
30661.jpgAlbum 30661 31185.jpgAlbum 31185 31186.jpgAlbum 31186
31187.jpgAlbum 31187
Mid
1978-1989 Brown Round
978.jpgAlbum 978
the brown can be re-painted black using vinyl paint
6205.jpgAlbum 6205
With rectangular Choke warning added to dash April 1978 (Japan Market)
174_5d65ee6af3492.jpgPost 492391
Late
1989-1994 dark Gray with Round Gauges
26028.jpgAlbum 26028 26029.jpgAlbum 26029
Note:
With rectangular Choke warning and EXH TEMP warning (Japan Market)
27042.jpgAlbum 27042
27036.jpgAlbum 27036 27037.jpgAlbum 27037
B140 Bakkie
14515.jpgAlbum 14515
  • "NISSAN" clock delete plate
Pad
Nissan calls the Dash pad the Instrument Panel Pad. Reference: Dash Trim Part Numbers
RHD
68910-H1000 ASS'Y-PAD, instrument [round or square]
68910-H2501 PAD-INSTRUMENT PB110 (black) DX,GL,GX
68910-H2600 PAD-INSTRUMENT PB110 (blue) GL
68910-H2700 PAD-INSTRUMENT PB110 (brown) GX
68910-H3100 PAD ASS'Y-instrument 1972 [Facelift]
68910-H2500 PAD-INSTRUMENT B120 -7803 BLACK
68910-G1060 PAD-INSTRUMENT 7804-8910 DARK BROWN
68910-95W00 PAD-INSTRUMENT 8910- GRAY
LHD
68910-H1600 LHD ASSY-PAD INSTRUMENT $306.10 USD
Maddat Code DP1200 - Datsun 1200 Dash Pad. Datsun 1200 RHD genuine Nissan dash pad, Brown only.
174_635ac27f5a508.jpgPost 497241
The pad tends to crack after 10 years in the hot sun.
17571.jpgAlbum 17571
Facia (Cluster Lid)
Dash facia is called by Nissan the Cluster Lid (gauge cluster lid). Reference: Meter Part Numbers
See also: Cluster Gauge
RHD | LHD round (GL, GX, USA.DX and all Coupes)
24073.jpgAlbum 24073 24074.jpgAlbum 24074
Rectangle cluster lid (STD & JDM DX + early Truck)
with red BEAM lamp (AUS)
with red BEAM lamp & empty BRAKE spot (AUS)
8400.jpgAlbum 8400
with blue BEAM lamp
27119.jpgAlbum 27119
with blue BEAM lamp & BRAKE lamp (c. 1977)
30661.jpgAlbum 30661 30660.jpgAlbum 30660
LHD USA LID-CLUSTER
25010-H1701 [no FAN text]
25010-H4600 0172- <> 25010-H1701 [FAN-PULL]
25010-H7000 0772-
23172.jpgAlbum 23172 24071.jpgAlbum 24071
RHD LID ASSY-CLUSTER
rectangle type
  25010-H1000
  25010-H1100
  * with glass & plug (per 1974 catalog)
  * Sedan DX, Van Super-DX 4-speed (per 1971 catalog)
  25010-G1600 -7803
round type
  1970-1971
    25010-H1800 ASS'Y-LID, cluster (metallic)
    25010-H2000 ASS'Y-LID, cluster (wood grain) GL,GX
    25010-H2500 ASS'Y-LID, cluster (gray metallic) 1400 DX
    25010-H2601 ASS'Y-LID, cluster (gold metallic) 1400 GL,GX
  1972 facelift including PB110
    25010-H3100 LID ASS'Y-cluster (gold metallic) STD,DX
    25010-H3300 LID ASS'Y-cluster (gray metallic) GL,GX
  25010-G1670 7804-8910
  68240-95W01 9810-
Close up around heater/radio section
24075.jpgAlbum 24075 27118.jpgAlbum 27118
1972 facelift wood-grain
30529.jpgAlbum 30529
LHD
willieoec-img400x600-1327302265hgagz856298.jpg willieoec-img400x600-1327302265qhfveq56298.jpg
Dash Frame
The dash frame is the metal part of the dashboard, which Nissan calls the Instrument Panel Assembly Reference: Dash Part Numbers
willieoec-img600x450-1327302780hf0m2n72814.jpg 24114.jpgAlbum 24114
Parts that bolt to the frame include the #Pad, the Fuse Box, Defroster vents and Glovebox Lid
LHD
23278.jpgAlbum 23278 24118.jpgAlbum 24118 24119.jpgAlbum 24119
RHD
24115.jpgAlbum 24115 24116.jpgAlbum 24116 24117.jpgAlbum 24117
With #Pad attached
Dash Top
The top of the dash contains:
PB110
* Early: Flat instrument panel
* Late: Podded instrument panel
Early - Same as 1970-1971 1200, but offered in additional colors
See PB110 Brochure
1972 — Same as 1972 Datsun 1200
16011.jpgAlbum 16011
Cluster
Early
Late — same as 1972 B110
23173.jpgAlbum 23173
CLUSTER LID
H25 Gray Metallic DX
H26 Gold Metallic GL/GX
H31 Gray Metallic DX    from '72-1
H33 Gold Metallic GL/GX from '72-1
Sunny Excellent 1400 (PB110) hooded dash
1972 PB110 Facelift double-hump dash
Facelift PB110
Facelift PB110
Facelift PB110 Glove Box door is thick, with a prominent curve
13452.jpgAlbum 13452
Gauges
See:
Speedometer
Tachometer
Fuel Gauge
Temperature Gauge
Auxiliary Gauges
Standard Dash
Round Dash
1981 April
Custom Dash
Wood, stainless, silvia gauges -- customize the 1200 dash. Or fit an entire dashboard from Silvia, Charade, Starlet etc. into your 1200.
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Dashboard"
This page has been accessed 179,569 times. This page was last modified 03:17, 9 November 2025. Content is available under Datsun 1200 Club.
