There is no page titled ":Brake". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Suspension And Brake Swaps (108 bytes)
4: * [[Brake Swaps]] - Brake Pads (9387 bytes)
12: 41060-H1006 PAD ASS'Y-front disc brake B110 GL, GX, and all USA
35: 41060-S0100 KIT-PAD DISC BRAKE B210 USA -0475
36: 41060-H7900 KIT-PAD DISC BRAKE B210 USA 0575-0775
37: 41060-S0126 KIT-PAD DISC BRAKE B210 USA -0775
38: 41060-H7926 KIT-PAD DISC BRAKE B210 USA -0775 $52.22 USD - Brake master cylinder (9410 bytes)
4: {{Daily Care Brake and Clutch}}
7: Datsun 1200 used three basic brake master cylinders:
8: ...16" safety split circuit (tandem), used with disc-brake models
9: ...ety split circuit (tandem), used with deluxe drum-brake models
10: * 11/16" single reservoir, used with economy drum-brake models - Brake Swaps (21279 bytes)
1: For general brake improvements, see [[Brake Upgrades]].
3: {{Brake_Mods_Navbox}}
4: = Better Brakes =
6: * Bigger caliper and brake pads will slow down car more quickly
7: * Larger-diameter disc brake rotor will improve braking power and sensitivity - Brake Upgrades (9218 bytes)
1: ...ll -- even the cheapest new import car has better brakes than the 1973 Datsun 1200.
4: There are two easy ways to get better brakes. This article will discuss these methods:
5: * Better brake pads, using premium materials
6: * Simple brakes swaps requiring no machining
8: ...brakes, as good as any new car. For details see [[Brake Swaps]]. - 1200 Disc Brake Swap (1383 bytes)
1: Swapping your front drum brakes to disc brakes is a worthwile easy upgrade.
4: ... 1200 has all-drum brakes, take note that '''disc brakes are''':
6: ...rectly adjusted drums, who has time to adjust the brakes?
10: ... bolt in the new assembly and [[bleed]] the front brakes.
12: ...ual-brake master cylinder''' along with its front brake hard-lines. - Brake Booster Swaps (9305 bytes)
1: ... want one so that it is a bit easier to press the brake pedal.
5: With the light weight of the 1200, you don't need brake booster — the pedal effort is not high on a...
7: CAUTION: If your small brakes are locking up now, a booster will only make the...
9: ... the factory 1200 booster, see [[Brake Booster]]. Brake Booster was used from October 1989 in Sunny Truck... - Brake Booster (4009 bytes)
1: {{BackTo|Brakes}}
3: ... to press the pedal. The booster doesn't make the brakes stop quicker, but instead lets a small person pr...
5: {{See|Brake Booster Swaps}}<br>
18: ... vertical alignment. It has separate front & rear brakes though sharing a common fluid reservoir.
34: ... what appear to be the same small-diameter [[B210 Brake Booster]] (M45 Master-Vac with 4.5 inch vacuum di... - B210 Brake Booster (5677 bytes)
1: A Brake Booster was fitted to many disc-brake B210s, including most 1976-1978 120Ys and all USA...
4: [[B210]] (including later 120Y) models that use a brake booster use a type M45 Master-Vac with 4.5-inch v...
9: ...minum adapter so that a 2-bolt vertical pattern [[Brake master cylinder]] can be fitted
74: ...April 1975) were fitted with Disc front brakes. A brake booster was standard for GX, optional with GL. Th...
80: 47210-H6100 MASTERVAC ASSY-BRAKE 1976-1977 A14/L16 (op. others) - Brake Adjustment (1167 bytes)
1: ... adjustment for optimal braking performance. Disc brakes require no adjusting.
6: See [[Brake master cylinder]] for adjustment procedure.
8: = Drum Brakes =
9: ... are adjusted correctly -- nearly as well as disc brakes. If you keep them adjusted periodically the peda...
