Toyota 5-speed
From Datsun 1200 Club
Categories: Transmission | Transmission Modifications
Gearbox Swaps
 Types: 56 | 60 | 63 | 71 | 90 | R30
 Transmission Swaps
 5-Speeds | F5C56A | Stumpy
 6-speed
 Toyota 5-speed
 Manual/Auto conversion
 more: Transmission Modifications
Toyota overdrive 5-speeds are light, strong and readily available. Most have ratios are closer the common Datsun 5-Speeds. But you need to adapt it to the A-series engine as it uses a different bellhousing bolt pattern.
See also: T50 5-speed
The Toyota gearboxes, being of the split case design, make it easy to maintain should you be the type to switch gearsets or perform your own overhauls. Toyota and aftermarket suppliers offer a large range of different gear ratios to suit your needs. The T50 has a shorter throw than the 1200s gearboxes.
Sources
T40 (A3)
T50 (4AGE)
K40
K50
W50 (Celica)
W57         steel Sandwich plate
W58 (Supra) steel Sandwich plate
W59 (Hilux) Rock-crawler 1st gear
Ratios
               1     2     3     4     5     R
T40 (A3)     3.587 2.022 1.384 1.000 ----- 3.484
T50 (4AGE)   3.587 2.022 1.384 1.000 0.861 3.484
W50 (Celica) 3.566 2.056 1.384 1.000 0.850 4.091
W58 (Supra)  3.285 1.894 1.275 1.000 0.783 3.768
Dellow Swap Kit
Dellow Engineering (Australia) sells an installation kit to fit a T50 five-speed into Datsun 1200.
Dellow also makes adapters for Rover/Buick V8 to Toyota Supra W57/W58 gearboxes for your more radical Datsun 1200 swaps.
W50 Adapter Plate
Bolt an adapter plate to a Celica W50 gearbox, then bolt A-series automatic bellhousing to it.
T50
Corolla/Celica gearbox with T-engine or A-engine (e.g. T18 or 4A)
K50
K50 5-speed light/medium-duty transmissions found in Corollas, Starlets and LiteAce with K-engine or 3A/4A engines
Main: K Gearbox
W55/W57/W58
Supra gearbox W55/W57/W58 are strong transmissions which will fit in a standard 1200 tunnel with some effort.
Main: W Gearbox
More info
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Toyota_5-speed"
This page has been accessed 25,342 times. This page was last modified 23:56, 28 March 2025. Content is available under Datsun 1200 Club.
