ALL 1200-related Pages from 1984 Catalog (part number 99996-CAT84).
NOTE: For other catalogs, see Nissan Competition
![Competition198400.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/Competition198400.jpg) | | NISSAN COMPETITION PARTS | |
Proven names like Electromotive, Bob Sharp Racing, Tilton, Koni, Venolia and Iskenderian, backed by a complete line of non-USA [JDM] and competition parts from the factory make this the most comprehensive competition catalog ever.
Table of contents: ![Competition198401.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/Competition198401.jpg) | |
- 1200, B210, 210, 310/N10 Page 34 [sic, page 36]
- Miscellaneous Page 60
1200 Parts
Block, Crank, Rod, Bearings, Piston & Camshaft
Cylinder Head, Valves and Lubrication
Cooling
Hitachi Twin Carb
![Competition198440.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/Competition198440.jpg) | |
The GX/SU induction system was a production line option on non-USA versions of the 1200 and B210. Requires use of GX cylinder head. The GX system can be adapted to virtually any A-series engine.
Mikuni/Solex Carburetors
![th_Competition198440.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198440.jpg) |
This induction system requires the use of the GX or competition cylinder head. With appropriate jetting and venturi sizing this system can be applied to any modified A-series engine.
Fuel Pump & Components
- Electric fuel pump
- replacement filter
- blanking plate
Pulleys and Electrical
![Competition198441.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/Competition198441.jpg) | |
- Pulleys (A-series)
- Electrical System (A-series)
Tachometer, Speedometer and Exhaust
Flywheel, Clutch and Transmission
![th_Competition198443.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198443.jpg) |
- Flywheel & Clutch
- Transmissions
Differential
Stabilizer and Shocks
![th_Competition198445.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198445.jpg) |
- F10 & N10/310 Final Drive Gears (To 7/81)
- Wheel Studs & Nuts
- Brakes
- 99996-H7010 1200, F10 & 310/N10 DP11 BRAKE PAD SET
- 99996-K7000 B210 & 210 DP11 BRAKE PAD SET
- 44060-27720 BRAKE SHOE/FORE for 1200 and early B210
- 44070-27720 BRAKE SHOE AFT for 1200 and early B210
- 44060-A1270 BRAKE SHOE/FORE for late B210, 210, F10 & 310/N10
- 44070-A1270 BRAKE SHOE/AFT for late B210, 210, F10 & 310/N10
- 44100-H3320 5/8" WHEEL CYLINDER for 1200 and early B210
- 44100-H3300 11/16" WHEEL CYLINDER for 1200 and early B210
- 44100-H3100 13/16" WHEEL CYLINDER for 1200 and early B210
- 44100-M7000 5/8" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 44100-M4901 11/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 44100-G2800 3/4" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 44100-U9200 13/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 44100-N4601 7/8" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 44100-Q1100 15/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 44100-A7610 1" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 44100-A7611 1-1/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
- 1200 Stabilizer Bars
- 54611-H2300 20MM FRONT BAR
- 54617-H2300 BUSHING FOR 54611-H2300 2 REQ.
- 99996-H4301 QUICKOR 25MM FRONT BAR KIT
- 99996-H4351 QUICKOR 19MM REAR BAR KIT
- B210 Stabilizer Bars
- 54611-22301 19MM FRONT BAR
- 54617-22020 BUSHING FOR 54611-22301 2 REQ.
- 99996-H4060 INSTALLATION KIT FOR 54611-22031
- 54611-22030 23MM FRONT BAR
- 54617-22030 BUSHING FOR 54611-22030 2 REQ.
- 99996-H4060 INSTALLATION KIT FOR 54611-22030
- 210 [Datsun B310] Stabilizer Bars
- 310/N10 Stabilizer Bars
- Koni Shock Absorbers
- Front
- Rear
- 99996-1714N 1200/FRONT 2 REQ.
- 99996-2359A 1200/REAR (COUPE ONLY) 2 REQ.
- 99996-1912R B210/FRONT
- 99996-2359A B210/REAR (COUPE ONLY)
- 99996-2002P 210/FRONT
- 99996-2378B 210/REAR (EXCEPT WAGON)
- 99996-1130B 210/REAR (GAS)(EXCEPT WAGON)
- 99996-2002T 210/FRONT (SPORT)
- 99996-2378J 210/REAR (SPORT)(EXCEPT WAGON)
- 99996-2005P F10 & 310/N10/FRONT
- 99996-2205B F10 & 310/N10/REAR
Suspension and Fiberglass Parts
![th_Competition198447.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198447.jpg) |
- B210 GT4 Fiberglass Parts
- 210 Fiberglass Parts
Miscellaneous
Mikuni Accessories
![th_Competition198462.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198462.jpg) |
- Mikuni/Solex Accessories
- Main Jets
- Air Jets (Countersunk Type)
- Pilot Jets
- Outer Venturi (40PHH)
- Outer Venturi (44PHH)
- Needle Valve ASSY
- Velocity Stack
![th_Competition198463.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198463.jpg) |
- Mikuni/Solex Accessories [continued]
- Jet Blocks
- Main Bleed Pipe (Emulsion Tube)
Spark Plugs
- Champion Spark Plugs
- [various standard tip, gold tip or projected tip plugs]
- Spark Plug Spacer
- 99996-N6732 .096 SPARK PLUG SPACER
- 99996-0N677 .135 SPARK PLUG SPACER
Special Tools
![](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/Brochures/Nissan%20Competition%201984/th_63c.jpg) |
- Special Tools
- EG167-00000 UNI-SYN CARB ADJUSTMENT GAUGE
- ST358-50000 BRAKE ADJUSTMENT TOOL
Literature
Labels
![](http://datsun1200.com/uploads/thumbs/20963.jpg)
- Nissan/Datsun Die-cuts & Labels
- 99996-X1001 'DATSUN' BLACK (1.5" x 12")
- 99996-X1002 'DATSUN' WHITE (1.5" x 12")
- 99996-X1003 'NISSAN' BLACK (1.5" x 12")
- 99996-X1004 'NISSAN' WHITE (1.5" x 12")
- 99996-X1010 'DATSUN' BLACK (3.5" x 34")
- 99996-X1011 'DATSUN' WHITE (3.5" x 34")
- 99996-X1013 'NISSAN' BLACK (3.5" x 34")
- 99996-X1014 'NISSAN' WHITE (3.5" x 34")
- 99996-X2001 'DATSUN...WE ARE DRIVEN' BLACK
- 99996-X2002 'DATSUN...WE ARE DRIVEN' WHITE
- 25371-N3121 IGNITION CUT-OFF SWITCH LABEL (CIRCLE)
- 25371-A7600 IGNITION CUT-OFF SWITCH LABEL (TRIANGLE)
Nissan/Datsun Die-Cuts
25371-A7600, 25371-N3121
Wearing Apparel
![th_Competition198464.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/competition/th_Competition198464.jpg) |
- Wearing Apparel
- T-shirts
- Tank Tops
- Halter Top
- Patches
Posters
See Poster Gallery
![th_65.jpg](http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/Brochures/Nissan%20Competition%201984/th_65.jpg) |
- 99996-P0003 '74 B210 C/S
- 99996-P0010 '76 B210 C/S
- 99996-P0012 '77 B210 C/S
- 99996-P0013 '77 B210 IMSA RS
- 99996-P0014 Z/B210 IMSA
- 99996-P0017 '78 B210 C/S
- 99996-P0020 '79 B210 C/S
The catalog has posters for all kinds of Datsun-Nissan models. Here are the Sunny posters:
P0003 P0010 P0012 P0013 P0014 P0017 P0020