11: See main article: [[Drum Brake Adjustment]] - Brake Lines (3783 bytes)
1: Brake Piping ([[Brakes|Brake]] lines).
4: [[Brake Piping Part Numbers]]
8: Brass brake connector (T-piece) - bolts to the rear diff. The...
23: [[#4-way connector]] for '''Single''' brake master cylinder
26: [[#3-way Connector]] for '''Tandem''' brake master cylinder - Hand Brake (5385 bytes)
1: ..." (the primary [[brakes]] are called the "service brakes").
5: ...nd Brake Cover]] is called by Nissan the "parking brake lever COVER".
8: 36310 Hand Brake Lever Assembly (comes in black, brown and grey)
11: ..._Part_Numbers|36315-H1001]] GRIP-HAND BRAKE (Hand Brake Lever Handle)
14: 36402 front handbrake cable - Brake Wiring (1485 bytes)
1: ...lights up if there is a problem or if the parking brake is on.
5: = Brake Stop Lights =
6: See: [[Lamp_Wiring#Brake_lights|brake stop lamp wiring]]
8: = Hand Brake Switch =
9: Lamp switch for [[Hand Brake]] pull-handle was fitted to USA 1200s, Japan Sunn... - Brake Bleeding (4803 bytes)
1: ...maintenance schedule. Also be sure to bleed the [[brake master cylinder]] if it runs dry.
4: ...el), then [[Drum Brake Adjustment|adjust the drum brakes]], then afterward re-evaluate the pedal action. ...
14: # Top up reservoirs with new brake fluid of [[Fluids|recommended type]]
19: # Top up reservoirs with new brake fluid of recommended type
26: ...ry, top up reservoir with new fluid. DO NOT REUSE BRAKE FLUID. - 258mm Brake Upgrade (10065 bytes)
1: ... to [http://community.ratsun.net/topic/24226-1200-brake-upgrade-mklotz70/ mklotz and morrisun at Ratsun] ...
5: If you require vented brakes, see:
7: [[S13 Brakes]] for smaller, vented brakes
8: {{Photo!|vented_brake_rotors.jpg|wiki}} - Brake Sizing (1185 bytes)
1: [[Category:Brake System]]
11: ...arger bore is better... but at some point you get brakes that are so hard to push down on that I'd be afr...
13: ... in most cases a light car like the 1200 needs no brake booster. - Drum Brake Adjustment (6547 bytes)
3: ... are adjusted correctly -- nearly as well as disc brakes. If you keep them adjusted once a month the peda...
6: With drum brakes, the pedal will go down a bit but then should be...
8: ... done, bleeding at the wheels will never fix your brakes
10: # Check and adjust the brake pedal play - Brake Drum Removal (115 bytes)
1: [[Category:Brake System]] - Brake Hoses (2566 bytes)
1: ...tinguish them from the "hard" metal [[Brake Lines|brake lines]].
3: = Front Brake Hoses =
5: The front brake hoses have a slot in each end fitting. This slot ...
19: * 46202-H7025 ASSY-HOSE BRAKE FRONT L=280 (2) $21 USD
20: ** superceded 46202-89913 ASSY-HOSE BRAKE FRONT L=280 - Hand Brake Part Numbers (2851 bytes)
3: [[Hand Brake]] (Parking Brake Control)
4: ...or_Part_Numbers#USA|Floor Part Numbers]] for hand brake boot
11: 36010-H1001 CONTROL ASS'Y-hand brake STD B110
12: 1 36310-H1001 LEVER ASS'Y-hand brake STD
Page text matches
- Datsun 1200 encyclopedia (3415 bytes)
30: * [[:Category:Brake System|Brake System]]
43: * [[:Category:Brake Modifications|Brake Modifications]] - A12GX Engine (12809 bytes)
244: ...e was also provision for a vacuum takeoff for the brake booster. - Rear Axle (11788 bytes)
14: ...nd brake cross Rod -- a solid rod (B110 uses hand brake cables)
17: B110 H145 uses hand brake Cables (no rods)
76: rear axle assembly (housing, brakes, etc)
114: ...rings quiet and reduce gear lube leakage into the brake area.
166: * Brake line splitter differences - Rear Axle Swaps (24650 bytes)
4: * To get rear disc brakes
90: ...e small difference in the brake line routing, handbrake cable location etc. Also use the shock-mounting p...
148: ...d flange as B310 but is an H165 unit with 9" drum brakes.
170: ...nly needs the usual swap items: custom tailshaft, brake hooksups, leaf spring mounting. And obtain two 6-...
177: [[Rear Disc Brakes]] are available for this axle housing. - Performance (21399 bytes)
209: The disc-brake Datsun 1200 had decent brakes:
223: Compared to its time period, the 1200's brakes weren't necessarily bad:
224: disc-brake Datsun 1200: 190 ft
249: disc-brake Datsun 1200: 190 ft
281: * BHP - [[Horsepower#Brake_horsepower_.28bhp.29|brake horsepower]], the HP measured from the engine cra... - Ignition Timing (9164 bytes)
61: # turn engine off. Set parking brake. Put transmission in neutral so that the engine w... - Choke Operation and Adjustment (6774 bytes)
24: Apply the Parking Brake. Place transmission shift lever - Part Numbers Index (8259 bytes)
48: ...omatic Transmission Hardware]] OIL PUMP, CLUTCH & BRAKE
60: == Brake ==
61: [[Hand Brake Part Numbers|Hand Brake]] & HAND BRAKE CABLE
62: [[Front Drum Brake Part Numbers|Front Drum Brake]]
63: [[Disc Brake Part Numbers|Disc Brake]] - Choosing A Carburetor (14914 bytes)
101: ...s of the Weber/Mikuni-Solex/Dellorto type hit the brake master cylinder on LHD 1200s. [[Hitachi Twin Carb... - Lamp Wiring (8455 bytes)
11: * GY - Brake lights (stop lamps)
25: * Brake failure lamp (Japan GL & USA)
163: <tr><td>STOP</td><td>GY</td><td>Brake light circuit</td></tr>
181: = Brake lights =
182: ...use Box GY wire ("H" terminal 15A always-hot). So brake lights work when key is off. - Nissan Part Numbers (8833 bytes)
21: 50 BRAKE
38: ...tr><tr><td valign=top>47</td><td valign=top>Power brake section</td></tr><tr><td valign=top>48</td><td va... - Intake Manifold (14016 bytes)
272: * brake booster tap - Suspension And Brake Swaps (108 bytes)
4: * [[Brake Swaps]] - 56-Series Transmission Parts (14945 bytes)
481: ... high speed, soft rotating abrasive drum wheel. A brake cylinder hone will work, but you will be honing f... - Engine Troubleshooting Overview (17895 bytes)
106: * Fractured hose or loose connections between the brake servo unit and the inlet manifold. - Toyota 4A engine (10159 bytes)
222: ... rear axle is from the GTS model (AE88) with disc brakes. Some were fitted with [[LSD]], but if not TRD s...
234: == Brake Booster & Clutch Pedal ==
240: Brake booster - Wheels (18326 bytes)
30: ...meter inside, possibly for clearance of the large brakes. These wheels are same as Datsun 610 and can be ...
58: ...owever the B310 13" wheels do not clear the front brake calipers.
83: ...e wheel, particularly the deep well hits the B110 brake caliper.
179: ...ers won't fit the front of the 1200. They hit the brake calipers, which may be related to the shape of th...
265: ...4" spacer on fronts to clear the hub center & the brake caliper - Air dam (6148 bytes)
18: Modern air dam with brake ductwork
39: Classic "chin spoiler" with brake ducts
71: BRE-style with square brake ducts - Bar Cluster Gauge (2347 bytes)
46: with BRAKE warning lamp (JDM 7510 & 1977 shown) - Lighting System (2956 bytes)
60: Running lights, brake lamps (stop lights) and turn-signal lamps (blinke...
